hello i what do ? just remove this files?
[12:57:18] Info: SCAN_MODE_DEV set to ‘THOROUGH’
[12:57:27] Checking /dev for suspicious file types [ Warning ]
[12:57:27] Warning: Suspicious file types found in /dev:
[12:57:27] /dev/shm/jack_db/metadata.db: Berkeley DB (Hash, version 9, native byte-order)
[12:57:27] /dev/shm/jack_db/__db.003: a.out little-endian 32-bit pure executable
[12:57:27] /dev/shm/jack_db/__db.002: a.out little-endian 32-bit pure executable
[12:57:27] /dev/shm/jack_db/__db.001: Applesoft BASIC program data, first line number 18
[12:57:27] Checking for hidden files and directories [ Warning ]
[12:57:27] Warning: Hidden file found: /etc/.updated: ASCII text
[12:57:28] Warning: Hidden file found: /usr/share/man/man5/.k5login.5.gz: gzip compressed data, max compression, from Unix, truncated
[12:57:28] Warning: Hidden file found: /usr/share/man/man5/.k5identity.5.gz: gzip compressed data, max compression, from Unix, truncat>
and i have problem with ufw ufw not starting at login
