Continuing the discussion from Keepassxc not launching. Bus error (core dumped):
NOTE: My inxi output is at the end
@winnie @Mirdarthos
UPDATE
I have a snapshot created at 1/5/2022 with a kernel version of 5.13
It’s basically a snapshot of my entire system however I can’t restore it because I have a lot of new files in multiple directories.
Is there a way to restore it and keep my new files?
I had an idea of creating a snapshot for the current system. Then I’m going to copy all the folders in my root directory except the home directory (So thats /bin /lib etc…). And copy all of them to my current system and replace all of them. (Although I think this is gonna cause a LOT of problems )
Maybe I can copy my entire home directories to a flash drive then restore the snapshot? I don’t have a flash drive that big so I’ll have to cut corners. So if I restore the snapshot then update how can I prevent the same problem from happening again.
inxi output:
Kernel: 5.13.19-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=45f6ee2f-bad8-474d-9148-ebcf4e4f6b22 rw quiet apparmor=1
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: LENOVO product: 5016A26 v: ThinkPad L520
Mobo: LENOVO model: 5016A26 serial: <superuser required> BIOS: LENOVO
v: 8GET34WW (1.11 ) date: 06/13/2011
ID-1: BAT1 charge: 30.9 Wh (100.0%) condition: 30.9/47.5 Wh (65.1%)
volts: 12.5 min: 10.8 model: SANYO 42T4763 type: Li-ion serial: <filter>
status: full
RAM: total: 3.68 GiB used: 1.51 GiB (41.1%)
RAM Report:
Info: model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1063 high: 1241 min/max: 800/2100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 1241 3: 1024
4: 1192 bogomips: 16769
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel arch: Gen6 process: Intel 32nm
built: 2011 ports: active: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) Integrated Camera
type: USB driver: uvcvideo bus-ID: 2-1.4:3 chip-ID: 05c8:0317 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: LVDS-1 model: Lenovo 0x40b1 built: 2010 res: 1600x900 hz: 60
dpi: 118 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1600x900
Message: Unable to show GL data. Required tool glxinfo missing.
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0085 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Local Storage: total: 298.06 GiB used: 157.15 GiB (52.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9320328CS
size: 298.06 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SC1A scheme: MBR
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7710H rev: 1.S0
dev-links: cdrom
ID-1: / raw-size: 298.06 GiB size: 292.32 GiB (98.07%)
used: 157.15 GiB (53.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 45f6ee2f-bad8-474d-9148-ebcf4e4f6b22
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:5 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0000:3825 class-ID: 0301
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.4:3
info: Cheng Uei Precision Industry (Foxlink) Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA
System Temperatures: cpu: 60.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 733
Processes: 190 Uptime: 34m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1485 pacman: 1467 lib: 416 flatpak: 12 snap: 6 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.19
