d77
1
I executed pinebook-pro-keyboard-updater (v0.0.3-2, v0.0.3-4) like discribed here:
sudo pbp-fwupdater step-1
sudo poweroff
sudo pbp-fwupdater step-2 ansi
sudo poweroff
sudo pbp-fwupdater flash-kb firmware/default_ansi.hex //pulled files from github
Touchpad works better as before, BUT I have the issue that my rigth touchpad button doesn’t work anymore. I cannot open a contextmenu as example
I don’t find any hints or issue reports on that. I repeated the update two times with no change. Update runs without error messages.
How should I proceed?
Fabby
2
Welcome to Manjaro!
Why don’t you raise an issue with the developers of the updater, because they know much more what’s going on than we do…
As to why, please read this:
Especially the “Upstream/downstream” section…
