Convert system from GRUB to UKI
The UKI is a Unified Kernel Image - a couple of benefits
- faster startup
- for encrypted systems better algorithms and faster decryption
- simplified maintenance
- signing (for use with Secure Boot)
- using the latest LTS greatly simplifies ongoing kernel maintenance
I have considered if there are any cons - I couldn’t think of any - but after carefully considering what could possibly go wrong
- watch out and verify that your UKI build successfully
- do not change your kernel cmdline arguments without proper validation
- do not blindly restart your system
Assumptions
A default Manjaro Linux encrypted standalone UEFI installation (no dual/multi booting)
- system disk is
/dev/nvme0n1ESP is first partiion (1) and system is on second partition (2) - default luks container encrypted with luks1 (default Calamares)
- default root file system is
btrfs - kernel is 6.18
EFI partition
A common Manjaro Linux EFI partition size (created by Calamares) is 300MB.
A unified kernel (without Nvidia) is around 55MB so there should be room on the EFI partition.
In any case check the size (example is my workstation configured with UKI)
$ sudo du -h /efi
55M /efi/EFI/Linux
4,0K /efi/EFI/manjaro/fw
80K /efi/EFI/manjaro
55M /efi/EFI
12K /efi/loader/credentials
20K /efi/loader
56M /efi
Avoiding errors
To avoid errors with disk and partition I will use variables for the partitions.
Enter the following (you may adjust this if your device is not nvme0n1)
disk="/dev/nvme0n1"
efipart="/dev/nvme0n1p1"
rootpart="/dev/nvme0n1p2"
Boot a live ISO
Open a terminal and switch to root context using su
convert to luks2
Convert the container on the root partition to luks2 - the benefit is better encryption algorithms and faster unlocking
cryptsetup convert $rootpart --type luks2
cryptsetup luksConvertKey $rootpart --pbkdf argon2id
using labels
Using labels simplifies maintenance, so add the label cryptsystem to the root partition
e2label cryptsystem $rootpart
Unlock the root container
cryptsetup open $rootpart system
Mount the root btrfs filesystem
Assuming a default Manjaro btrfs file system layout
mount -t btrfs -o subvol=@ /dev/mapper/system /mnt
mount -t btrfs -o subvol=@home /dev/mapper/system /mnt/home
mount -t btrfs -o subvol=@cache /dev/mapper/system /mnt/var/cache
mount -t btrfs -o subvol=@log /dev/mapper/system /mnt/var/log
label the btrfs filesystem
Simplify the maintenance by adding the label system to your btrfs file root
btrfs filesystem label /mnt system
udevadm trigger
label ext4 or xfs and mount
Note: Since btrfs is the default on new Manjaro Linux installations, this guide has been written with btrfs in mind, but the approach is equally valid if your root file system is ext4 or xfs. Simply adjust the mount procedure and the labelling of the root file system.
To label your file system inside the container
- ext4:
e2label system /dev/mapper/system - xfs:
xfs_admin -L system /dev/mapper/system
mount /dev/mapper/system /mnt
Label and mount the efi partition
Label the efi partition with EFI
fatlabel $efipart EFI
Using the UEFI standard, create the /efi mountpoint inside the root mountpoint, we also need the Linux subfolder in the EFI folder.
Ensure there is no folder or symlinking named efi in the mounted root file system, them create the folder, mount the partition and finally create the location for the UKI
rm -rf /mnt/efi
mkdir /mnt/efi
mount $efipart /mnt/efi
mkdir /mnt/efi/EFI/Linux
Mount system devices
mount --bind /dev /mnt/dev
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
mount --bind /run /mnt/run
Enter chroot
manjaro-chroot /mnt /bin/bash
Configuration
edit: the file /etc/mkinitcpio.d/linux618.preset. The file has a lot of content - mostly commented - so I will only list the important bits here. Ensure the rest is commented
ALL_kver="/boot/vmlinuz-6.18-x86_64"
PRESETS=('default')
default_uki="/efi/EFI/Linux/manjaro-6.18.efi"
default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp"
edit: add a FONT and FONT_MAP to /etc/vconsole.conf this will make it possible to use non-us characters in the passphrase ref: Linux console - ArchWiki
FONT=lat2-16
FONT_MAP=8859-1
edit: remove or comment root directive from /etc/crypttab (no use for it)
edit: change /etc/fstab to use /efi as mountpoint for ESP (EFI System Partition) (instead of /boot/efi)
edit: simplify maintenance by modifying /etc/fstab to use a partition label instead of uuid
The following is samples from my working systems (laptop and workstation)
LABEL=EFI /efi vfat rw,relatime,umask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 2
btrfs
LABEL=system / btrfs subvol=/@,defaults,compress=zstd:1 0 0
LABEL=system /home btrfs subvol=/@home,defaults,compress=zstd:1 0 0
LABEL=system /var/log btrfs subvol=/@log,defaults,compress=zstd:1 0 0
LABEL=system /var/cache btrfs subvol=/@cache,defaults,compress=zstd:1 0 0
ext4
LABEL=system / ext4 rw,noatime 0 1
xfs
LABEL=system / xfs rw,relatime,inode64,logbufs=8,logbsize=32k,noquota 0 0
create: file /etc/crypttab.initramfs with content, this is where we point the root file system (instead of the crypttab file above)
system /dev/disk/by-partlabel/cryptsystem none timeout=120
create: file /etc/kernel/cmdline with content.
Using btrfs
fbcon=nodefer rd.luks.allow-discards bgrt_disable root=LABEL=system rootflags=subvol=@,rw quiet splash udevlog_priority=3 vt.global_cursor_default=0
Using ext4 or xfs
fbcon=nodefer rd.luks.allow-discards bgrt_disable root=LABEL=system quiet splash udevlog_priority=3 vt.global_cursor_default=0
edit: file /etc/mkinitcpio.conf (the dots are representing existing content)
FILES=()
HOOKS=(systemd microcode autodetect kms modconf block keyboard sd-vconsole sd-encrypt filesystems plymouth fsck)
configure: plymouth to use a theme like bgrt or spinfinity
plymouth-set-default-theme bgrt
generate: the unified kernel (assuming linux 6.18 kernel)
mkinitcpio -p linux618
configure: UEFI firmware to load the UKI
efibootmgr --create --disk $disk --part 1 --loader "/EFI/Linux/manjaro-6.18.efi" --label "Manjaro Linux 6.18LTS" --unicode
housekeeping: Remove grub and related files
pacman -Rns grub-theme-manjaro install-grub update-grub grub grub-btrfs mkinitcpio-openswap
Be sure to do some house keeping - remove obsolete kernels and their configuration.
Recovery
When you have created your first UKI and succesfully booted your system, copy the UKI to a recovery image.
sudo cp /efi/EFI/Linux/manjaro-6.18.efi /efi/EFI/Linux/recovery.efi
Then add the image to your firmware
sudo efibootmgr --create --disk $disk --part 1 --loader "/EFI/Linux/recovery.efi" --label "Recovery 6.18LTS" --unicode
Should it need be - you can use your system’s firmware boot override to select the Recovery image to get to a working system where you can fix the issue.
Another option is to use rEFInd - a graphical utility for listing available EFI binaries.
