Convert GRUB+LUKS1 to UKI+LUKS2
This guide targets a default Manjaro Installation (no dualboot) using btrfs inside a LUKS container.
Prerequisites
The $esp (EFI System Partition) is expected to be 300MiB
The kernel is expected to be the latest LTS (e.g. 6.18)
Your know the layout of the disk
lsblk -fyou will need the device name e.g.
sdaornvme0n1and the partition numbers -
a default manjaro system will have
- EFI partition is
/dev/<device>1 - luks root is
/dev/<device>2 - luks swap is
/dev/<device>3
- EFI partition is
We will use labels - easier to work with than UUIDs which is different from one installation to the next.
Boot a live ISO
Open a terminal
Setting the assumptions as variables
The variables is to avoid human errors - mistyping commands etc.
If your disk is a SATA - remove the p from partition numbering
DEVICE="/dev/nvme0n1" # disk device /dev/sda or /dev/nvme0n1
EFI_NUM="p1" # efi partition number (default = 1)
SYS_NUM="p2" # system partition number (default = 2)
SWAP_NUM="p3" # swap parition number (default = 3)
MOUNTPOINT="/mnt" # mountpoint
KERNEL="linux618"
BOOT_LOADER="/EFI/Linux/manjaro-6.18-x86_64.efi"
LABEL_BOOT="Manjaro 6.18 (EFI)" # label for boot loader entry
LABEL_CRYPT_SYSTEM="cryptsystem" # label for partition luks system container
LABEL_CRYPT_SWAP="cryptswap" # label for partition luks swap container
LABEL_SYSTEM="system" # label for filesystem inside container
LABEL_SWAP="swap" # label for filesystem inside container
EFI_LABEL="EFI" # label for efi partition
convert luks container to luks2
cryptsetup convert ${DEVICE}${SYS_NUM} --type luks2 cryptsetup luksConvertKey ${DEVICE}${SYS_NUM} --pbkdf argon2id -
add label to root partition
cryptsystemsgdisk -c ${SYS_NUM}:${LABEL_CRYPT_SYSTEM} ${DEVICE} -
mount btrfs subvolumes - see Basic Rescue and Recovery
when mounted, set label on btrfs fileystem root mount point to
system
assuming you opened the container as/dev/mapper/systembtrfs filesystem label ${MOUNT} ${LABEL_SYSTEM} udevadm trigger -
set label on efi partition
sgdisk -c ${EFI_NUM}:${EFI_LABEL} ${DEVICE} -
create mount point for EFI partition
mkdir ${MOUNT}/efi -
mount efi partition on the mountpoint
mount ${DEVICE}${EFI_NUM} ${MOUNT}/efi -
enter chroot using the defined mountpoint
manjaro-chroot ${MOUNT} /bin/bash
System Configuration
optional edit: add
FONTandFONT_MAPto/etc/vconsole.conf
example (the FONT_MAP is standard western font map)KEYMAP=dk FONT=lat2-16 FONT_MAP=8859-1 -
edit: remove or comment root directive from
/etc/crypttab -
edit: change efi mount in
/etc/fstabto be/efi(created beforehand) -
edit: modify
/etc/fstabto
use thesystempartition label for all btrfs subvolumes for all subvolumes
use theEFIpartition label for efi partition moving the mountpoint to/efiLABEL=EFI /efi vfat defaults,umask=0077 0 2 LABEL=system / btrfs subvol=/@,defaults,compress=zstd:1 0 0 LABEL=system /home btrfs subvol=/@home,defaults,compress=zstd:1 0 0 LABEL=system /var/log btrfs subvol=/@log,defaults,compress=zstd:1 0 0 LABEL=system /var/cache btrfs subvol=/@cache,defaults,compress=zstd:1 0 0 #/dev/mapper/swap swap swap defaults,noatime,mode=1777 0 0 -
create: file
/etc/crypttab.initramfswith contentsystem /dev/disk/by-partlabel/cryptsystem none timeout=120 -
create: file
/etc/kernel/cmdlinewith content (cat /proc/cmdline) and amend to look likefbcon=nodefer rd.luks.allow-discards bgrt_disable root=LABEL=system rootflags=subvol=@,rw quiet splash udevlog_priority=3 vt.global_cursor_default=0 -
edit: mkintcpio.conf
FILESarray - remove keyfileHOOKSarray- remove
encrypt - add
systemd,sd-vconsoleandsd-encrypt
- remove
FILES=() HOOKS=(base systemd microcode autodetect kms modconf block keyboard sd-vconsole sd-encrypt plymouth filesystems fsck) -
edit:
/etc/mkinitcpio.d/linux<kernel>.preset
The file will look like this for Manjaro Linux 6.18$ cat /etc/mkinitcpio.d/linux618.preset # mkinitcpio preset file for the '6.18-x86_64' package #ALL_config="/etc/mkinitcpio.conf" ALL_kver="/boot/vmlinuz-6.18-x86_64" PRESETS=('default' 'fallback') #default_config="/etc/mkinitcpio.conf" #default_image="/boot/initramfs-6.18-x86_64.img" default_uki="/efi/EFI/Linux/manjaro-6.18-x86_64.efi" default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp" #fallback_config="/etc/mkinitcpio.conf" #fallback_image="/boot/initramfs-6.18-x86_64-fallback.img" fallback_uki="/efi/EFI/Linux/manjaro-6.18-x86_64-fallback.efi" fallback_options="-S autodetect"Change to
ALL_kver="/boot/vmlinuz-6.18-x86_64" PRESETS=('default') default_uki="/efi/EFI/Linux/manjaro-6.18-x86_64.efi" default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp" -
configure
plymouthto usespinfinity(or another theme providing a nice passphrase input)plymouth-set-default-theme spinfinity -
create Linux folder in
/efi/EFImkdir /efi/EFI/Linux -
generate initramfs
mkinitcpio -p ${KERNEL} -
create a EFI boot entry (assuming kernel 6.18)
efibootmgr --create --disk ${DEVICE} --part ${EFI_NUM} --loader ${BOOT_LOADER} --label ${LABEL_BOOT} --unicode -
remove grub efi stubs
rm -r /efi/EFI/boot rm -r /efi/EFI/Manjaro -
remove grub related packages and mkinitcpio-openswap
pacman -Rns grub-theme-manjaro install-grub update-grub grub grub-btrfs mkinitcpio-openswap -
before you reboot the system
You can useefibootmgrto set the bootorder
This will ensure your new entry will be used first
You will need the number from the output e.gBoot0000to set the bootorder
Example your new entry is0000unlikely but an exampleefibootmgr -o 0000
