I installed Manjaro on a disk with given paritions:
/dev/sda1 : /boot/efi
/dev/sda2 : something not related to linux
/dev/sda3: / (root)
/dev/sda4: /home
Grub does is not loading when I boot up the system. I used the live installation media to detect bootloaders and found that root is set to sda1 instead of sda3. When I change it to sda3, it works fine except that the changes are not permanent. How can I make the changes permanent ?
I looked at fstab, the partitions look correct. But for some reason, when I try to boot, I can’t unless I change things. Let me try to boot again and take some screenshots.
I found someone with exactly the same problem as mine. For some reason, the EFI partition is given a legacy_boot flag instead of boot, even though I explicitly set the flag to boot during the installation.
