I can disable bluetooth with rfkill block bluetooth but cannot enable it with rfkill unblock bluetooth. I can enable it with Manjaro settings though.
Here’s the output of rfkill list | grep -A 2 bluetooth after running rfkill block bluetooth :
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Here’s the output of rfkill list | grep -A 2 bluetooth after running rfkill unblock bluetooth :
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
But bluetooth is not enabled at this time. Here’s the output after enabling it from KDE settings :
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Exactly the same. I’m unable to figure out what’s exactly happening. Please help.
inxi -Fazy
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 dm: GDM 3.38.2.1, SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
date: 10/30/2017
ID-1: BAT1 charge: 42.3 Wh condition: 42.3/42.3 Wh (100%) volts: 13.2/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Full
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
Speed: 838 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 838 2: 865 3: 875
4: 847 5: 847 6: 800 7: 800 8: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917 class ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d class ID: 0302
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 04f2:b5d6 class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 115 s-size: 424x238mm (16.7x9.4")
s-diag: 486mm (19.1")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71 class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus ID: 03:00.0 chip ID: 8086:095a class ID: 0280
bus ID: 1-4:3 chip ID: 8087:0a2a class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 1.03 TiB used: 581.84 GiB (55.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0006 scheme: GPT
ID-1: / raw size: 50 GiB size: 48.72 GiB (97.43%) used: 26.37 GiB (54.1%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 277 MiB size: 276.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw size: 60.87 GiB size: 59.67 GiB (98.02%)
used: 31.19 GiB (52.3%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
Kernel: swappiness: 5 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 8.1 GiB used: 8.2 MiB (0.1%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 46.0 C mobo: 29.8 C
Processes: 349 Uptime: 31m wakeups: 2 Memory: 7.69 GiB
used: 5.34 GiB (69.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 2097 pacman: 2096 lib: 469 flatpak: 1 Shell: fish v: 3.1.2
running in: server inxi: 3.3.01
