Hi! New user here, switched from Win11 to Manjaro Gnome about two days ago. Fresh install.
Everything works mostly right, did my updates. I’m using propietary NVIDIA drivers, and two monitors. I setup a VM for Win7 to play some old games, that works mostly right, the mouse pointer is a bit laggy but I don’t mind.
Anyway, my issue is that I can’t do anything else with the proper response time whenever I’m running a game on one monitor and a youtube video on the other. If I switch windows, for example from the game to Firefox, and I try to scroll down it’s slow and barely responsive. Still the video playback works, but it starts looking choppy.
I don’t know what to expect from Manjaro tbh, I just have the Win11 frame and this whole setup used to work flawlessly over there, but I’m here to stay and want to setup base Arch when I’m comfortable in the future. I’m running Proton with Steam, switching to GE or 8.0 doesn’t make any difference, games run great.
Here’s my system’s info:
inxi -v8azy 22 ✘
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a3416e91-311f-4af8-b939-22bc0f6e8e62 rw quiet splash apparmor=1
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.70 date: 06/29/2021
System RAM: total: 24 GiB available: 23.39 GiB used: 6.27 GiB (26.8%)
Array-1: capacity: 128 GiB slots: 4 modules: 3 EC: None
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF3600C17D4/8GX serial: <filter>
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 3981 high: 4775 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4771 2: 3858
3: 3819 4: 3818 5: 3821 6: 3819 7: 3820 8: 3819 9: 4775 10: 3855 11: 3819
12: 3817 13: 3958 14: 3819 15: 3798 16: 4320 bogomips: 121637
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] driver: nvidia
v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 2b:00.0
chip-ID: 10de:2489 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 3280x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 pos: primary,top-right res: 1920x1080 hz: 144 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: bottom-l res: 1360x768 hz: 60 dpi: 85
size: 406x229mm (15.98x9.02") diag: 466mm (18.35") modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2b:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 931.51 GiB used: 139.28 GiB (15.0%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 613000WD temp: 44.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 139.28 GiB (15.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a3416e91-311f-4af8-b939-22bc0f6e8e62
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4608-8909
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5:3 info: SINOWEALTH Wired Gaming Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 1-8:4 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c91 class-ID: 0300
serial: <filter>
Device-3: 1-9:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 65.5 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1386 libs: 472 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirror.seahost.de/manjaro/stable/$repo/$arch
2: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
3: https://repos.silknet.com/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 421
1: cpu: 135%
command: Z:\home\naru\.local\share\Steam\steamapps\common\Yog-Sothoth's
pid: 27299 mem: 986.2 MiB (4.1%)
2: cpu: 27.6% command: firefox pid: 2407 mem: 890.4 MiB (3.7%)
3: cpu: 8.4% command: gnome-shell pid: 1373 mem: 427.9 MiB (1.7%)
4: cpu: 4.8% command: firefox pid: 2710 mem: 505.2 MiB (2.1%)
5: cpu: 4.6% command: firefox pid: 2842 mem: 113.3 MiB (0.4%)
Memory top: 5 of 421
1: mem: 986.2 MiB (4.1%)
pid: 27299 cpu: 135%
2: mem: 890.4 MiB (3.7%) command: firefox pid: 2407 cpu: 27.6%
3: mem: 544.5 MiB (2.2%) command: steamwebhelper pid: 6408 cpu: 3.5%
4: mem: 505.2 MiB (2.1%) command: firefox pid: 2710 cpu: 4.8%
5: mem: 427.9 MiB (1.7%) command: gnome-shell pid: 1373 cpu: 8.4%
Processes: 421 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.35 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.33
Here’s a Conky and System Monitor screenshot while running both the video playback at 1080@60 and the game Yog-Sothoth’s Yard, which is a light 2d game. I don’t see anything alarming, yes my CPU temp is a bit warm but it’s not even reaching 70°. I also noticed that when I click the + to add a new Firefox tab, the tab appears, stutters for a bit trying to grow in size and then I can use it.
Wanted to add, that I tried adding a SWAP file and switching Kernels to 7.x and 5.x and nothing changed. The game runs fine capped @60, I notice screen tearing but the main monitor runs @144 so that’s expected, I think?
