Rog-control-center and asusd do not not work after Manjaro update
I used to be able to set my charging limit, change my keyboard color etc., but after an update, rog-control-center doesn’t launch, Ive installed asusctl and rog control center from the official repository, AUR (with AUR it says asusctl could not be configured), and a gitlab manjaro repo i saw linked somewhere, but none worked. Ive been poking around and this is the furthest asusd got:
[INFO  asusd]        daemon v6.1.10
[INFO  asusd]     rog-anime v6.1.10
[INFO  asusd]     rog-slash v6.1.10
[INFO  asusd]      rog-aura v6.1.10
[INFO  asusd]  rog-profiles v6.1.10
[INFO  asusd] rog-platform v6.1.10
[INFO  asusd] Product family: ASUS TUF Gaming A15
[INFO  asusd] Board name: FA507UV
[INFO  config_traits] Parsed RON for "asusd::config::Config"
[INFO  rog_platform::platform] Found platform support at "asus-nb-wmi"
[INFO  rog_platform::power] Power: Checking "/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0A:00/power_supply/BAT1"
[INFO  rog_platform::power] Found a battery
[INFO  rog_platform::power] Checking battery attributes
[INFO  rog_platform::power] Found battery power at "BAT1", matched charge_control_end_threshold. Current level: "100"
[INFO  rog_platform::power] Power: Checking "/sys/devices/platform/ACPI0003:00/power_supply/ACAD"
[INFO  rog_platform::power] Found mains power at "ACAD"
[INFO  rog_platform::power] Power: Checking "/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001"
[INFO  rog_platform::power] Found USB-C power at "ucsi-source-psy-USBC000:001"
[INFO  rog_platform::power] Power: Checking "/sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:002"
[INFO  rog_platform::power] Found USB-C power at "ucsi-source-psy-USBC000:002"
[INFO  asusd::asus_armoury] Reloading gpu_mux_mode
[INFO  asusd::asus_armoury] inotify watch failed: Attribute not found: gpu_mux_mode. You can ignore this if your device does not support the feature
[INFO  asusd::asus_armoury] Reloading dgpu_disable
[INFO  asusd::asus_armoury] inotify watch failed: Attribute not found: dgpu_disable. You can ignore this if your device does not support the feature
[INFO  asusd::ctrl_fancurves] Device has profile control available
[INFO  asusd::ctrl_fancurves] Device has fan curves available
[INFO  config_traits] Parsed RON for "asusd::ctrl_fancurves::FanCurveConfig"
[INFO  asusd::ctrl_fancurves] Fan curves previously stored, loading...
[DEBUG rog_profiles] write_profile_curve_to_platform: writing profile:(performance), CurveData { fan: CPU, pwm: [5, 22, 38, 45, 56, 63, 81, 94], temp: [45, 49, 54, 68, 74, 79, 84, 89], enabled: false }
[ERROR rog_profiles::error] ProfileError: got: Permission denied (os error 13)
[WARN  asusd] Controller error: Profile error: std::io error: Permission denied (os error 13)
[INFO  rog_platform::cpu] Found CPU support at "cpu0", checking supported items
[INFO  rog_platform::cpu] cpufreq/scaling_available_governors: "performance powersave"
[INFO  rog_platform::cpu] cpufreq/scaling_governor: "powersave"
[INFO  rog_platform::cpu] cpufreq/energy_performance_available_preferences: "default performance balance_performance balance_power power "
[INFO  rog_platform::cpu] cpufreq/energy_performance_preference: "performance"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu0"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu1"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu10"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu11"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu12"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu13"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu14"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu15"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu2"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu3"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu4"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu5"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu6"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu7"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu8"
[INFO  rog_platform::cpu] Adding: "/sys/devices/system/cpu/cpu9"
[INFO  asusd::ctrl_platform] Begin Platform settings restore
[INFO  asusd::ctrl_platform] Starting inotify watch for asusd config file
[INFO  asusd::ctrl_platform] reloading charge_control_end_threshold to 100
[WARN  asusd] Controller error: Asus Platform error: charge_control_end_threshold Permission denied (os error 13)
[DEBUG asusd::aura_manager] Not ASUS vendor ID
[DEBUG asusd::aura_types] Testing for USB Slash
[INFO  asusd::aura_manager] Tested device was not Slash
[DEBUG asusd::aura_types] Testing for USB AniMe
[INFO  asusd::aura_types] No Anime Matrix capable laptop found
[INFO  asusd::aura_manager] Tested device was not AniMe Matrix
[INFO  asusd::aura_manager] No USB keyboard aura, system is ASUS TUF Gaming A15 FA507UV_FA507UV, try using sysfs backlight control
[INFO  asusd::aura_manager] TUF laptop, try using sysfs backlight control
[DEBUG asusd::aura_types] Testing for laptop aura
[INFO  asusd::aura_types] Found laptop aura type "tuf"
[INFO  rog_platform::keyboard_led] Found keyboard LED controls at "asus::kbd_backlight"
[INFO  asusd::aura_types] Found sysfs backlight control
[INFO  asusd::aura_laptop::config] Setting up AuraConfig for "tuf"
[INFO  rog_aura::aura_detection] Loaded default LED support data from /usr/share/asusd/aura_support.ron
[INFO  rog_aura::aura_detection] Matched to FA507
[DEBUG asusd::aura_laptop::config] creating default for Static
[DEBUG asusd::aura_laptop::config] creating default for Breathe
[DEBUG asusd::aura_laptop::config] creating default for RainbowCycle
[DEBUG asusd::aura_laptop::config] creating default for RainbowWave
[DEBUG asusd::aura_laptop::config] creating default for Pulse
[INFO  config_traits] Parsed RON for "asusd::aura_laptop::config::AuraConfig"
[DEBUG asusd::aura_laptop::trait_impls] reloading keyboard mode
[WARN  asusd::aura_laptop::trait_impls] Controller error: Asus Platform error: kbd_rgb_mode Permission denied (os error 13)
[INFO  asusd::aura_manager] Found 1 valid devices on startup
Error: MethodError(OwnedErrorName("org.freedesktop.DBus.Error.AccessDenied"), Some("Request to own name refused by policy"), Msg { type: Error, serial: 4294967295, sender: UniqueName("org.freedesktop.DBus"), reply-serial: 19, body: Str, fds: [] })
I have an ASUS TUF Gaming A15 FA507UV, and use the 6.13 kernel.
Quick update, i no longer get the above logs and now get:
Error: MissingFunction("asus-nb-wmi not found")
I cannot seem to get asus-nb-wmi, there’s one package named similarly but it fails to install (asus-rog-nb-wmi-dkms-git
This is a somewhat embarrasing self-solve,
Before installing asusctl/rog-control-center, all i had to do is to run
sudo modprobe asus-nb-wmi
This is what asusd claimed could not be found!
now make SURE you are on Wayland since rog-control-center doesn’t like X11 it will give you an error,
Install asusctl and rog-control-center from pamac,
And this time you shouldn’t get an error from pamac saying it failed to setup asusctl and it should launch!
I also recommend making a crontab job so you don’t have to type it every startup with the command above because it also fixed an issue where the microphone mute button didn’t work, i think it’s something that should be turned on normally, but the new update kind of just forgets!
