Source: https://root.nix.dk/utility-scripts/arch-arm-setup-wifi-script
Difficulty: ★★☆☆☆
Preconfigure ARM WiFi
The utility script preconfigures an ARM sd-card to connect to WiFi at first boot.
After you have written the installer image to your sd-card, run this script to configure a connection to your wifi.
Save the script on your system as e.g. wifi-hack.sh.
Assuming your sd-card is /dev/mmcblk0 the command to create a network using DHCP address assignment
sudo bash wifi-hack.sh /dev/mmcblk0 my-ssid my-passphrase
Optionally you can add ip info which will create a static network configuration
sudo bash wifi-hack.sh /dev/mmcblk0 my-ssid my-passphrase 192.168.1.10/24 192.168.1.1 192.168.1.1
#!/usr/bin/env bash
# Script to preconfigure Manjaro ARM installer for WiFi connection
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <https://www.gnu.org/licenses/>.
# @linux-aarhus - root.nix.dk
set -e
scriptname=$0
tmproot="/tmp/root"
usage(){
echo "Run script as root using su or sudo"
echo "Usage: sudo ${scriptname} /dev/mmcblkX ssid passphrase [ ip.x.y.z/24 gw.x.y.z ns.x.y.x ]"
exit 1
# run as root
if ! [[ $(whoami) == "root" ]] ; then
usage
fi
# check if arg1 is block device
if ! [[ -b $"$1" ]]; then
echo "'$1' is not a block devicce"
exit 1
fi
# mount partition
echo Mount sd-card root partition
mkdir -p "${tmproot}"
mount "$1"p2 "${tmproot}"
# create wlan0 network
# if we have 3 arguments - use dhcp
if [[ $# -eq 3 ]] ; then
cat << EOF >> "${tmproot}/etc/systemd/network/wlan0.network"
[Match]
Name=wlan0
[Network]
DHCP=yes
EOF
# if we have 6 arguments - static ip
elif [[ $# -eq 6 ]]; then
[Match]
Name=wlan0
[Network]
Address=$4
Gateway=$5
DNS=$6
EOF
# argument count must be either 3 or 6
else
usage
fi
# create wpa_supplicant.conf
wpa_passphrase "$2" "$3" > "${tmproot}/etc/wpa_supplicant/wpa_supplicant-wlan0.conf"
# create symlink for wlan0 service
ln -sf "/usr/lib/systemd/system/wpa_supplicant0.service" \
"${tmproot}/etc/systemd/system/multi-user.target.wants/wpa_supplicant@wlan0.service"
# unmount and clean up
echo Unmounting
umount ${tmproot}
echo Cleaning up
rmdir ${tmproot}
echo Done
