speaker-test is silent.
alsamixer detects the card “rockchip,rk3328” but shows this message:
“This sound device does not have any controls.”
i’ve found people on the pine64-forum from different distros who changed their asound.conf to change ctl and pcm to 1 but it doesn’t do anything for me.
another answer is about adding a node to the device tree in ayufan’s kernel.
which doesn’t apply here since the node exists.
however:
$ cat /proc/device-tree/analog-sound/status
disabled
is there a way to enable it?
Strit
2 March 2021 15:37
2
We patch in HDMI sound card on Rock64 in our kernel, so it should be there.
But there is no Analog sound in the mainline kernel it seems.
The Roc-CC seems to have gotten an analog sound node recently, so you can try [patching that in] your kernel.
hi @Strit
thanks for your answer.
i went and had a look at the hdmi-sound node.
the node exists.
but:
$ fdtget /boot/dtbs/rockchip/rk3328-rock64.dtb /hdmi-sound status
disabled
i’ve tried enabling the analog-sound node:
sudo fdtput -t s /boot/dtbs/rockchip/rk3328-rock64.dtb /analog-sound status okay
reboot
but without effect :-/
it was enabled on 6. Jan in the upstream kernel along with some other changes.
Strit
2 March 2021 15:56
4
If the kernel produces the sound card, and it’s listed with aplay -l, then it’s a matter of configuring it in your environment.
Maybe it needs a special asound.conf file, like the Pinebooks.
ok. i was under the impression that it wouldn’t work with status: "disabled".
with the status set to “okay” and after running speaker-test (unsuccesfully), programs like aplay -L just freeze.
before running speaker-test, aplay -L works just fine and gives:
default:CARD=Analog
Analog, ff010000.i2s-rk3328-hifi ff410000.codec-0
Default Audio Device
sysdefault:CARD=Analog
with analog-sound.status set to disabled again, this is the output of aplay -L:
default:CARD=rockchiprk3328
rockchip,rk3328, ff000000.i2s-i2s-hifi i2s-hifi-0
sysdefault:CARD=rockchiprk3328
i had hoped to see separate analog and HDMI devices.
then i should probably stop tinkering with the device tree
i’ll report if i find a way of getting it to work with alsa config.
in the meantime, i found this .
Strit
2 March 2021 16:13
6
Yeah, it’s merged for kernel 5.12. You can test linux-rc in unstable branch, to see if it works.
With linux-rc, there are these three devices:
$ aplay -L | grep "^default"
default:CARD=Analog
default:CARD=SPDIF
default:CARD=HDMI
very promising!
thanks!
it seems like a good direction but i don’t suppose it will save me from digging deeper into ALSA…
forgot to add: sound works - just no controls…
cvlc --play-and-exit https://billwurtz.com/i-just-did-a-bad-thing.mp4
I’ve tried to understand how and when ALSA loads the card configuration, tried many file names, forced syntax errors, done lots of reboots…
system
Closed
19 March 2021 09:54
10
