I have to reset my theme to Dark every time I LogIn or Reboot. Gnome doesn’t remember my preferences after upgrade.
Here is my system information:
inxi -F
Host: ralf-desk Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64
Desktop: GNOME v: 43.3 Distro: Manjaro Linux
Type: Desktop System: HP product: HP ProDesk 400 G4 DM v: N/A
serial: <superuser required>
Mobo: HP model: 83F3 v: KBC Version 07.B4.00 serial: <superuser required>
UEFI: HP v: Q23 Ver. 02.02.04 date: 07/27/2018
Info: 6-core model: Intel Core i7-8700T bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 1600 min/max: 800/4000 cores: 1: 800 2: 2400 3: 800
4: 2400 5: 2400 6: 2400 7: 800 8: 800 9: 800 10: 2400 11: 800 12: 2400
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Display: wayland server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: modesetting dri: iris gpu: i915
resolution: 1920x1080~60Hz
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB
driver: snd-usb-audio
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: PipeWire v: 0.3.65 running: yes
driver: r8169
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: b0:0c:d1:59:0b:00
Local Storage: total: 238.47 GiB used: 33.95 GiB (14.2%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
ID-1: / size: 233.38 GiB used: 33.95 GiB (14.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 36.0 C pch: 42.0 C mobo: N/A
Processes: 280 Uptime: 14m Memory: 15.47 GiB used: 2.47 GiB (16.0%)
Shell: Zsh inxi: 3.3.25
And here are the installed and enabled GNOME-Shell-Extensions:
gnome-extensions list --enabled
BringOutSubmenuOfPowerOffLogoutButton@pratap.fastmail.fm
quick-settings-tweaks@qwreey
custom-accent-colors@demiskp
tiling-assistant@leleat-on-github
launch-new-instance@gnome-shell-extensions.gcampax.github.com
user-theme@gnome-shell-extensions.gcampax.github.com
appindicatorsupport@rgcjonas.gmail.com
dash-to-panel@jderose9.github.com
nightthemeswitcher@romainvigier.fr
pamac-updates@manjaro.org
I have no orphans.
Thank you for your help.
