Hi everyone, having some really unstable wifi if you can help that do be great:)
Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi
things i remember trying:
1.changing to connman network manager(he was un responsive when i got the drops)
2. restarting the network manager(always helps for a minute or two)
3. something about mac randomization(not sure what it did)
4. disabled ipv6(maybe helped a little bit?)
process error(not sure if it’s related)
- Journal begins at Wed 2021-06-09 18:37:32 IDT, ends at Sun 2021-06-13 16:14:56 IDT. –
Jun 13 11:05:30 hazannovich-Manj kernel: usb 1-8: device descriptor read/64, error -71
Jun 13 11:05:31 hazannovich-Manj kernel: usb 1-8: device descriptor read/64, error -71
Jun 13 11:05:31 hazannovich-Manj systemd-udevd[276]: could not read from '/sys/module/pcc_cpufreq/initsta>
Jun 13 11:05:31 hazannovich-Manj wpa_supplicant[584]: nl80211: kernel reports: Attribute failed policy va>
Jun 13 11:05:31 hazannovich-Manj wpa_supplicant[584]: Failed to create interface p2p-dev-wlp0s20f3: -22 (>
Jun 13 11:05:31 hazannovich-Manj wpa_supplicant[584]: nl80211: Failed to create a P2P Device interface p2>
Jun 13 11:05:31 hazannovich-Manj systemd-udevd[270]: could not read from '/sys/module/pcc_cpufreq/initsta>
Jun 13 11:05:32 hazannovich-Manj kernel: usb 1-8: device not accepting address 7, error -71
Jun 13 11:05:32 hazannovich-Manj kernel: usb 1-8: device not accepting address 8, error -71
Jun 13 11:05:32 hazannovich-Manj kernel: usb usb1-port8: unable to enumerate USB device
Jun 13 11:05:33 hazannovich-Manj kernel: snd_hda_codec_hdmi ehdaudio0D2: Monitor plugged-in, Failed to po>
Jun 13 11:05:36 hazannovich-Manj kwin_x11[995]: kwin_xkbcommon: XKB: couldn’t find a Compose file for loc>
Jun 13 11:05:38 hazannovich-Manj dolphin[1267]: MEGASYNCOVERLAYPLUGIN: error in connection to notify serv>
Jun 13 11:05:38 hazannovich-Manj dolphin[1267]: MEGASYNCOVERLAYPLUGIN: error in connection to ext server:>
Jun 13 11:05:39 hazannovich-Manj dolphin[1267]: MEGASYNCOVERLAYPLUGIN: error in connection to ext server:>
Fazy:
System: Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=6d47aaae-56eb-4baf-b792-146df1b09312 rw ipv6.disable=1 quiet apparmor=1 security=apparmor udev.log_priority=3 Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux Machine: Type: Convertible System: LENOVO product: 81TC v: Lenovo Yoga C740-14IML serial: <filter> Chassis: type: 31 v: Lenovo Yoga C740-14IML serial: <filter> Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: BNCN41WW date: 11/30/2020 Battery: ID-1: BAT0 charge: 45.6 Wh (100.0%) condition: 45.6/51.0 Wh (89.3%) volts: 8.7 min: 7.7 model: SMP L18M4PE0 type: Li-poly serial: <filter> status: Full cycles: 347 CPU: Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12) microcode: DE cache: L2: 8 MiB flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36812 Speed: 800 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling Type: srbds mitigation: TSX disabled Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300 Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-7:4 chip-ID: 13d3:56b2 class-ID: 0e02 Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1 Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 675x380mm (26.6x15.0") s-diag: 775mm (30.5") Monitor-1: DP1 res: 2560x1440 hz: 60 dpi: 93 size: 700x390mm (27.6x15.4") diag: 801mm (31.5") OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.2 direct render: Yes Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: sof-audio-pci alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401 Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes Sound Server-2: JACK v: 0.125.0 running: no Sound Server-3: PulseAudio v: 14.2 running: yes Sound Server-4: PipeWire v: 0.3.28 running: no Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel port: 3000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280 IF: wlp0s20f3 state: up mac: <filter> Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:10 chip-ID: 8087:0026 class-ID: e001 Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter> Drives: Local Storage: total: 968.78 GiB used: 58.73 GiB (6.1%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 3L1QEXF7 temp: 41.9 C scheme: GPT ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade size: 14.91 GiB block-size: physical: 512 B logical: 512 B serial: <filter> rev: 2.01 scheme: MBR SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure? Partition: ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 58.73 GiB (6.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 Swap: Alert: No swap data was found. Sensors: System Temperatures: cpu: 43.0 C mobo: N/A Fan Speeds (RPM): N/A Info: Processes: 239 Uptime: 56m wakeups: 3 Memory: 15.35 GiB used: 2.6 GiB (17.0%) Init: systemd v: 247 tool: systemctl Compilers: gcc: 11.1.0 Packages: 1299 pacman: 1283 lib: 361 flatpak: 8 snap: 8 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
any ideas what i should do?
