I have a weird issue with the linux console. I am trying to setup a rockpro64 and in doing that I am using an old Dell monitor with a 1680x1050 resolution.
When the rockpro64 boots, the first thing that I see is the output from uboot. This is OK. Then linux is booted and for a short time I see a patterned screen. After this, there is the linux boot output.
The issue is that as soon as uboot gives control to the linux kernel, the display becomes terrible: all trembling and slightly distorted. The monitor reports that the output is at 1400x1050@55Hz, which is obviously not correct. However, /sys/class/graphics/fb0/modes correctly shows U:1680x1050p-0.
Obviously, I suspect that the poor display is due to using an output format that is not suited for the monitor. However:
- Why does uboot pick the right display mode and linux does not?
- What would be the proper way to instruct linux to use a more correct display mode for its console?
- Should I use some
Uenv.txtfile in/boot? Should I set somebootargsin it? Is the relevant kernel parameter to addvideo=...or something else? Do arm SOCs employing mali graphics use KMS?
- Should I use some
Note that issue is cross-distro (also seen with debian). Asking here because I am particularly interested in finding a solution for Manjaro (and particularly confident on the helpfulness of this community!)
Thanks for any help!
