Feature request to Manjaro Repository - Status of mirrors at https://repo.manjaro.org.
Add a column that would display the average time between sync operations. An alternative would be to display a history of “Last sync” times.
I have a set procedure I do before an update. One step includes reviewing https://repo.manjaro.org. I believe it would be helpful to know if one is approaching the normal time a mirror is going to be syncing.
“Do You Manage a Potential Manjaro Mirror Server?” suggests:
Sync every six hours. Being a rolling release system Manjaro’s repos are very dynamic. So mirrors need to be updated multiple times per day.
Below are the repositories for country=United_States and the non-scientific results of how often the repository updates.
repo.ialab.dsu.edu/manjaro 30 minutes distro.ibiblio.org/manjaro 24 hours? mirrors.ocf.berkeley.edu/manjaro 2 hours & 30 minutes mirror.math.princeton.edu/pub/manjaro 1 hour mirror.clarkson.edu/manjaro 2 hour mirror.dacentec.com/manjaro 1 hour mirrors.gigenet.com/manjaro 7 hour us.mirrors.fossho.st/manjaro > 24 days
Questions:
Are
Stable,TestingandUnstableupdated at the same time? -
If the terms
sync = mirror = clone, why is it necessary to do
pacman -Syyurather thanpacman -Syuafter a mirrorlist change? -
During a sync operation of a mirror, are manjaro users locked out of the specific mirror to prevent any issues related to partial sync update?
Summary
How does Manjaro know what mirror(s) to use?
There is a file /etc/pacman.d/mirrorlist which lists all of the available mirrors.
There is another file called /etc/pacman-mirrors.conf that by default is configured to re-write your mirrorlist in a list with the fastest at the top, descending to the slowest, when the system is given the terminal command:
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
Also:
Every run of pacman-mirrors requires you to syncronize your database and update your
system. Pacman-mirrors - Manjaro
