I received this message when opening my Evolution mail client this morning. I have located the file but cant seem to clear the cache. Please advise.
Failed to generate message list/ Error while Processing folder changes in “INBOX”.
database disk image is malformed (/home/****/.cache/evolution/mail/615309f1e87c050cf48c4fac84e2dced45e9268f/folders.db)
#Evolutionmailclient #manjaroemailcacheremove
Hi and welcome to the Forum
You should be fine to remove that cache dir completely, it will be re-created…
Cache is not the originals…
So just recursively remove the dir: /home/****/.cache/evolution/mail
Recursively means the dir itself plus anything below it…
Hi TriMoon
Thank you for the reply.
I have tried sudo 615309f1e87c050cf48c4fac84e2dced45e9268f -rm -r
What is the correct syntax?
I recently moved over from Ubuntu to Manjaro
Please see man rm
Usage of sudo
and rm
or any other command at all, is same on all distro’s…
sudo command args
Plus you are not trying to remove the dir i mentioned…
Okay thanks , will try that.
Success, thanks very much.
Have a super day.
