Resume from suspend results in system shutdown
I recently re-install Manjaro Gnome 22.1.0 on my Desktop PC. Then did a BIOS update.
Now I am experiencing a weird issue where my system shuts down quickly upon resume from suspend. I reset my BIOS settings to default before and after I did update. Able to wake up PC by moving the mouse, it just shuts down on it’s own afterwards. Was working previously.
Version of my BIOS prior to the upgrade was F36. I am now on F37b. ( X570 I AORUS PRO WIFI )
This is my inxi output:
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
    root=UUID=Removed rw rootflags=subvol=@ quiet
    splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop System: Gigabyte product: X570 I AORUS PRO WIFI v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 I AORUS PRO WIFI serial: <superuser required>
    UEFI: American Megatrends LLC. v: F37b date: 03/23/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX Anywhere
    2S serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 31.27 GiB used: 3.28 GiB (10.5%)
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201025
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2687 high: 3700 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2800 7: 3700 8: 3700 9: 2200 10: 3700 11: 2200
    12: 2200 13: 2200 14: 2800 15: 2200 16: 2200 17: 3700 18: 3700 19: 2200
    20: 2200 21: 2200 22: 2200 23: 3700 24: 2200 bogomips: 177652
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ZOTAC
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.0
    chip-ID: 10de:2504 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: DP-4 res: 2560x1440 dpi: 65024 size: 1x1mm (0.04x0.04")
    diag: 1mm (0.06") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
    3060/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA GA106 High Definition Audio vendor: ZOTAC
    bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-2:3
  Local Storage: total: 4.09 TiB used: 39.77 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 47.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT4000MX500SSD1
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 045 scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
    used: 39.77 GiB (8.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: Removed
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: Removed
  ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-4: /swap raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-5: /var/cache raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-6: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%)
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swap/swapfile
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 1-1:2 info: Integrated Express IT8297 RGB LED Controller
    type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
  Device-2: 1-2:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-5:2 info: Generic Io type: Abstract (modem),CDC-Data
    driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 1209:1776 class-ID: 0a00 serial: <filter>
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Holtek USB Keyboard type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
    power: 100mA chip-ID: 04d9:a01b class-ID: 0300
  Hub-6: 5-4:3 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
  Device-1: 5-4.1:4 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 5-4.3:6 info: ENE AGON3 Light FX Device type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0cf2:7750 class-ID: 0300 serial: <filter>
  Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-8: 6-4:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
    chip-ID: 05e3:0620 class-ID: 0900
  System Temperatures: cpu: 49.9 C mobo: 43.0 C gpu: nvidia temp: 52 C
  Processes: 444 Uptime: 2h 31m wakeups: 6 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1411 pm: pacman pkgs: 1401 libs: 358 tools: gnome-software,pamac
  pm: flatpak pkgs: 10 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.26
If useful mine is a System76 Thelio model.
How can I prevent my computer from shutting down when it wakes from Suspend?
That is not going to work as is small. Swap file or partition needs to be at least equal to the RAM, or at most double the RAM the system has. See Swap - ArchWiki
I also recommend to go trough Power management/Suspend and hibernate - ArchWiki
Please provide a log when it last happened.
The swap file is much too small but for suspend, it’s no problem.
The system installer (Calamares ?) chose the size of my swap file. I selected to use a swap file instead of a partition when I went through and installed Manjaro. Thought the swap file changed in size on-the-fly as needed? The computer suspends to ram but shuts down when I attempt to wake it.
How do I provide the relevant log requested by @mithrial ? Which one should I get and how?
I have been reading through the two ArchWiki topics you linked.
No, it will have one size as you define it. Maybe some related issue with calamares with default size as discussed here Swapfile - increase standard size from 512MB to ... · Issue #1722 · calamares/calamares · GitHub
There is the swapspace in AUR but i do not think is dynamically resizing, but rather creating more swapfiles of certain size. Never tested it as per their conclusion “not a good choice for systems that need to remain responsive at all times”, but you can learn more about it here. Swapspace — swap file manager for Linux
I prefer to use zram-generator
I went back to my previous BIOS version F36 . Suspend to ram works again. Perhaps the newer BIOS version has an issue I should report?
Will attempt to enlarge my swap file.
Please don’t mark my thread as solved yet. Will probably need further help. I don’t want to stay on older BIOS forever.
