Somehow Wine has taken over and it opens my Images with iexplorer, Witch I don’t Like
here is how to get rid of it
- Open winecfg
- Go to the libraries tab
- In the dropdown, type in “winemenubuilder.exe” without the quotes. It’s not in the list, but you can type it.
- Once added, click on the new entry and click the Edit button.
- Click the Disabled radio button, and save everything.
Hop this helps the other guy who runs into this little Problem
This isn’t the way to fix your problem, because it will disallow Wine from launching and associating your Wine programs in the future. The correct way to solve this is to redefine your application to open image files as GThumb.
To be fair, this is not an easy task to do. The application preference is way to fragile.
For example when I use nautilus outside of gnome, the “Open with” dialogue will not offer me the option for “ Remember nextime” and just overwrittes my defaults application association.
