So, I installed RetroArch 1.9.14 from the Official Repositories (community) + all optional dependencies.
When I start RetroArch it’s window shows up and everything works nicely (tried ozone & XMB menus) - except that the window has no border so I can’t move or resize it easily with the mouse.
Never had an issue like that under Ubuntu GNOME, so not sure what to do here? How can I restore/add the border?
Okay, since there’s been no reply in nearly a week, maybe someone can answer me a different question:
Is this known behaviour? Am I the only one that experiences this or does everyone? Is this Manjaro/GNOME exclusive?
I use Retroarch on Manjaro Cinnamon and it has a border.
It may just be a simple setting. Can you go into RetroArch/Settings/Video/Window Mode/
Then look for “Show Window Decorations” and if it is not set to on, turn it on.
Thank you for your suggestion, but window decorations are on by default - and toggling them did not restore the border.
I played around with the settings a bit and changing the video driver to xvideo/x11 actually brought up a bordered window! … which was unfortunately completely blank, requiring me to manually change back the configuration file
sdl2 also re-enables the border - but forces the rgui menu driver, which is not optimal.
No other video related settings that I tried seem to affect the border at all. Well, I guess I’ll try asking on the RetroArch Discord for help.
Oh well, worth a shot. Sorry, that was all I could think of to help. I rarely play around inside retroarch or even use it in window mode, I write scripts for each game that load the game up and close everything when you exit the game. If I need to tweak something while in the game I hit the hotkey to enter into it in full screen mode find the setting and go back to the game.
I find it great for organisation and especially for the children, who can see an icon click it and play the game. Same as what I have always done with say Dosbox or PCSX2 games as well. I find it easier than going into Retroarch and loading a core and a game from inside.
Thanks to a tip from the RetroArch Discord, I figured it out!
Apparently, there is some incompatibility between RetroArch and Wayland, the default window system for GNOME. Restarting with XORG/X11 fixed the issue!
