RStudio does not start anymore after the latest Manjaro’s update. All what I get is an irresponsive black window.
I already tried to reinstall rstudio-desktop-bin
and rstudio-desktop-daily-bin
, but the problem persists.
Looking into $HOME/.local/share/rstudio/log/rdesktop.log
, I found the following error message:
2022-03-01T17:54:45.058572Z [rdesktop] ERROR Main window closed unexpectedly; LOGGED FROM: rstudio::desktop::MainWindow::closeEvent(QCloseEvent*)::<lambda(QVariant)> src/cpp/desktop/DesktopMainWindow.cpp:524
Apparently, the problem was already reported here, but no answer was provided.
Any idea on how to solve the problem?
Output of `inxi -Fazy`
Kernel: 5.16.11-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.16-x86_64
root=UUID=ca0b13f1-3220-4bc9-9dc7-77d2311111e0 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 4180Q3U v: ThinkPad T420
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 4180Q3U serial:
UEFI-[Legacy]: LENOVO v: 83ET82WW (1.52 ) date: 06/04/2018
ID-1: BAT0 charge: 4.8 Wh (32.7%) condition: 14.7/56.2 Wh (26.1%)
volts: 11.6 min: 10.8 model: SANYO 45N1001 type: Li-ion serial:
status: Not charging
Info: model: Intel Core i7-2640M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1066 high: 1875 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 797 2: 797 3: 797
4: 1875 bogomips: 22337
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo ThinkPad T420 driver: i915 v: kernel ports: active: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: Chicony integrated camera type: USB driver: uvcvideo
bus-ID: 1-1.6:5 chip-ID: 04f2:b221 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: LVDS-1 model: LG built: 2010 res: 1600x900 hz: 60 dpi: 131
gamma: 1.2 size: 310x174mm (12.2x6.9") diag: 355mm (14") ratio: 16:9
modes: 1600x900
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.11-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: down mac:
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0085 class-ID: 0280
IF: wlp3s0 state: up mac:
IF-ID-1: wwp0s29u1u4i6 state: down mac:
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial:
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 256.01 GiB (18.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
type: HDD rpm: 5400 serial: rev: A7G0 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 28.61 GiB (28.6%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 121.9 MiB (23.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 365.26 GiB size: 365.26 GiB (100.00%)
used: 227.29 GiB (62.2%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 28.61 GiB (28.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3533
Processes: 310 Uptime: 18m wakeups: 1 Memory: 15.41 GiB
used: 3.47 GiB (22.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1850 lib: 405 flatpak: 0
Shell: Zsh v: 5.8.1 running-in: konsole inxi: 3.3.13
