How can I rotate one side screen on my desktop?
Wie kann ich meinen Bildschirm drehen?
Manjaro Gaming Edition
Best regards,
Hansi
Best regards,
Hansi
I guess you are talking about Display, and more precise one fo your displays in a multi-display setup.
Settings > Display and you select that display and you set the orientation you want.
Thanks a lot! Found it!
Manjaro Symbol -> Alle Einstellungen -> Anzeige -> Drehung -> Rechts -> Anwenden
