Has anyone gotten riseup vpn working on a pinebook pro? I’ve been unsuccessful and wondering if it just doesn’t work for arm. Thanks.
Theres a couple of scripts in AUR but marked as x86_64 only.
https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=riseup-vpn
You may be able to build on PineBook if you clone the script and add aarch64 to the arch array
arch=('x86_64' 'aarch64')
Then install dependencies and build
makepkg -si
Awesome thanks so much! Apparently I didn’t have the right text for the build file. Works perfectly now.
