Initially it did not detect my second monitor, until I installed the nvidia drivers. With drivers installed it detected the monitor but at a 1024x768 resolution, when it should be capable of 1920x1080.
I removed the nvidia drivers and installed the nvidia-intel-hybrid hoping it would fix it.
I have come across many similar threads, with no success on solving this issue any help would be appreciated!
Here’s what I get with xrandr:
Screen 0: minimum 8 x 8, current 2944 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 60.00*+
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 connected 1024x768+1920+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*+
1600x900 59.82
1400x900 59.88
1368x768 59.88 59.85
1280x800 59.91 59.81
1280x720 59.86 59.74
1024x576 59.90 59.82
960x540 59.82 59.63
864x486 59.92 59.57
800x600 72.19 60.32 56.25
800x450 59.82
700x450 59.88
684x384 59.88 59.85
640x480 59.94
640x400 59.98 59.88
640x360 59.86 59.83
512x384 60.00
512x288 60.00 59.92
480x270 59.82 59.63
432x243 59.92 59.57
400x300 72.19
320x240 60.05
DP-1 disconnected (normal left inverted right x axis y axis)
VGA-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-3 disconnected (normal left inverted right x axis y axis)
I am working on going through the wiki article you had linked. I created the newmode like the wiki suggests however I get this error when using addmode :
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 60
Current serial number in output stream: 61
Is your second monitor fully compatible with digital only signals? While the first connection DVI-I-1 sends digital+analog, DVI-D-0 only send digital signals. Can you switch the connectors and see if this works then?
I usually have both DVI ports on the graphics card connected and running my monitors.
I tried switching the DVI ports, and the troublesome monitor still was not being recognized. I even tried hooking up to the integrated graphics card DVI, and it did not recognize the monitor.
Found an HDMI port on the graphics card and it recognized the monitor right away. Perhaps there is a better fix (I would like to have them both on DVI), but I can use it like this for my needs.
