I have used hdmi sound but now I have a need to use the analog audio jack. However, I do not seem to have one in KDE Plasma (arm-unstable).
$ inxi -Fazy
Device-1: bcm2711-hdmi0 driver: vc4_hdmi bus ID: N/A chip ID: brcm:fef00700
Device-2: bcm2711-hdmi1 driver: vc4_hdmi bus ID: N/A chip ID: brcm:fef05700
Sound Server: ALSA v: k5.10.9-1-MANJARO-ARM
And amixer does not show an analog option.
Maybe related to these messages?
Jan 27 19:11:29 oblio kernel: vc4_hdmi fef05700.hdmi: ASoC: error at snd_soc_dai_startup on fef05700.hdmi: -19
Jan 27 19:11:29 oblio pulseaudio[783]: Failed to find a working profile.
Jan 27 19:11:29 oblio pulseaudio[783]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="platform-fef05700.hdmi" card_name="alsa_card.platform-fef05700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
But they seem to reference HDMI, which works fine, so maybe not.
$ cat /boot/config.txt
# sound
dtparam=audio=on
#hdmi_drive=2
$ cat /proc/cmdline
coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:C1:E1:C7 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 root=LABEL=MNJRO_ROOT rw rootfstype=btrfs rootwait console=ttyAMA0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyAMA0,115200 usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=1 audit=0 usb-storage.quirks=152d:1561:u
I have messed around with:
$ amixer cset numid=3 [1-4]
But they result in setting the volume to 0, no change in output device.
