This partition used to be ~3.7G used and recently spiked up to 11G out of no where:
/dev/mmcblk2p2 15G 11G 3.3G 77%
ncdu -x /
output:
. 2.3 GiB [##########] /usr
. 1.3 GiB [##### ] /var
21.4 MiB [ ] /home
. 8.1 MiB [ ] /etc
! 16.0 KiB [ ] /lost+found
12.0 KiB [ ] /srv
. 8.0 KiB [ ] /opt
! 4.0 KiB [ ] /root
4.0 KiB [ ] /mnt
4.0 KiB [ ] overlay.txt
Above output gives me the ~3.7G that I was expecting
but I can’t find ~7.6G anywhere in the system using these tools, what else can I use?
Have you tried cleaning out the package cache?
sudo paccache -rvk0
Result: (disk space saved: 389.5 MiB)
The strange thing is I can’t find any directories that are more than the original 3.4G.
Is it possible that these are hidden files?
Not normally, no. Hidden files are user-specific configuration data ─ usually in plain text format ─ and cache files.
wdt
14 December 2020 19:22
5
I strongly recommend , ncdu
It is a little slow when it has to read lots of files
q to quit, d to delete, start as root/sudo to delete anything
I used ncdu as well but still not finding anything close to the amount I’m looking for
I’m not really shure about your system configurations.
3 points I think are worth investigating:
in your list there is no /usr directory which is likely filled
/opt usually contains more than 8KiB
leading to the last
overlay.txt indicates that there is an overlay filesystem involved. Could it be that you are looking at the changes only?
BG405
14 December 2020 21:27
8
Does df -h
reveal any more? Re. @a-sassermann ’s comment:
a-sassermann:
As that isn’t shown in your output maybe it will with the above command.
Hope this helps.
first line in OP shows the df -h
output for that partition
missed it on copy/paste, updated above
Strit
15 December 2020 10:13
11
And what’s the output of sudo ncdu /
714.4 GiB [##########] /mnt
2.3 GiB [ ] /usr
1.3 GiB [ ] /var
52.7 MiB [ ] /boot
21.4 MiB [ ] /home
16.3 MiB [ ] /root
8.2 MiB [ ] /etc
1.4 MiB [ ] /run
16.0 KiB [ ] /opt
e 16.0 KiB [ ] /lost+found
12.0 KiB [ ] /srv
. 0.0 B [ ] /proc
0.0 B [ ] /sys
0.0 B [ ] /dev
0.0 B [ ] /tmp
@ 0.0 B [ ] sbin
@ 0.0 B [ ] lib
@ 0.0 B [ ] bin
/mnt
is external SSD so irrelevant
0n0w1c
15 December 2020 13:14
14
Have you looked in the /mnt directory, without the external drive mounted?
theres nothing extra there when mounted, why unmount?
cscs
15 December 2020 14:47
16
Maybe they are marked deleted but kept open, like this? :
0n0w1c
15 December 2020 14:53
17
If you have files in /mnt and you mount over it, you will not see the files under the mount. They continue to take up space on /. Basically, just as you are describing. Lost disk space and no files to account for that lost space.
I had deleted files from /mnt
that were sent there on accident so its possible, but why is it showing up as used in /dev/mmcblk2p2
and not /dev/sda1
(SSD)?
ok that makes sense ill check
closer! mount --bind / /mnt
& du -shx /mnt
output shows me:
3.7G /
“You save me a lot of time, I have a backup script which performs its operations by anacron from ssd to hdd, and when I temporary removed hdd it had pushed a backup to hdd mount point. And of course I didn’t catch this.”
this is basically what happened - how can I delete the files under the mount?
BG405
15 December 2020 15:16
21
When you unmount from that mountpoint, those files will be accessible.
