Here is the error message:
DKMS make.log for 8812au-5.6.4.2_35491.20191025 for kernel 5.9.6-1-MANJARO-ARM (aarch64)
Mon Nov 9 09:28:14 PM EST 2020
make[1]: Entering directory ‘/var/lib/dkms/8812au/5.6.4.2_35491.20191025/build’
make ARCH=arm CROSS_COMPILE= -C /lib/modules/5.9.6-1-MANJARO-ARM/build M=/var/lib/dkms/8812au/5.6.4.2_35491.20191025/
build modules
make[2]: Entering directory ‘/usr/lib/modules/5.9.6-1-MANJARO-ARM/build’
Makefile:685: arch/arm/Makefile: No such file or directory
make[2]: *** No rule to make target ‘arch/arm/Makefile’. Stop.
make[2]: Leaving directory ‘/usr/lib/modules/5.9.6-1-MANJARO-ARM/build’
make[1]: *** [Makefile:2246: modules] Error 2
make[1]: Leaving directory ‘/var/lib/dkms/8812au/5.6.4.2_35491.20191025/build’
Used this one:
Source: AUR (en) - rtl88xxau-aircrack-dkms-git
Which file to change line 12?
No PKGBUILD for the above.
I have 5.9.6-1-MANJARO-ARM linux headers installed.
Got this message:
Good news! Module version v5.6.4.2_35491.20191025 for 88XXau.ko.gz
exactly matches what is already found in kernel 5.9.6-1-MANJARO-ARM.
DKMS will not replace this module.
You may override by specifying --force.
depmod…
DKMS: install completed.
dkms status
8812au, 5.6.4.2_35491.20191025, 5.9.6-1-MANJARO-ARM, aarch64: installed (WARNING! Diff between built and installed module!)
rtl8812au, 5.6.4.2.r11.g3110ad6: added
