All resolution worked good in Manjaro until I added a user to bumblebee group. Now the resolution is 960x540
Please help.
Please help.
How did you do that?
That would not affect screen resolution anyway, but from what i see, you had that issue before
Was that conclusive somehow after 171 comments or not and it does not help now?
The best resource for troubleshooting for all this is here Bumblebee - ArchWiki
That was the first thing I did.
This is another problem. Finally in the previous error the solution was a clean installation.
Right now, the only thing I changed was add my user to bumblebee group and reboot.
Until I did that, the resolution was fine and there was no problem with drivers.
Can you help me, please?
Also, I follow the instructions in Bumblebee Wiki as you say, but, after apply ‘gpasswd -a my_user bumblebee’ and reboot, the resolution changes to 960x540.
But you enabled the bumblebeed.service ?
systemctl enable bumblebeed.service
Yes…
● bumblebeed.service - Bumblebee C Daemon
Loaded: loaded (/usr/lib/systemd/system/bumblebeed.service; enabled; preset: disabled)
Active: active (running) since Wed 2022-11-09 09:13:30 -03; 34s ago
Main PID: 383 (bumblebeed)
Tasks: 1 (limit: 19077)
Memory: 1.5M
CPU: 13ms
CGroup: /system.slice/bumblebeed.service
└─383 /usr/bin/bumblebeed --use-syslog
nov 09 09:13:30 siegfried-nb systemd[1]: Started Bumblebee C Daemon.
nov 09 09:13:33 siegfried-nb bumblebeed[383]: /usr/bin/bumblebeed 3.2.1-2017-02-27-Format:%h$ started
Can you help me @anon89812132 ?
Not much. Not without going again, step by step and asking what you did from the arch wiki, or on the other topic.
You should only do what is necessary and suited for your particular hardware. Before adding the user to bumblebee group, all was working fine?
But I assure you, I only add my user to bumblebee group and before that it was function with correct resolution and working fine. I only added my user in order to change custom set and provide better performance in others applications selecting NVIDIA GPU.
… But… I have 960x540… is a preset config?
Can you help me, @anon89812132 ?
mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
mhwd -l ✔
> 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation:
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
Can anyone help me, please @anon89812132 ? @brahma ?
sorry, but i really have no idea with these bumblebee drivers…
OK man. Thanks for your time.
Right, so what do you have in
ls /etc/X11/*
cat /etc/X11/xorg.conf
cat /etc/X11/xorg.conf.d/20-intel.conf
cat /etc/bumblebee/xorg.conf.nvidia
Please, help me @anon89812132
ls /etc/X11/* ✔
/etc/X11/xorg.conf /etc/X11/xorg.conf.backup /etc/X11/xorg.conf.nvidia-xconfig-original
/etc/X11/mhwd.d:
intel.conf nvidia.conf
/etc/X11/xinit:
xinitrc xinitrc.d xserverrc
/etc/X11/xorg.conf.d:
00-keyboard.conf 30-touchpad.conf 90-mhwd.conf
~ cat /etc/X11/xorg.conf ✔
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.154 (dvs-builder@U64-E08-26-1) Wed Jun 22 04:41:13 UTC 2022
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
~ cat /etc/X11/xorg.conf.d/20-intel.con ✔
cat: /etc/X11/xorg.conf.d/20-intel.con: No such file or directory
~ cat /etc/bumblebee/xorg.conf.nvidia 1 ✘
## Generated by mhwd - Manjaro Hardware Detection
Option "AutoAddDevices" "false"
EndSection
Section "ServerFlags"
Option "IgnoreABI" "1"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "NoLogo" "true"
Option "UseEDID" "false"
Option "ConnectedMonitor" "DFP"
EndSection
Bumblebee is no longer maintained. Remove video-hybrid-intel-nvidia-390xx-bumblebee and install video-nvidia-390xx instead.
See:
This is a support forum. We already know you need help.
That’s quite enough of that. The kind people here are volunteers and will respond if they can help and when they have time. The more information you provide increases the chances of that. Help us help you. Please see [HowTo] Request support
Please do not add multiple replies in a row. Instead, edit your previous post if no one has responded yet. See the Forum Rules - Manjaro
OK @Yochanan, my apologies. Manjaro Stuff does a great job in order to assist users.
But all attempts to manipulate nvidia-390xx result in a disaster. Only bumblebee works.
And I only added my user to bumblebee group, after that, the resolution change to 960x540 and I’m stuck on this resolution.
…ok, as @Yochanan said it is no longer supported. But I remenber there was a hack to make it run.
You need to append the following content
Option "ignoreABI" "true"
EndSection
at the end of your
…should look like this
EndSection
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:01:00:0"
EndSection
EndSection
hope that helps
cheers
What video card do you have? How is it we still do not know that at this point? Please post the output of:
inxi -Gazy
inxi -Gazy ✔
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: eDP-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0416
class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 750M] vendor: Lenovo driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: speed: Unknown lanes: 63 link-max:
gen: 5 speed: 32 GT/s bus-ID: 01:00.0 chip-ID: 10de:0fe4 class-ID: 0300
Device-3: Realtek Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 0bda:58b9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: intel unloaded: nvidia dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 960x540 s-dpi: 96 s-size: 253x142mm (9.96x5.59")
s-diag: 290mm (11.42")
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x033a built: 2011
res: 960x540 hz: 60 dpi: 72 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct render: Yes
It was:
cat /etc/bumblebee/xorg.conf.nvidia ✔ 35s
EndSection
EndSection
Section "Device"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
I will change it and reboot.
@banjo Not working the correct resolution with that, still stuck on 960x540
You should be able to use video-hybrid-intel-nvidia-470xx-prime. Have you tried installing that?
No, every time I install propietary video driver, the system installs video-hybrid-intel-nvidia-390xx-bumblebee, never video-hybrid-intel-nvidia-470xx-prime.
¿Can you guide me in order to install video-hybrid-intel-nvidia-470xx-prime?
Remove video-hybrid-intel-nvidia-390xx-bumblebee first, then manually install it.
