Hi,
Recently tried to boot custom kernel with v5.10-rc2, with all pcie related fixes applied from Manajaro.
It fails to boot the root device on NVME. (Although can still boot from SDcard, but SDcard is really to lame compared to NVME).
After some extra debugging output, I found the direct cause.
In the following call chain, we failed to initialize vpcie1v8
and possibly vpcie0v9
rockchip_pcie_parse_host_dt()
|- rockchip>vpcie1v8 = devm_regulator_get_optional(dev, "vpcie1v8");
|- _regulator_get()
|- regulator_dev_lookup()
|- node = of_get_regulartor()
|- if (!node) {
|- r = of_find_regulator(); /* No @r found */
|- return ERR_PTR(-EPROBE_DEFER);
But I also checked the dtsi, vpcie1v8
and vpcie0v9
are all defined properly.
BTW, vpcie3v3
and vpcie12v
all works without problem.
Is there something wrong with the vcc_0v9
and vcc_1v8
definition in the dtsi?
Thanks.
