Reboot
$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.88.1 0.0.0.0 UG 20100 0 0 eno1
192.168.4.0 0.0.0.0 255.255.255.0 U 100 0 0 eno1
192.168.88.0 0.0.0.0 255.255.255.0 U 100 0 0 eno1
Things went bad when I added 88.0/24 to support a MikroTik after a factory reset
Not sure if it’s best handled on this box
Or, on the dhcp server.
Another Manjaro box on the network is working after a reboot.
sudo route add default gw 192.168.4.1 eno1
[drew@drew-desk ~]$ route -n
0.0.0.0 192.168.4.1 0.0.0.0 UG 0 0 0 eno1
* So, I think the problem is here.
Makes things work
But, it doesn’t look right to me
It’s been years, if not decades since I last did this sort of work.
And, it restores the broken version if I reboot.
