Precondition: Dual-boot Windows 11 + Ubuntu 22.04
What was done: Re-install to the Manjaro with / and /home partitions recreation.
Original EFI partition mounted to the /boot/efi according to the https://wiki.manjaro.org/index.php/UEFI_-_Install_Guide
Current state: In the UEFI in the Secure boot configuration I have OS Type - Other OS, that according to the documentation is equal to OFF, but by some reason also displays as “Enabled” on the screen in the state line. At the same time for booting has options:
- ubuntu (ssd name) - leads to nothing that makes sense;
- ssd name - leads to Grub that just prints welcome message and starts Manjaro;
- Windows (ssd name) - leads to window
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,MOUNTPOINT,PARTTYPENAME ✔
PATH PTTYPE PARTTYPE FSTYPE MOUNTPOIN PARTTYPENAME
/dev/nvme0n1 gpt
/dev/nvme0n1p1 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/nvme0n1p2 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat /boot/efi EFI System
/dev/nvme0n1p3 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved
/dev/nvme0n1p4 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/nvme0n1p5 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/nvme0n1p6 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/nvme0n1p7 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 / Linux filesystem
/dev/nvme0n1p8 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 /home Linux filesystem
inxi
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=da2b81da-da01-4475-9d84-407e836f9a9f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: PRIME H370-PLUS v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2501
date: 11/10/2020
System RAM: total: 16 GiB available: 15.54 GiB used: 2.89 GiB (18.6%)
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
vme x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Local Storage: total: 931.51 GiB used: 10.22 GiB (1.1%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 9.98 GiB (20.4%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: da2b81da-da01-4475-9d84-407e836f9a9f
used: 32.5 MiB (33.8%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: A453-3FF6
ID-3: /home raw-size: 50 GiB size: 48.91 GiB (97.82%)
used: 206.1 MiB (0.4%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: eddca266-fb4c-460b-a766-b059888efca0
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: \xd0\x92\xd1\x96\xd0\xb4\xd0\xbd\xd0\xbe\xd0\xb2\xd0\xbb\xd0\xb5\xd0\xbd\xd0\xbd\xd1\x8f
uuid: 4686521486520539
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 98.8 GiB fs: ntfs label: N/A
uuid: C06C5DCC6C5DBE3A
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 596 MiB fs: ntfs label: N/A
uuid: 0E46006A460054BD
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 731.5 GiB fs: ntfs label: N/A
uuid: A48ECD628ECD2E1C
Processes: 288 Uptime: 17m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1159 libs: 343 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
efibootmgr gives a warning message. I suppose because of the issue described in the https://forum.manjaro.org/t/system-bios-update-efi-variables-are-not-supported-on-this-system/146965/3
efibootmgr
EFI variables are not supported on this system.
Goal: Make GRUB be able to see both the Manjaro and Windows 11 with possibility to choose which one to boot.
