I had some key issues, so I reset everything on my system as follows, which I hope is right, otherwise please correct me.
sudo rm -R /etc/pacman.d/gnupg/
sudo rm -R ~/.gnupg
sudo rm -R /root/.gnupg/
sudo gpg --refresh-keys
sudo pacman-key --init
sudo pacman-key --populate manjaro
sudo pacman-key --populate archlinux
sudo pacman-key --refresh-keys
sudo pacman -Syyu
However, if I execute gpg --homedir /etc/pacman.d/gnupg --list-keys, I get
gpg: WARNING: unsafe ownership on homedir '/etc/pacman.d/gnupg'
gpg: Note: trustdb not writable
/etc/pacman.d/gnupg/pubring.gpg
How can I solve that? And did I do everything right in principle so that in the end everything is consistent and clean?
The items 4. and 6. are new, thank you, but what about sudo rm -R ~/.gnupg and sudo gpg --refresh-keys? I guess these commands don’t contribute.
well this is how i have saved it, if i have keyring errors, these commands should fix your issue…
Unfortunately, I still get the warning. And what is the /root partition all about? I thought / is root.
That is the home directory for the root user, not the root directory.
so you still have keyring issues - cant install/update… or the only issue is the … gpg: Note: trustdb not writable… ?
The issue is
It seems that I can install and update.
i tried running the command and get the same
so its probably how it should be
Thanks. This helped alot!
