Contetx
I’m currently going over the .pacnew
files.
Issue
Came across the /etc/pam.d/kde
diff that suggests:
- a bunch of whitespace changes that are probably inconsequential
- plus a changes of “system-login” → “system-local-login”
Extra Info
Looking into /etc/pam.d/sddm
I see it referencing system-login
, but I don’t understand the significance of it.
Question
How do I figure out which one I should be using?
Do I stick with “system-login”, or do I go with “system-local-login”.
Can the switch to “system-local-login” lock me off my system?
