Resolution unsupported after log in
When trying to use the video-nvidia drivers, I get an unsupported resolution error after I log in.
Removing the drivers through TTY (Ctrl+ Alt + F3) and installing video-nvidia-470xx fixes the issue, but I’d like to fix the problem with the newer drivers if possible.
Xorg log:
[    18.380] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[    18.380] (II) No input driver specified, ignoring this device.
[    18.380] (II) This device may have been added with another device file.
[    18.380] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[    18.380] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[    18.381] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[    18.381] (II) No input driver specified, ignoring this device.
[    18.381] (II) This device may have been added with another device file.
[    18.381] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[    18.382] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[    18.382] (II) No input driver specified, ignoring this device.
[    18.382] (II) This device may have been added with another device file.
[    18.382] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
System information (on Nouvaeu drivers):
  Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=164c3059-4b4f-4cb1-ab14-dfecba3daa35 rw quiet apparmor=1
    security=apparmor resume=UUID=5a907a0c-2a48-4567-bb87-0ffec0c5f2fa
    udev.log_priority=3
  Desktop: GNOME v: 43.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
  Type: Desktop Mobo: ASUSTeK model: RAMPAGE IV GENE v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 4901
    date: 05/15/2014
  RAM: total: 23.42 GiB used: 2.3 GiB (9.8%)
  Info: model: Intel Core i7-3820 bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 3 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2D (45) stepping: 7 microcode: 0x71A
    L3: 10 MiB desc: 1x10 MiB
  Speed (MHz): avg: 1837 high: 3800 min/max: 1200/3800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3800 2: 1200 3: 1200
    4: 1200 5: 1200 6: 3700 7: 1201 8: 1200 bogomips: 57649
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdtscp
    rep_good sep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GM206 [GeForce GTX 960] driver: nouveau v: kernel
    alternate: nvidia_drm,nvidia non-free: 520.xx+
    status: current (as of 2022-10) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1
    empty: DP-1,DVI-D-1,DVI-I-1 bus-ID: 01:00.0 chip-ID: 10de:1401
    class-ID: 0300 temp: 45.0 C
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Dell SE2717H/HX serial: <filter>
    built: 2018 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.3 Mesa 22.2.3 renderer: NV126 direct render: Yes
  Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
    class-ID: 0403
  Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
  Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: no
  Sound Server-2: PipeWire v: 0.3.59 running: yes
  Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
    driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
    class-ID: 0200
  Local Storage: total: 3.75 TiB used: 3.35 TiB (89.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WDS120G2G0A-00JH30 size: 111.8 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EZEX-00WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
    model: WD Elements 1042 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1016 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
    model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1026 scheme: GPT
  ID-1: / raw-size: 99.59 GiB size: 97.47 GiB (97.87%) used: 81.42 GiB (83.5%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: 164c3059-4b4f-4cb1-ab14-dfecba3daa35
  ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
    used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 16BD-3B4C
  ID-3: /mnt/f5e4e8db-b0d4-4d0a-ad4a-bcfdfdd1fe8d raw-size: 931.51 GiB
    size: 915.82 GiB (98.32%) used: 733.98 GiB (80.1%) fs: ext4 dev: /dev/sdb1
    maj-min: 8:17 label: N/A uuid: f5e4e8db-b0d4-4d0a-ad4a-bcfdfdd1fe8d
  ID-4: /run/media/bys/Taffer raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 888.34 GiB (95.4%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Taffer
    uuid: 1ADC8962DC893951
  ID-5: /run/media/bys/Templar raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.69 TiB (92.8%) fs: ntfs dev: /dev/sdd1 maj-min: 8:49 label: Templar
    uuid: B21C95CB1C958ACD
  ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 5a907a0c-2a48-4567-bb87-0ffec0c5f2fa
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:3 info: USB GAMING MOUSE type: Mouse,Keyboard
    power: 100mA chip-ID: 30fa:1230 class-ID: 0301
  Device-2: 2-1.3:4 info: Valve Wireless Steam Controller type: Keyboard,HID
    driver: hid-steam,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 28de:1142 class-ID: 0300
  Device-3: 2-1.5:5 info: Wacom PTZ-630 [Intuos3 (6x8)] type: Mouse
    driver: usbhid,wacom interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 300mA
    chip-ID: 056a:00b1 class-ID: 0301
  Device-4: 2-1.8:6 info: Microsoft Comfort Curve Keyboard 3000
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 1.5 Mb/s power: 100mA chip-ID: 045e:0780 class-ID: 0300
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Device-1: 4-1:2 info: Western Digital Elements SE Portable (WDBPCK)
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 1058:1042 class-ID: 0806 serial: <filter>
  Device-2: 4-2:3 info: Western Digital Elements 2621 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
    chip-ID: 1058:2621 class-ID: 0806 serial: <filter>
  Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 32.0 C mobo: 39.0 C gpu: nouveau temp: 45.0 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 0 gpu: nouveau fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.30 gpu: nouveau watts: 20.20
    mV: 900.00
  Processes: 257 Uptime: 6m wakeups: 0 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1890 libs: 518 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.23
No you did not actually
Meaning you use the nouveau aka open source drivers.
Please share from terminal
mhwd -li
ls /etc/X11/*
and
cat /etc/X11/mhwd.d/nvidia.conf
Apologies for the confusing post.
In order to gain access to my desktop (and make the post) I had to remove the drivers as stated and at this point I collected the information.
I finally have some time to jump between installing and removing the drivers, so the following logs will make a little more sense. :man_bowing:
Install log for video-nvidia drivers:
Waiting for user input...
Starting
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-utils dependency
Packages (7) egl-wayland-2:1.1.11-2  eglexternalplatform-1.1-2  libxnvctrl-520.56.06-1  lib32-nvidia-utils-520.56.06-1  linux515-nvidia-520.56.06-9  linux60-nvidia-520.56.06-13  nvidia-utils-520.56.06-2
Total Installed Size:  889.30 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing eglexternalplatform...
installing egl-wayland...
installing libxnvctrl...
installing nvidia-utils...
If you run into trouble with CUDA not being available, run nvidia-modprobe first.
If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
Optional dependencies for nvidia-utils
    xorg-server-devel: nvidia-xconfig
    opencl-nvidia: OpenCL support
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
    lib32-opencl-nvidia
installing linux515-nvidia...
installing linux60-nvidia...
(1/8) Creating system user accounts...
(2/8) Reloading system manager configuration...
(3/8) Reloading device manager configuration...
(4/8) Arming ConditionNeedsUpdate...
(5/8) Updating module dependencies...
(6/8) Updating Kernel initcpios for Nvidia-DRM...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.78-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
  -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
cpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux517.preset: 'default'
  -> -k /boot/vmlinuz-5.17-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.17-x86_64.img
==> ERROR: '/lib/modules/5.17.15-1-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux517.preset: 'fallback'
  -> -k /boot/vmlinuz-5.17-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.17-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
  -> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> Starting build: 6.0.8-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
  -> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64-fallback.img
error: command failed to execute correctly
(7/8) Reloading system bus configuration...
(8/8) Updating the desktop file MIME type cache...
nvidia-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux515-nvidia: install reason has been set to 'explicitly installed'
linux60-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia
Done ...
Output for mhwd -li
e[1me[31m> e[mInstalled PCI configs:
          video-nvidia            2021.11.04               false            PCI
           video-linux            2018.05.04                true            PCI
e[1me[31mWarning: e[mNo installed USB configs!
Output for ls /ect/X11/*
/etc/X11/mhwd.d:
nvidia.conf
nvidia.conf.backup
nvidia.conf.nvidia-xconfig-original
/etc/X11/xinit:
xinitrc
xinitrc.d
xserverrc
/etc/X11/xorg.conf.d:
00-keyboard.conf
50-synaptics.conf
90-mhwd.conf
Output for cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 520.56.06
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
	Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Please remove that kernel as is EOL = End OF Life.
Remove that driver, is interfering with the nvidia one.
Do this
Thanks for the prompt reply.
It seems like 5.17-x86_64 was a ghost entry, since I had removed it and it isn’t listed as an installed kernel. Followed the steps here to clean it up.
Will install drivers as suggested and report back.
After following the removal steps, I’m unable to reach the log in screen on video-nvidia drivers. It’s just a black screen instead.
Reverting to video-nvidia-470xx still works.
Supposing you are installing them with
sudo mhwd -i video-nvidia-470xx
and the driver is actually used, then you can continue using it. Not much beneficiary changes for GeForce GTX 960 between those drivers version … i have the same GPU.
Thanks for the assistance.
It seems like DXVK is no longer compatible with video-nvidia-470xx drivers, so I’m running into a lot of trouble running games that previously worked.
Anything else I might try to get the 500xx drivers to work?
I don’t game, so no idea about the DXVK compatibility of the video-nvidia-470xx drivers. I use the video-nvidia as i need CUDA for Blender, never had issues with any of the drivers tho.
In your case, while using the video-nvidia-470xx drivers, do you get a different entry in your /etc/X11/mhwd.d/nvidia.conf in this Section?
Compared to mine for example
Section "Monitor"
    VendorName     "LG Electronics"
    ModelName      "LG Electronics W2253"
    HorizSync       30.0 - 83.0
    VertRefresh     56.0 - 75.0
    Option         "DPMS"
EndSection
But you are connecting via HDMI according to this
And to be honest i would switch to DVI-I-1 if i was you, especially because of this
To me there is something off about that cable compatibility …
As mentioned before, i also use early KMS, but that only helps with wayland when i want to test it.
Other than that, i use a fixed config for dual display, and it looks like this since forever:
    Screen      0  "Screen0" 0 0
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BoardName      "GeForce GTX 960"
    Option         "TripleBuffer"  "On"
    Option  "ConnectToAcpid"    "Off"
    Option         "Coolbits" "31"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "DVI-I-1: 1920x1080_60 +0+0 {ForceCompositionPipeline=On}, DVI-D-0: 1920x1080_60 +1920+0 {ForceCompositionPipeline=On}"
    Option         "SLI" "Off"
    Option         "MultiGPU" "Off"
    Option         "BaseMosaic" "off"
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
Thanks for the prompt reply. Currently, the output of /etc/X11/mhwd.d/nvidia.conf on video-nvidia-470xx is:
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
I’ll replace the HDMI cable with a DVI-I-1 cable, but is there anything else I need to change or will it auto detect on restart?
I’ve changed the cable.
Here’s the output of inxi --admin --verbosity=7 --filter --width:
    udev.log_priority=3
    date: 05/15/2014
  RAM: total: 23.42 GiB used: 2.93 GiB (12.5%)
  Speed (MHz): avg: 2571 high: 3533 min/max: 1200/3800 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2687 2: 3533 3: 2106
    4: 3440 5: 2877 6: 1396 7: 3135 8: 1401 bogomips: 57652
    xtopology xtpr
    vulnerable
  Device-1: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 470.141.03
    alternate: nouveau,nvidia_drm non-free: 520.xx+
    process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
  Device-2: Microdia Rapoo Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 2-1.7:6 chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: N/A display-ID: :1 screens: 1
  Monitor-1: DVI-I-0 res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 470.141.03 renderer: NVIDIA GeForce GTX
    960/PCIe/SSE2 direct render: Yes
    driver: snd_hda_intel bus-ID: 2-1.7:6 v: kernel bus-ID: 00:1b.0
    chip-ID: 0c45:636b chip-ID: 8086:1d20 class-ID: 0102 class-ID: 0403
    serial: <filter>
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
  Device-3: Microdia Rapoo Camera type: USB driver: snd-usb-audio,uvcvideo
    class-ID: 0200
  Local Storage: total: 3.75 TiB used: 3.38 TiB (90.1%)
    scheme: GPT
  ID-1: / raw-size: 99.59 GiB size: 97.47 GiB (97.87%) used: 82.51 GiB (84.7%)
    uuid: 16BD-3B4C
    size: 915.82 GiB (98.32%) used: 723.01 GiB (78.9%) fs: ext4 dev: /dev/sdb1
    used: 923.74 GiB (99.2%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Taffer
  Device-4: 2-1.7:6 info: Microdia Rapoo Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
  Device-5: 2-1.8:7 info: Microsoft Comfort Curve Keyboard 3000
  System Temperatures: cpu: 35.0 C mobo: 37.0 C gpu: nvidia temp: 38 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 0 fan-3: 0 gpu: nvidia fan: 30%
  Processes: 265 Uptime: 6m wakeups: 0 Init: systemd v: 251 default: graphical
  pkgs: 1877 libs: 512 tools: gnome-software,pamac pm: flatpak pkgs: 0
And I still get the same output in /etc/X11/mhwd.d/nvidia.conf
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Still resolution unsupported?
It should be detected at the install of the drivers and when the config file is generated automatically.
By just changing the cable the file itself will not regenerate.
It can be taken also from Nvidia X Server Settings, but you need to access it, hence log into Desktop Session, and copy it from there.
By default Nvidia X Server settings will try to create /etc/X11/xorg.conf - but that is not ok to be present because Manjaro uses MHWD and needs to be in /etc/X11/mhwd.d/nvidia.conf - but you can Preview the Settings file and only copy that part …
Sometimes you can make use of nomodeset kernel boot parameter to boot without a config file, but it depends.
I’ve reinstalled my drivers to see whether that does the trick, but the output in /etc/X11/mhwd.d/nvidia.conf remains the same.
The preview through nvidia-settings is the following:
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    ModelName      "Dell SE2717H/HX"
    VertRefresh     56.0 - 76.0
    Option         "DPMS"
EndSection
So I just need to replace the monitor section in /etc/X11/mhwd.d/nvidia.conf with the above preview information?
I’ve also noticed a slight degradation of the image quality when switching to DVI. Think that’s the reason why I chose the HDMI cable.
Thanks for the help!
Copying the monitor information into the file worked. I was getting a frequency out of range error, since the screen can go up to 75hz (AMD FreeSync).
With the new drivers that is what has been giving me the out of sync error. It works at 75hz on the 470xx drivers for some reason though.
Is there a way of limiting the refresh rate?
When I remove the VGA to DVI cable, I get an out of sync error because the HDMI output auto selects 75hz. I’ve tried setting it in nvidia-settings, but it still defaults to 75hz.
Yes, if you look at my config, i have this values on my Screen Section:
That will set the refresh rate to 60 (in my case) and i can’t make mistakes later.
But probably your monitor is set from its menu to Auto …
That with an AMD GPU, but on Nvidia that is the G-Sync, but our GPU model does not support that, only the Sync to VBlank.
I’ve set the refresh rate to 60hz in nvidia-settings, but I still get out of sync when I remove the VGA cable. My /etc/X11/mhwd.d/nvidia.conf currently looks like:
# nvidia-settings:  version 520.56.06
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
EndSection
Section "Monitor"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BoardName      "NVIDIA GeForce GTX 960"
    Option         "NoLogo" "1"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-1"
    Option         "metamodes" "HDMI-0: 1920x1080_60 +0+0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
EndSection
Would changing the VertRefresh 56.0 - 76.0 to VertRefresh 56.0 - 60.0 remove the 75hz option?
I don’t suggest that because then you get into different issue. You can set for each port the fixed layout as you did for HDMI, as i did for my two monitors, and is not a problem that is not connected some monitor to that port.
Okay, thanks for all the help. :man_bowing:
If all works as you wanted, then all good!
Cheers!
