I was unable to peform the last update and received the title error
LC_ALL=en_US sudo pacman -Syyu
core 167.6 KiB 1095 KiB/s 00:00 [########################################] 100%
extra 1995.1 KiB 2.72 MiB/s 00:01 [########################################] 100%
community 6.3 MiB 3.24 MiB/s 00:02 [########################################] 100%
multilib 182.0 KiB 1957 KiB/s 00:00 [########################################] 100%
:: Replace lib32-nvidia-450xx-utils with multilib/lib32-nvidia-utils? [Y/n]
:: Replace linux57 with community/linux-latest? [Y/n]
:: Replace linux57-virtualbox-host-modules with community/linux-latest-virtualbox-host-modules? [Y/n]
:: Replace mhwd-nvidia-418xx with core/mhwd-nvidia? [Y/n]
:: Replace mhwd-nvidia-430xx with core/mhwd-nvidia? [Y/n]
:: Replace mhwd-nvidia-435xx with core/mhwd-nvidia? [Y/n]
:: Replace mhwd-nvidia-440xx with core/mhwd-nvidia? [Y/n]
:: Replace mhwd-nvidia-450xx with core/mhwd-nvidia? [Y/n]
:: Replace mhwd-nvidia-455xx with core/mhwd-nvidia? [Y/n]
:: Replace opencl-nvidia-450xx with extra/opencl-nvidia? [Y/n]
resolving dependencies...
:: removing linux57 breaks dependency 'linux57' required by linux57-nvidia-450xx
I did some searching on the forum and the solution marked here did not work for me.
What should I do?
can you report
uname -a
sudo mhwd-kernel -li
sudo mhwd -li
sudo ls /etc/mkinitcpio.d/*.preset
uname -a
Linux rohan 5.7.19-2-MANJARO #1 SMP PREEMPT Fri Aug 28 20:22:12 UTC 2020 x86_64 GNU/Linux
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
/etc/mkinitcpio.d/linux54.preset /etc/mkinitcpio.d/linux57.preset
sudo pacman -Syyu
sudo mhwd-kernel -i linux510
sudo mkinitcpio -P ( check that all is correct )
if you have no nvidia
sudo mhwd -a pci free 0300
if you have a nvidia
sudo mhwd -a pci nonfree 0300
reboot on linux5.10 or 5.4 then remove linux57
sudo mhwd-kernel -r linux57
I did run all the commands. Manjaro wont boot now Iḿ stuck into a black screen. I did login with a live cd, now I get:
mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.2-2-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.85-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
==> ERROR: '/lib/modules/5.7.19-2-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
-> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
reboot with USB iso manjaro
open a terminal and a browser on this topic
and returns
sudo manjaro-chroot -a
uname -a
mhwd-kernel -li
mhwd -li
exit ( quit chroot )
