I am currently using PipeWire and have been having problems with the audio turning off after the computer has been on for a bit. I would like to remove PipeWire and try using PulseAudio to see if this fixes my problem. I would like to do this correctly so I don’t cause myself even more problems. Could someone perhaps advise me on how to go about replacing PipeWire with PulseAudio?
pamac install manjaro-pulse
Edit: sorry, that’s the right package
I get this message when I run the command
Error: target not found: manjaro-pulseaudio
The package is called manjaro-pulse
Thanks, I have installed manjaro-pulse
and I removed PipeWire. However, my audio is still not working, is there anything extra to configure? Otherwise, where should I start looking to fix this?
It might be power save options.
I found this thread (https://www.reddit.com/r/ManjaroLinux/comments/mfgxlf/comment/gsnj9q5/?utm_source=share&utm_medium=web2x&context=3) and basically ran all the commands then restarted my computer and my sound is working. I’ll add to the thread if I encounter any more problems.
