I have been experiencing repeated crashes on my fresh Manjaro install, usually when running GPU intensive applications such as video streaming or video calls.
System is running X11, but this happens more frequently if I switch to Wayland. I have reinstalled the OS, and the graphics drivers, but it keeps happening. Seems to be something to do with libc.so.6. Any chance switching from video-linux drivers to video-modesetting might help?
There is also a repeated error with the Bluetooth: Bluetooth: hci0: Malformed MSFT vendor event: 0x02, but I am not sure if that is related.
output of sudo journalctl -b -1 -p err :
Aug 20 09:51:15 finley-HPElitebook-850 kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1420:>
Aug 20 09:51:15 finley-HPElitebook-850 kernel: ext4_test_bit(bit=5434, block=37748756) = 0
Aug 20 09:51:15 finley-HPElitebook-850 kernel: ext4_test_bit(bit=3816, block=36175892) = 0
Aug 20 09:51:15 finley-HPElitebook-850 kernel: ext4_test_bit(bit=4727, block=34603028) = 0
Aug 20 09:51:18 finley-HPElitebook-850 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Aug 20 09:51:21 finley-HPElitebook-850 systemd-coredump[850]: [🡕] Process 795 (Xorg) of user 0 dumped core.
Stack trace of thread 795:
#0 0x0000728909d503f4 n/a (libc.so.6 + 0x963f4)
#1 0x0000728909cf7120 raise (libc.so.6 + 0x3d120)
#2 0x0000728909cde4c3 abort (libc.so.6 + 0x244c3)
#3 0x00005cb76fedb12e OsAbort (Xorg + 0x14b12e)
#4 0x00005cb76fedc5e7 FatalError (Xorg + 0x14c5e7)
#5 0x00005cb76fee3268 n/a (Xorg + 0x153268)
#6 0x0000728909cf71d0 n/a (libc.so.6 + 0x3d1d0)
Stack trace of thread 826:
#0 0x0000728909d4aa19 n/a (libc.so.6 + 0x90a19)
#1 0x0000728909d4d479 pthread_cond_wait (libc.so.6 + 0x93479)
#2 0x0000728906ca21ee n/a (iris_dri.so + 0xa21ee)
#3 0x0000728906c7f1cc n/a (iris_dri.so + 0x7f1cc)
#4 0x0000728906ca211d n/a (iris_dri.so + 0xa211d)
#5 0x0000728909d4e39d n/a (libc.so.6 + 0x9439d)
#6 0x0000728909dd349c n/a (libc.so.6 + 0x11949c)
Stack trace of thread 829:
Stack trace of thread 830:
Stack trace of thread 825:
Stack trace of thread 837:
Stack trace of thread 838:
Stack trace of thread 845:
#0 0x0000728909dd38b2 epoll_wait (libc.so.6 + 0x1198b2)
#1 0x00005cb76fedad40 n/a (Xorg + 0x14ad40)
#2 0x00005cb76fede449 n/a (Xorg + 0x14e449)
#3 0x0000728909d4e39d n/a (libc.so.6 + 0x9439d)
#4 0x0000728909dd349c n/a (libc.so.6 + 0x11949c)
inxi:
Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=a89b2a3f-eb20-46cc-839b-28017c073760 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: HP product: HP EliteBook 850 G8 Notebook PC v: SBKPF
Mobo: HP model: 8846 v: KBC Version 30.53.00 serial: <superuser required>
part-nu: 1G1Y1AV uuid: <superuser required> UEFI: HP v: T76 Ver. 01.17.01
date: 05/03/2024
ID-1: BAT0 charge: 46.6 Wh (100.0%) condition: 46.6/56.3 Wh (82.9%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 111
System RAM: total: 32 GiB available: 31.04 GiB used: 4.86 GiB (15.7%)
Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous size: 16 GiB
speed: 3200 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: HP32D4S2S8ME-16 serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous size: 16 GiB
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 967 high: 1196 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 938 2: 858 3: 1196
4: 1105 5: 1004 6: 1123 7: 1115 8: 400 bogomips: 47936
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp
rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
Use of uninitialized value $unmatched_display[0] in hash element at /usr/bin/inxi line 19002.
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0408:5374
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: evdi,i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5560x2112 s-dpi: 96 s-size: 1467x557mm (57.76x21.93")
s-diag: 1569mm (61.78")
Monitor-1: DVI-I-1 mapped: DVI-I-1-1 pos: top-left model: HP E232
serial: <filter> built: 2017 res: 1080x1920 hz: 60 dpi: 96 gamma: 1.2
chroma: red: x: 0.655 y: 0.337 green: x: 0.322 y: 0.608 blue: x: 0.149
y: 0.059 white: x: 0.314 y: 0.329 size: 286x509mm (11.26x20.04")
diag: 584mm (23") ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900,
1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
Monitor-2: DVI-I-1 mapped: DVI-I-2-2 pos: primary,middle-c model: HP E232
serial: <filter> built: 2017 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
y: 0.059 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
Monitor-3: eDP-1 pos: bottom-r model: LG Display 0x071b built: 2021
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
green: x: 0.306 y: 0.612 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
EDID-Warnings: 1: parse_edid: unknown flag 2
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 15.15 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 24.1.5-manjaro1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Device-2: DisplayLink ALOGIC DX2 Docking Station
driver: cdc_ncm,snd-usb-audio,usbfs type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-6.1:6 chip-ID: 17e9:6000 class-ID: 0a00
serial: <filter>
API: ALSA v: k6.9.12-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
IF-ID-1: enp0s20f0u6u1i5 state: up speed: 1000 Mbps duplex: half
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 200.73 GiB (42.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
model: MTFDHBA512TDV-1AZ1AABHA size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS0032 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 200.73 GiB (42.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a89b2a3f-eb20-46cc-839b-28017c073760
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8468-CFEB
ID-3: /home/<filter>/GoogleDrive raw-size: N/A size: 100 TiB
used: 48.31 TiB (48.3%) fs: fuse.rclone remote: gdrive:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Quanta HP HD Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0408:5374 class-ID: 0e02 serial: <filter>
Hub-4: 3-6:4 info: Genesys Logic Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 3-6.1:6 info: DisplayLink ALOGIC DX2 Docking Station
type: audio,communication,CDC-data driver: cdc_ncm,snd-usb-audio,usbfs
interfaces: 7 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 2mA chip-ID: 17e9:6000 class-ID: 0a00 serial: <filter>
Device-2: 3-6.2:43 info: Holtek USB-HID Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 04d9:8008 class-ID: 0300
serial: <filter>
Hub-5: 3-6.4:8 info: Genesys Logic Hub ports: 3 rev: 2.1
Device-1: 3-6.5:9 info: Genesys Logic Billboard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 96mA chip-ID: 05e3:0f01 class-ID: 1100 serial: <filter>
Device-2: 3-10:5 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1610 libs: 363 tools: pamac,yay pm: flatpak
pkgs: 0
