here it is.
[ 21.730] (--) Log file renamed from "/var/log/Xorg.pid-1132.log" to "/var/log/Xorg.0.log"
[ 21.731]
X.Org X Server 1.21.1.4
[ 21.731] Current Operating System: Linux bee 5.15.74-3-MANJARO #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022 x86_64
[ 21.731] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=97862e81-ce46-4f78-85b1-85413ab10a62 rw rootflags=subvol=@ quiet cryptdevice=UUID=0e0826a7-7822-49c4-80d3-e52210680309:luks-0e0826a7-7822-49c4-80d3-e52210680309 root=/dev/mapper/luks-0e0826a7-7822-49c4-80d3-e52210680309 apparmor=1 security=apparmor resume=/dev/mapper/luks-da6f9727-290c-48d1-a551-c71b85c9c135 udev.log_priority=3
[ 21.731]
[ 21.731] Current version of pixman: 0.40.0
[ 21.731] Before reporting problems, check http://wiki.x.org
[ 21.731] Markers: (--) probed, (**) from config file, (==) default setting,
[ 21.731] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Oct 17 17:31:07 2022
[ 21.733] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 21.733] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.733] (==) No Layout section. Using the first Screen section.
[ 21.733] (==) No screen section available. Using defaults.
[ 21.733] (**) |-->Screen "Default Screen Section" (0)
[ 21.733] (**) | |-->Monitor "<default monitor>"
[ 21.733] (==) No monitor specified for screen "Default Screen Section".
[ 21.733] (==) Automatically adding devices
[ 21.733] (==) Automatically enabling devices
[ 21.733] (==) Automatically adding GPU devices
[ 21.733] (==) Automatically binding GPU devices
[ 21.733] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21.734] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 21.734] Entry deleted from font path.
[ 21.734] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 21.734] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 21.734] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 21.734] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 21.734] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21.734] (II) The server relies on udev to provide the list of input devices.
[ 21.734] (II) Module ABI versions:
[ 21.734] X.Org ANSI C Emulation: 0.4
[ 21.734] X.Org Video Driver: 25.2
[ 21.734] X.Org XInput driver : 24.4
[ 21.734] X.Org Server Extension : 10.0
[ 21.735] (++) using VT number 1
[ 21.735] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 21.736] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 21.736] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:09:00.0/drm/card0
[ 21.740] (--) PCI:*(9@0:0:0) 10de:1187:1458:360b rev 161, Mem @ 0xfb000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 21.740] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 21.740] (II) LoadModule: "glx"
[ 21.741] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 21.749] (II) Module glx: vendor="X.Org Foundation"
[ 21.749] compiled for 1.21.1.4, module version = 1.0.0
[ 21.749] ABI class: X.Org Server Extension, version 10.0
[ 21.749] (==) Matched modesetting as autoconfigured driver 0
[ 21.749] (==) Matched fbdev as autoconfigured driver 1
[ 21.749] (==) Matched vesa as autoconfigured driver 2
[ 21.749] (==) Assigned the driver to the xf86ConfigLayout
[ 21.749] (II) LoadModule: "modesetting"
[ 21.749] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 21.752] (II) Module modesetting: vendor="X.Org Foundation"
[ 21.752] compiled for 1.21.1.4, module version = 1.21.1
[ 21.752] Module class: X.Org Video Driver
[ 21.752] ABI class: X.Org Video Driver, version 25.2
[ 21.752] (II) LoadModule: "fbdev"
[ 21.752] (WW) Warning, couldn't open module fbdev
[ 21.752] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 21.752] (II) LoadModule: "vesa"
[ 21.752] (WW) Warning, couldn't open module vesa
[ 21.752] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 21.752] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 21.753] (II) modeset(0): using drv /dev/dri/card0
[ 21.753] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 21.753] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 21.753] (==) modeset(0): RGB weight 888
[ 21.753] (==) modeset(0): Default visual is TrueColor
[ 21.753] (II) Loading sub module "glamoregl"
[ 21.753] (II) LoadModule: "glamoregl"
[ 21.753] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 21.759] (II) Module glamoregl: vendor="X.Org Foundation"
[ 21.759] compiled for 1.21.1.4, module version = 1.0.1
[ 21.759] ABI class: X.Org ANSI C Emulation, version 0.4
[ 21.977] (II) modeset(0): glamor X acceleration enabled on NVE4
[ 21.977] (II) modeset(0): glamor initialized
[ 21.977] (==) modeset(0): VariableRefresh: disabled
[ 21.977] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 21.989] (II) modeset(0): Output DVI-I-1 has no monitor section
[ 21.990] (II) modeset(0): Output DVI-D-1 has no monitor section
[ 22.064] (II) modeset(0): Output HDMI-1 has no monitor section
[ 22.134] (II) modeset(0): Output DP-1 has no monitor section
[ 22.146] (II) modeset(0): EDID for output DVI-I-1
[ 22.148] (II) modeset(0): EDID for output DVI-D-1
[ 22.221] (II) modeset(0): EDID for output HDMI-1
[ 22.221] (II) modeset(0): Manufacturer: GSM Model: c0c8 Serial#: 16843009
[ 22.221] (II) modeset(0): Year: 2020 Week: 1
[ 22.221] (II) modeset(0): EDID Version: 1.3
[ 22.221] (II) modeset(0): Digital Display Input
[ 22.221] (II) modeset(0): Max Image Size [cm]: horiz.: 160 vert.: 90
[ 22.221] (II) modeset(0): Gamma: 2.20
[ 22.221] (II) modeset(0): No DPMS capabilities specified
[ 22.221] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 22.221] (II) modeset(0): First detailed timing is preferred mode
[ 22.221] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 22.221] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[ 22.221] (II) modeset(0): Supported established timings:
[ 22.221] (II) modeset(0): 720x400@70Hz
[ 22.221] (II) modeset(0): 640x480@60Hz
[ 22.221] (II) modeset(0): 800x600@60Hz
[ 22.221] (II) modeset(0): 1024x768@60Hz
[ 22.221] (II) modeset(0): Manufacturer's mask: 0
[ 22.221] (II) modeset(0): Supported standard timings:
[ 22.221] (II) modeset(0): #0: hsize: 640 vsize 480 refresh: 60 vid: 16433
[ 22.221] (II) modeset(0): #1: hsize: 800 vsize 600 refresh: 60 vid: 16453
[ 22.221] (II) modeset(0): #2: hsize: 1024 vsize 768 refresh: 60 vid: 16481
[ 22.221] (II) modeset(0): #3: hsize: 1152 vsize 864 refresh: 60 vid: 16497
[ 22.221] (II) modeset(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 22.221] (II) modeset(0): #5: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 22.221] (II) modeset(0): Supported detailed timing:
[ 22.221] (II) modeset(0): clock: 594.0 MHz Image Size: 1600 x 900 mm
[ 22.221] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 22.221] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 22.221] (II) modeset(0): clock: 85.5 MHz Image Size: 1600 x 900 mm
[ 22.221] (II) modeset(0): h_active: 1360 h_sync: 1424 h_sync_end 1536 h_blank_end 1792 h_border: 0
[ 22.221] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 795 v_border: 0
[ 22.221] (II) modeset(0): Ranges: V min: 24 V max: 120 Hz, H min: 30 H max: 255 kHz, PixClock max 1195 MHz
[ 22.221] (II) modeset(0): Monitor name: LG TV SSCR
[ 22.221] (II) modeset(0): clock: 497.8 MHz Image Size: 1600 x 900 mm
[ 22.221] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 22.221] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1525 v_border: 0
[ 22.221] (II) modeset(0): Number of EDID sections to follow: 1
[ 22.221] (II) modeset(0): EDID (in hex):
[ 22.221] (II) modeset(0): 00ffffffffffff001e6dc8c001010101
[ 22.221] (II) modeset(0): 011e010380a05a780aee91a3544c9926
[ 22.221] (II) modeset(0): 0f5054a1080031404540614071408180
[ 22.221] (II) modeset(0): d1c00101010108e80030f2705a80b058
[ 22.221] (II) modeset(0): 8a0040846300001e662150b051001b30
[ 22.221] (II) modeset(0): 4070360040846300001e000000fd0018
[ 22.221] (II) modeset(0): 781eff77000a202020202020000000fc
[ 22.221] (II) modeset(0): 004c4720545620535343520a202001aa
[ 22.221] (II) modeset(0): 020364f15e616076756665dbda101f04
[ 22.221] (II) modeset(0): 13051403021220212215015d5e5f6263
[ 22.221] (II) modeset(0): 643f402c095707150750570701670403
[ 22.221] (II) modeset(0): 6e030c001000b83c240080010203046a
[ 22.221] (II) modeset(0): d85dc401788053022878e200cfe305c0
[ 22.221] (II) modeset(0): 00e3060d01e20fffeb0146d0002a1a03
[ 22.221] (II) modeset(0): 518b67736fc200a0a0a0555030203500
[ 22.221] (II) modeset(0): 40846300001e00000000000000000060
[ 22.221] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 22.221] (II) modeset(0): Not using default mode "3840x2160" (bad mode clock/interlace/doublescan)
[ 22.221] (II) modeset(0): Printing probed modes for output HDMI-1
[ 22.221] (II) modeset(0): Modeline "4096x2160"x30.0 297.00 4096 4184 4272 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 22.221] (II) modeset(0): Modeline "4096x2160"x25.0 297.00 4096 5064 5152 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 22.221] (II) modeset(0): Modeline "4096x2160"x24.0 297.00 4096 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "4096x2160"x30.0 296.70 4096 4184 4272 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 22.221] (II) modeset(0): Modeline "4096x2160"x24.0 296.70 4096 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x60.0 1044.88 3840 3864 3880 3920 2160 2161 2164 2221 doublescan +hsync -vsync (266.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x60.0 712.75 3840 4160 4576 5312 2160 2163 2168 2237 -hsync +vsync (134.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x60.0 533.00 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 22.221] (II) modeset(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 22.221] (II) modeset(0): Modeline "3200x1800"x60.0 492.00 3200 3456 3800 4400 1800 1803 1808 1865 -hsync +vsync (111.8 kHz d)
[ 22.221] (II) modeset(0): Modeline "3200x1800"x59.9 373.00 3200 3248 3280 3360 1800 1803 1808 1852 +hsync -vsync (111.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "2880x1620"x60.0 396.25 2880 3096 3408 3936 1620 1623 1628 1679 -hsync +vsync (100.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "2880x1620"x60.0 303.75 2880 2928 2960 3040 1620 1623 1628 1666 +hsync -vsync (99.9 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1600"x60.0 348.50 2560 2760 3032 3504 1600 1603 1609 1658 -hsync +vsync (99.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1440"x60.0 638.25 2560 2780 3064 3568 1440 1441 1444 1491 doublescan -hsync +vsync (178.9 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1440"x60.0 469.12 2560 2584 2600 2640 1440 1441 1444 1481 doublescan +hsync -vsync (177.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1536"x85.0 388.04 2048 2216 2440 2832 1536 1537 1540 1612 -hsync +vsync (137.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1536"x75.0 340.48 2048 2216 2440 2832 1536 1537 1540 1603 -hsync +vsync (120.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1440"x85.0 341.35 1920 2072 2288 2656 1440 1441 1444 1512 -hsync +vsync (128.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1440"x75.0 297.00 1920 2064 2288 2640 1440 1441 1444 1500 -hsync +vsync (112.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1856x1392"x75.0 288.00 1856 1984 2208 2560 1392 1393 1396 1500 -hsync +vsync (112.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 22.221] (II) modeset(0): Modeline "1792x1344"x75.0 261.00 1792 1888 2104 2456 1344 1345 1348 1417 -hsync +vsync (106.3 kHz d)
[ 22.221] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1152"x60.0 406.50 2048 2220 2444 2840 1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1152"x60.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 22.221] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x120.0 297.00 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x100.0 297.00 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (112.5 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x119.9 296.70 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (134.9 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 22.221] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 22.221] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "1600x1200"x85.0 229.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (106.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x1200"x75.0 202.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (93.8 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x1200"x70.0 189.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (87.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x1200"x65.0 175.50 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 22.221] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 22.221] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 22.221] (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 22.221] (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 22.221] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 22.221] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 22.221] (II) modeset(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 22.221] (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 22.221] (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 22.222] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 22.222] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x85.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 22.222] (II) modeset(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x720"x85.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 22.222] (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x85.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 22.222] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 22.222] (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 22.222] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 22.222] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 22.222] (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
[ 22.222] (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 22.222] (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 22.222] (II) modeset(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 22.222] (II) modeset(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
[ 22.294] (II) modeset(0): EDID for output DP-1
[ 22.294] (II) modeset(0): Output DVI-I-1 disconnected
[ 22.294] (II) modeset(0): Output DVI-D-1 disconnected
[ 22.294] (II) modeset(0): Output HDMI-1 connected
[ 22.294] (II) modeset(0): Output DP-1 disconnected
[ 22.294] (II) modeset(0): Using exact sizes for initial modes
[ 22.294] (II) modeset(0): Output HDMI-1 using initial mode 3840x2160 +0+0
[ 22.294] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 22.294] (==) modeset(0): DPI set to (96, 96)
[ 22.294] (II) Loading sub module "fb"
[ 22.294] (II) LoadModule: "fb"
[ 22.294] (II) Module "fb" already built-in
[ 22.302] (==) modeset(0): Backing store enabled
[ 22.302] (==) modeset(0): Silken mouse enabled
[ 22.303] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 22.304] (==) modeset(0): DPMS enabled
[ 22.304] (II) modeset(0): [DRI2] Setup complete
[ 22.304] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 22.304] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 22.304] (II) Initializing extension Generic Event Extension
[ 22.304] (II) Initializing extension SHAPE
[ 22.304] (II) Initializing extension MIT-SHM
[ 22.304] (II) Initializing extension XInputExtension
[ 22.304] (II) Initializing extension XTEST
[ 22.304] (II) Initializing extension BIG-REQUESTS
[ 22.304] (II) Initializing extension SYNC
[ 22.304] (II) Initializing extension XKEYBOARD
[ 22.304] (II) Initializing extension XC-MISC
[ 22.304] (II) Initializing extension SECURITY
[ 22.304] (II) Initializing extension XFIXES
[ 22.304] (II) Initializing extension RENDER
[ 22.304] (II) Initializing extension RANDR
[ 22.304] (II) Initializing extension COMPOSITE
[ 22.304] (II) Initializing extension DAMAGE
[ 22.304] (II) Initializing extension MIT-SCREEN-SAVER
[ 22.304] (II) Initializing extension DOUBLE-BUFFER
[ 22.305] (II) Initializing extension RECORD
[ 22.305] (II) Initializing extension DPMS
[ 22.305] (II) Initializing extension Present
[ 22.305] (II) Initializing extension DRI3
[ 22.305] (II) Initializing extension X-Resource
[ 22.305] (II) Initializing extension XVideo
[ 22.305] (II) Initializing extension XVideo-MotionCompensation
[ 22.305] (II) Initializing extension GLX
[ 22.308] (II) AIGLX: Loaded and initialized nouveau
[ 22.308] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 22.308] (II) Initializing extension XFree86-VidModeExtension
[ 22.308] (II) Initializing extension XFree86-DGA
[ 22.308] (II) Initializing extension XFree86-DRI
[ 22.308] (II) Initializing extension DRI2
[ 22.308] (II) modeset(0): Damage tracking initialized
[ 22.308] (II) modeset(0): Setting screen physical size to 1016 x 571
[ 22.343] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 22.343] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 22.343] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 22.343] (**) Power Button: Applying InputClass "system-keyboard"
[ 22.343] (II) LoadModule: "libinput"
[ 22.343] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 22.348] (II) Module libinput: vendor="X.Org Foundation"
[ 22.348] compiled for 1.21.1.3, module version = 1.2.1
[ 22.348] Module class: X.Org XInput Driver
[ 22.348] ABI class: X.Org XInput driver, version 24.4
[ 22.348] (II) Using input driver 'libinput' for 'Power Button'
[ 22.348] (**) Power Button: always reports core events
[ 22.348] (**) Option "Device" "/dev/input/event1"
[ 22.350] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 22.350] (II) event1 - Power Button: device is a keyboard
[ 22.350] (II) event1 - Power Button: device removed
[ 22.374] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 22.374] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 22.374] (**) Option "xkb_layout" "de"
[ 22.387] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 22.387] (II) event1 - Power Button: device is a keyboard
[ 22.388] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 22.388] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 22.388] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 22.388] (**) Power Button: Applying InputClass "system-keyboard"
[ 22.388] (II) Using input driver 'libinput' for 'Power Button'
[ 22.388] (**) Power Button: always reports core events
[ 22.388] (**) Option "Device" "/dev/input/event0"
[ 22.388] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 22.388] (II) event0 - Power Button: device is a keyboard
[ 22.388] (II) event0 - Power Button: device removed
[ 22.414] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 22.414] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 22.414] (**) Option "xkb_layout" "de"
[ 22.415] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 22.415] (II) event0 - Power Button: device is a keyboard
[ 22.415] (II) config/udev: Adding input device DHS USB DOGLE Keyboard (/dev/input/event2)
[ 22.415] (**) DHS USB DOGLE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 22.415] (**) DHS USB DOGLE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 22.415] (**) DHS USB DOGLE Keyboard: Applying InputClass "system-keyboard"
[ 22.415] (II) Using input driver 'libinput' for 'DHS USB DOGLE Keyboard'
[ 22.415] (**) DHS USB DOGLE Keyboard: always reports core events
[ 22.415] (**) Option "Device" "/dev/input/event2"
[ 22.416] (II) event2 - DHS USB DOGLE Keyboard: is tagged by udev as: Keyboard
[ 22.416] (II) event2 - DHS USB DOGLE Keyboard: device is a keyboard
[ 22.416] (II) event2 - DHS USB DOGLE Keyboard: device removed
[ 22.441] (II) libinput: DHS USB DOGLE Keyboard: needs a virtual subdevice
[ 22.441] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:06:00.1/usb1/1-6/1-6:1.0/0003:348F:1010.0001/input/input2/event2"
[ 22.441] (II) XINPUT: Adding extended input device "DHS USB DOGLE Keyboard" (type: MOUSE, id 8)
[ 22.441] (**) Option "AccelerationScheme" "none"
[ 22.441] (**) DHS USB DOGLE Keyboard: (accel) selected scheme none/0
[ 22.441] (**) DHS USB DOGLE Keyboard: (accel) acceleration factor: 2.000
[ 22.441] (**) DHS USB DOGLE Keyboard: (accel) acceleration threshold: 4
[ 22.442] (II) event2 - DHS USB DOGLE Keyboard: is tagged by udev as: Keyboard
[ 22.442] (II) event2 - DHS USB DOGLE Keyboard: device is a keyboard
[ 22.443] (II) config/udev: Adding input device DHS USB DOGLE (/dev/input/event4)
[ 22.443] (**) DHS USB DOGLE: Applying InputClass "evdev pointer catchall"
[ 22.443] (**) DHS USB DOGLE: Applying InputClass "libinput pointer catchall"
[ 22.443] (II) Using input driver 'libinput' for 'DHS USB DOGLE'
[ 22.443] (**) DHS USB DOGLE: always reports core events
[ 22.443] (**) Option "Device" "/dev/input/event4"
[ 22.498] (II) event4 - DHS USB DOGLE: is tagged by udev as: Mouse
[ 22.498] (II) event4 - DHS USB DOGLE: device is a pointer
[ 22.499] (II) event4 - DHS USB DOGLE: device removed
[ 22.560] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:06:00.1/usb1/1-6/1-6:1.1/0003:348F:1010.0004/input/input4/event4"
[ 22.560] (II) XINPUT: Adding extended input device "DHS USB DOGLE" (type: MOUSE, id 9)
[ 22.561] (**) Option "AccelerationScheme" "none"
[ 22.561] (**) DHS USB DOGLE: (accel) selected scheme none/0
[ 22.561] (**) DHS USB DOGLE: (accel) acceleration factor: 2.000
[ 22.561] (**) DHS USB DOGLE: (accel) acceleration threshold: 4
[ 22.618] (II) event4 - DHS USB DOGLE: is tagged by udev as: Mouse
[ 22.619] (II) event4 - DHS USB DOGLE: device is a pointer
[ 22.620] (II) config/udev: Adding input device DHS USB DOGLE (/dev/input/mouse0)
[ 22.620] (II) No input driver specified, ignoring this device.
[ 22.620] (II) This device may have been added with another device file.
[ 22.620] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
[ 22.621] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
[ 22.621] (II) No input driver specified, ignoring this device.
[ 22.621] (II) This device may have been added with another device file.
[ 22.621] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[ 22.621] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[ 22.622] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[ 22.622] (II) No input driver specified, ignoring this device.
[ 22.622] (II) This device may have been added with another device file.
[ 22.622] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[ 22.622] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event14)
[ 22.623] (II) config/udev: Adding input device Logitech K360 (/dev/input/event5)
[ 22.623] (**) Logitech K360: Applying InputClass "evdev keyboard catchall"
[ 22.623] (**) Logitech K360: Applying InputClass "libinput keyboard catchall"
[ 22.623] (**) Logitech K360: Applying InputClass "system-keyboard"
[ 22.623] (II) Using input driver 'libinput' for 'Logitech K360'
[ 22.623] (**) Logitech K360: always reports core events
[ 22.623] (**) Option "Device" "/dev/input/event5"
[ 22.625] (II) event5 - Logitech K360: is tagged by udev as: Keyboard
[ 22.625] (II) event5 - Logitech K360: device is a keyboard
[ 22.625] (II) event5 - Logitech K360: device removed
[ 22.654] (II) libinput: Logitech K360: needs a virtual subdevice
[ 22.654] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb5/5-4/5-4:1.2/0003:046D:C52B.0006/0003:046D:4004.0008/input/input19/event5"
[ 22.654] (II) XINPUT: Adding extended input device "Logitech K360" (type: MOUSE, id 10)
[ 22.654] (**) Option "AccelerationScheme" "none"
[ 22.654] (**) Logitech K360: (accel) selected scheme none/0
[ 22.654] (**) Logitech K360: (accel) acceleration factor: 2.000
[ 22.654] (**) Logitech K360: (accel) acceleration threshold: 4
[ 22.655] (II) event5 - Logitech K360: is tagged by udev as: Keyboard
[ 22.656] (II) event5 - Logitech K360: device is a keyboard
[ 22.657] (II) config/udev: Adding input device Logitech MX Anywhere 2S (/dev/input/event3)
[ 22.657] (**) Logitech MX Anywhere 2S: Applying InputClass "evdev pointer catchall"
[ 22.657] (**) Logitech MX Anywhere 2S: Applying InputClass "evdev keyboard catchall"
[ 22.657] (**) Logitech MX Anywhere 2S: Applying InputClass "libinput pointer catchall"
[ 22.657] (**) Logitech MX Anywhere 2S: Applying InputClass "libinput keyboard catchall"
[ 22.657] (**) Logitech MX Anywhere 2S: Applying InputClass "system-keyboard"
[ 22.657] (II) Using input driver 'libinput' for 'Logitech MX Anywhere 2S'
[ 22.657] (**) Logitech MX Anywhere 2S: always reports core events
[ 22.657] (**) Option "Device" "/dev/input/event3"
[ 22.658] (II) event3 - Logitech MX Anywhere 2S: is tagged by udev as: Keyboard Mouse
[ 22.658] (II) event3 - Logitech MX Anywhere 2S: device is a pointer
[ 22.658] (II) event3 - Logitech MX Anywhere 2S: device is a keyboard
[ 22.659] (II) event3 - Logitech MX Anywhere 2S: device removed
[ 22.694] (II) libinput: Logitech MX Anywhere 2S: needs a virtual subdevice
[ 22.694] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb5/5-4/5-4:1.2/0003:046D:C52B.0006/0003:046D:406A.0009/input/input17/event3"
[ 22.694] (II) XINPUT: Adding extended input device "Logitech MX Anywhere 2S" (type: MOUSE, id 11)
[ 22.694] (**) Option "AccelerationScheme" "none"
[ 22.694] (**) Logitech MX Anywhere 2S: (accel) selected scheme none/0
[ 22.694] (**) Logitech MX Anywhere 2S: (accel) acceleration factor: 2.000
[ 22.694] (**) Logitech MX Anywhere 2S: (accel) acceleration threshold: 4
[ 22.695] (II) event3 - Logitech MX Anywhere 2S: is tagged by udev as: Keyboard Mouse
[ 22.696] (II) event3 - Logitech MX Anywhere 2S: device is a pointer
[ 22.696] (II) event3 - Logitech MX Anywhere 2S: device is a keyboard
[ 22.697] (II) config/udev: Adding input device Logitech MX Anywhere 2S (/dev/input/mouse1)
[ 22.697] (**) Logitech MX Anywhere 2S: Applying InputClass "system-keyboard"
[ 22.697] (II) No input driver specified, ignoring this device.
[ 22.697] (II) This device may have been added with another device file.
[ 22.698] (II) config/udev: Adding input device Logitech M705 (/dev/input/event6)
[ 22.698] (**) Logitech M705: Applying InputClass "evdev pointer catchall"
[ 22.698] (**) Logitech M705: Applying InputClass "libinput pointer catchall"
[ 22.698] (II) Using input driver 'libinput' for 'Logitech M705'
[ 22.698] (**) Logitech M705: always reports core events
[ 22.698] (**) Option "Device" "/dev/input/event6"
[ 22.699] (II) event6 - Logitech M705: is tagged by udev as: Mouse
[ 22.699] (II) event6 - Logitech M705: device set to 1000 DPI
[ 22.699] (II) event6 - Logitech M705: device is a pointer
[ 22.699] (II) event6 - Logitech M705: device removed
[ 22.760] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb5/5-4/5-4:1.2/0003:046D:C52B.0006/0003:046D:406D.0007/input/input18/event6"
[ 22.761] (II) XINPUT: Adding extended input device "Logitech M705" (type: MOUSE, id 12)
[ 22.761] (**) Option "AccelerationScheme" "none"
[ 22.761] (**) Logitech M705: (accel) selected scheme none/0
[ 22.761] (**) Logitech M705: (accel) acceleration factor: 2.000
[ 22.761] (**) Logitech M705: (accel) acceleration threshold: 4
[ 22.762] (II) event6 - Logitech M705: is tagged by udev as: Mouse
[ 22.762] (II) event6 - Logitech M705: device set to 1000 DPI
[ 22.762] (II) event6 - Logitech M705: device is a pointer
[ 22.763] (II) config/udev: Adding input device Logitech M705 (/dev/input/mouse2)
[ 22.763] (II) No input driver specified, ignoring this device.
[ 22.763] (II) This device may have been added with another device file.
[ 22.764] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event16)
[ 22.764] (II) No input driver specified, ignoring this device.
[ 22.764] (II) This device may have been added with another device file.
[ 22.764] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event17)
[ 22.764] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event18)
[ 22.765] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event19)
[ 22.765] (II) No input driver specified, ignoring this device.
[ 22.765] (II) This device may have been added with another device file.
[ 22.765] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event20)
[ 22.765] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event21)
[ 22.766] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event22)
[ 22.766] (II) No input driver specified, ignoring this device.
[ 22.766] (II) This device may have been added with another device file.
[ 22.766] (II) config/udev: Adding input device Eee PC WMI hotkeys (/dev/input/event15)
[ 22.766] (**) Eee PC WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 22.766] (**) Eee PC WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 22.766] (**) Eee PC WMI hotkeys: Applying InputClass "system-keyboard"
[ 22.766] (II) Using input driver 'libinput' for 'Eee PC WMI hotkeys'
[ 22.766] (**) Eee PC WMI hotkeys: always reports core events
[ 22.766] (**) Option "Device" "/dev/input/event15"
[ 22.767] (II) event15 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 22.767] (II) event15 - Eee PC WMI hotkeys: device is a keyboard
[ 22.767] (II) event15 - Eee PC WMI hotkeys: device removed
[ 22.827] (**) Option "config_info" "udev:/sys/devices/platform/eeepc-wmi/input/input28/event15"
[ 22.827] (II) XINPUT: Adding extended input device "Eee PC WMI hotkeys" (type: KEYBOARD, id 13)
[ 22.827] (**) Option "xkb_layout" "de"
[ 22.828] (II) event15 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[ 22.828] (II) event15 - Eee PC WMI hotkeys: device is a keyboard
[ 22.829] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 22.829] (II) No input driver specified, ignoring this device.
[ 22.829] (II) This device may have been added with another device file.
[ 22.834] (**) DHS USB DOGLE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 22.834] (**) DHS USB DOGLE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 22.834] (**) DHS USB DOGLE Keyboard: Applying InputClass "system-keyboard"
[ 22.834] (II) Using input driver 'libinput' for 'DHS USB DOGLE Keyboard'
[ 22.834] (**) DHS USB DOGLE Keyboard: always reports core events
[ 22.834] (**) Option "Device" "/dev/input/event2"
[ 22.834] (II) libinput: DHS USB DOGLE Keyboard: is a virtual subdevice
[ 22.834] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:06:00.1/usb1/1-6/1-6:1.0/0003:348F:1010.0001/input/input2/event2"
[ 22.834] (II) XINPUT: Adding extended input device "DHS USB DOGLE Keyboard" (type: KEYBOARD, id 14)
[ 22.834] (**) Option "xkb_layout" "de"
[ 22.834] (**) Logitech K360: Applying InputClass "evdev keyboard catchall"
[ 22.834] (**) Logitech K360: Applying InputClass "libinput keyboard catchall"
[ 22.834] (**) Logitech K360: Applying InputClass "system-keyboard"
[ 22.835] (II) Using input driver 'libinput' for 'Logitech K360'
[ 22.835] (**) Logitech K360: always reports core events
[ 22.835] (**) Option "Device" "/dev/input/event5"
[ 22.835] (II) libinput: Logitech K360: is a virtual subdevice
[ 22.835] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb5/5-4/5-4:1.2/0003:046D:C52B.0006/0003:046D:4004.0008/input/input19/event5"
[ 22.835] (II) XINPUT: Adding extended input device "Logitech K360" (type: KEYBOARD, id 15)
[ 22.835] (**) Option "xkb_layout" "de"
[ 22.835] (**) Logitech MX Anywhere 2S: Applying InputClass "evdev pointer catchall"
[ 22.835] (**) Logitech MX Anywhere 2S: Applying InputClass "evdev keyboard catchall"
[ 22.835] (**) Logitech MX Anywhere 2S: Applying InputClass "libinput pointer catchall"
[ 22.835] (**) Logitech MX Anywhere 2S: Applying InputClass "libinput keyboard catchall"
[ 22.835] (**) Logitech MX Anywhere 2S: Applying InputClass "system-keyboard"
[ 22.835] (II) Using input driver 'libinput' for 'Logitech MX Anywhere 2S'
[ 22.835] (**) Logitech MX Anywhere 2S: always reports core events
[ 22.835] (**) Option "Device" "/dev/input/event3"
[ 22.835] (II) libinput: Logitech MX Anywhere 2S: is a virtual subdevice
[ 22.835] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb5/5-4/5-4:1.2/0003:046D:C52B.0006/0003:046D:406A.0009/input/input17/event3"
[ 22.835] (II) XINPUT: Adding extended input device "Logitech MX Anywhere 2S" (type: KEYBOARD, id 16)
[ 26.710] (II) event1 - Power Button: device removed
[ 26.731] (II) event0 - Power Button: device removed
[ 26.761] (II) event4 - DHS USB DOGLE: device removed
[ 26.841] (II) event6 - Logitech M705: device removed
[ 26.921] (II) event15 - Eee PC WMI hotkeys: device removed
[ 26.988] (II) event2 - DHS USB DOGLE Keyboard: device removed
[ 27.014] (II) event5 - Logitech K360: device removed
[ 27.042] (II) event3 - Logitech MX Anywhere 2S: device removed
[ 27.067] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 191.990] (II) UnloadModule: "libinput"
[ 191.991] (II) UnloadModule: "libinput"
[ 191.992] (II) Server terminated successfully (0). Closing log file.
