inxi output
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
serial: <superuser required>
Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F21 date: 02/08/2018
System RAM: total: 16 GiB available: 15.57 GiB used: 5.27 GiB (33.8%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3000 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001129
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 1946 high: 3072 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1474 2: 1550
3: 1550 4: 1392 5: 2844 6: 3072 7: 1357 8: 1550 9: 2737 10: 2872 11: 1412
12: 1550 bogomips: 76670
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02
class-ID: 0300
Device-2: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0894
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1215 s-dpi: 96 s-size: 1016x321mm (40.00x12.64")
s-diag: 1066mm (41.95")
Monitor-1: DVI-D-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 75 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
memory: 2.93 GiB
API: Vulkan v: 1.3.276 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 3GB driver: nvidia v: 545.29.06 device-ID: 10de:1c02
surfaces: xcb,xlib
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: 1: a2jmidid status: off 2: nsmd
status: off tools: cadence,jack_control,jack_mixer,qjackctl
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-jack
type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
status: discoverable: no pairing: no
Local Storage: total: 3.41 TiB used: 1.18 TiB (34.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 177.73 GiB (78.0%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 40809886-d17c-433b-876f-89a03d053b64
used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: E832-7B45
ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 830.8 GiB (90.7%) fs: ext4 dev: /dev/sdd
maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
size: 426.62 GiB (98.18%) used: 180.31 GiB (42.3%) fs: ext4 dev: /dev/sdc2
maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 17.7 GiB (1.0%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
uuid: 14863704-322a-453c-b7a5-87bba34bb094
Device-1: 1-1:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
Device-2: 1-2:3 info: Logitech CrystalCam type: video,audio
chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Device-1: 3-3:2 info: Ducky One 3̠ type: HID,keyboard,mouse
driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
serial: <filter>
Device-2: 3-4:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 37.6 C mobo: 29.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.21
Processes: 363 Power: uptime: 5h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: gsd-power,
tool: systemctl
Packages: 2474 pm: pacman pkgs: 2460 libs: 608 tools: gnome-software,pamac
pm: flatpak pkgs: 5 pm: snap pkgs: 9 Compilers: clang: 16.0.6 gcc: 13.2.1
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.33
At first Rockstar Launcher would throw an error related to not being usable with Windows 7 or 8 so I changed the version to Windows 10 in the prefix. Now the Rockstar Launcher will run, ask to check for saves on Windows Live, find none, then close itself and stop the GTA IV process.
I have a Proton Log but it is too massive to post but I can share it in another way if someone has a recommendation.
Edit: Uninstalled and reinstalled the game a bunch of times. It works now! No idea why, I think the Rockstar launcher updated. Hopefully it stays working!
