Restore previous session
Hi,
I would like to restore previous session automatically. Is it possible ?
Thanks :upside_down_face:
Hello, welcome to the forum!
Open the Settings Manager, got to “Session and Startup,” and check the box labeled “automatically save session on logout.”
Thanks,
i did it but it doesn’t work…i don’t know why.
Capture d’écran_2020-08-30_09-06-41|690x426
You have a similar checkbox with the Logoff button (Where you have Logout, Shutdown, reboot, …).
I remember they work somehow ‘together’.
But I can’t recall in which order precisely I had to tick them.
Thank you.
I don’t have this option on logout window :
IMG_20200830_121230|178x500
When I log out, the session is saved but not on restart and shut down, what I would like.
Found !
On “Session and Startup,” uncheck “automatically save session on logout.” So, the option “save session for future logins” on the log out window appears.
Thanks all.
