Having installed manjaro cinnamon 21.0.7 , When booting into the system I get straight into the emergency root shell. Problem is the root partition UUID cannot be found. After booting from the live USB and mounting the the NVME root partition on /mnt and inspecting the fstab file the UUID is the one not found when booting the system. I have also tried installing the mate version with which gives same problem.
@motut is fstab file inact?
Hi hisham_6c5
Thanks for responding. Do you mean is it executable?
No, that file is never executable.
Is the syntax of that file correct and does the UUID
to be mounted as the root fs match the UUID
of your error message?
$ cat /etc/fstab
Does the kernel get a UUID
to use in its cmdline?
$ cat /proc/cmdline
Hi,
have a look at this post, it looks like you’ve come across the same problem:
Hi freggel.doe
The UUID to be mounted matches the error message one.
there is no cmdline in dir proc
- UEFI or BIOS mode?
- encrypted or non-encrypted?
- dual boot or single Linux system?
Please share /etc/fstab file and UUID’s by posting here
cat /etc/fstab
sudo BLKID
sudo fdisk -l
Sorry, the leading slash was missing. I’ve updated the post.
But since the system doesn’t boot, this would not be present
Check /etc/default/grub
for GRUB_CMDLINE_LINUX
and GRUB_CMDLINE_LINUX_DEFAULT
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
#GRUB_ROOT_FS_RO=true
Thank you for responding, however it does not work for me.
Hi Wollie
UEFI mode I think
non-encrypted
dual boot with Ubuntu 20.04 LTS
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=945B-61FA /boot/efi vfat umask=0077 0 2
UUID=e3284cc7-0fe1-4453-8072-5dbbc40bdc36 / ext4 defaults,noatime 0 1
UUID=53bf4c40-ab4e-42f7-96b9-14e9db25101a /home ext4 defaults,noatime 0 2
[manjaro-cinnamon /]# blkid
/dev/sda1: BLOCK_SIZE="2048" UUID="2021-04-21-08-48-25-00" LABEL="MANJARO_CINNAMON_2102" TYPE="iso9660"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="176E-4A11" BLOCK_SIZE="512" TYPE="vfat"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/nvme0n1p1: UUID="945B-61FA" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="6bd6968b-6959-4b49-a5f3-c0719d8df4fd"
/dev/nvme0n1p2: UUID="31d9b530-fce2-4888-86bd-3597998b0ea3" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="ubuntu-root" PARTUUID="54096a78-b795-4175-a6c9-469fa3f7bcdf"
/dev/nvme0n1p3: UUID="ebb0eb7b-6b67-4489-be67-f919311e56b9" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="ubuntu-home" PARTUUID="a0d6ceec-3c7a-4cbe-bd32-b7bb760a67cd"
/dev/nvme0n1p4: UUID="d1b3f081-60f5-45d6-82cb-a832bdd6ac93" TYPE="swap" PARTUUID="fcfe3be4-ce5b-476b-8ba5-d2e2410e8515"
/dev/nvme0n1p5: UUID="e3284cc7-0fe1-4453-8072-5dbbc40bdc36" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="manjaro-root" PARTUUID="aa957202-fbb9-4d29-96aa-91d744c80a3a"
/dev/nvme0n1p6: UUID="53bf4c40-ab4e-42f7-96b9-14e9db25101a" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="manjaro-home" PARTUUID="61f5776e-b651-4a0b-b305-9382f25c7393"
/dev/nvme0n1p7: PARTLABEL="veracrypt" PARTUUID="67e1b476-068e-45db-949d-bda56f21e4e6"
/dev/nvme0n1p8: UUID="0589c83c-1f9a-470b-b172-cdd8decb91b5" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="timeshift" PARTUUID="6490fb95-ee67-4f2d-be7d-5ded1c50236f"
I would try to boot a live ISO in UEFI mode and restore the boot loader as described here:
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader#Use_manjaro-chroot
Make sure to follow the EFI System description and not the BIOS description.
Hi Wollie
THanks for trying, I think I will give it up. I have installed this system on an older hp laptop with no problems. I guess this version does not like nvme partitions. I will use my older system with manjaro and the newer system with ubuntu.
It is a pity that the installation media cannot detect problems after it has "successfully@ installed the system
Best wishes
Hi again Wollie
I have connected an SSD to a USB slot and installed manjaro on it with no problem it seems to like the /dev/sda partitions.
