Restore default user groups
Hi all,
I made a mistake/typo/whateveryouwannacallit while adding my user to a group, as root.
I ran
usermod -G <groupname> mirdarthos
instead of
usermod -aG <groupname> mirdarthos
mistakenly.
Now, I think I’ve restored everything as it should be. At least, I can work and use my computer without any poroblems. But I just want to make sure and be certain about it.
So, my question is whether there is any command to check if a user belongs to all the default groups, and add it to those that he/she/it isn’t a member of?
Alternatively, can you please post a list of the default user groups, so that I can manually double check them?
man id
I can only list the groups my account here is a member of. Things may differ at your end, depending on the software you’ve installed.
groups=1000(aragorn),3(sys),90(network),98(power),990(optical),991(lp),998(wheel)
Thank you @Aragorn.
This is exactly what I was looking for!
