Reset mouse config to default
Hi,
I had mouse acceleration so I googled and found a command online and I entered it into terminal and my mouse acceleration was fixed but now after some time my mouse has got deacceleration! my mouse works fine on windows but bad on linux please help :frowning:
xinput --list-props “Cooler Master Technology Inc. MM710 Gaming Mouse”
Device ‘Cooler Master Technology Inc. MM710 Gaming Mouse’:
Device Enabled (154): 1
Coordinate Transformation Matrix (156): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (336): 0
Device Accel Constant Deceleration (337): 1.000000
Device Accel Adaptive Deceleration (338): 1.000000
Device Accel Velocity Scaling (339): 10.000000
Device Product ID (275): 9494, 303
Device Node (276): “/dev/input/event3”
Evdev Axis Inversion (340): 0, 0
Evdev Axes Swap (342): 0
Axis Labels (343): “Rel X” (164), “Rel Y” (165), “Rel Horiz Wheel” (334), “Rel Vert Wheel” (335), “None” (0), “None” (0)
Button Labels (344): “Button Left” (157), “Button Middle” (158), “Button Right” (159), “Button Wheel Up” (160), “Button Wheel Down” (161), “Button Horiz Wheel Left” (162), “Button Horiz Wheel Right” (163), “Button Side” (329), “Button Extra” (330), “Button Forward” (331), “Button Back” (332), “Button Task” (333), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328), “Button Unknown” (328)
Evdev Scrolling Distance (345): 1, 1, 1
Evdev Middle Button Emulation (346): 0
Evdev Middle Button Timeout (347): 50
Evdev Middle Button Button (348): 2
Evdev Third Button Emulation (349): 0
Evdev Third Button Emulation Timeout (350): 1000
Evdev Third Button Emulation Button (351): 3
Evdev Third Button Emulation Threshold (352): 20
Evdev Wheel Emulation (353): 0
Evdev Wheel Emulation Axes (354): 0, 0, 4, 5
Evdev Wheel Emulation Inertia (355): 10
Evdev Wheel Emulation Timeout (356): 200
Evdev Wheel Emulation Button (357): 4
Evdev Drag Lock Buttons (358): 0
This is all really confusing I dont know how to fix this I just want my mouse back to normal, is there a way I can delete a config file for my mouse just to reset it.
in the gui in settings mouse accelertation is set to 0.
Thanks for any help ;/
Which was…?
I dont know the command, but my mouse has got deacceleration not acceleration ;/
I do remember it has deacceleration in the command somewhere though.
@alastair You need to make a new xorg config file with some options as given here: Mouse acceleration - ArchWiki. Put the file in the following directory: /etc/X11/xorg.conf.d/. It will disable mouse acceleration and then you’ll be able to adjust your mouse speed in the xfce slider.
thanks
title adjusted: Forum Rules - Manjaro
