Hello,I installed fastfetch and removed neofetch (since is no longer supported)and edited the .basrc file , replaced the “neofetch”at the end of the file with “ fastfetch” and saved.Now when I open terminal I get this on top:
bash: neofetch: command not found
██████████████████ ████████ jesuslinux@A9410
██████████████████ ████████ OS: Manjaro Linux x86_64
██████████████████ ████████ Host: HP Pavilion Notebook
████████ ████████ Kernel: Linux 6.6.107-1-MANJARO
████████ ████████ ████████ Uptime: 4 mins
████████ ████████ ████████ Packages: 1310 (pacman)[stable], 17 (flatpak)
████████ ████████ ████████ Shell: bash 5.3.3
████████ ████████ ████████ Display (CMN15C6): 1366x768 in 16", 60 Hz
████████ ████████ ████████ DE: Xfce4 4.20
████████ ████████ ████████ WM: Xfwm4 (X11)
████████ ████████ ████████ WM Theme: Matcha-dark-sea
████████ ████████ ████████ Theme: Matcha-dark-sea [GTK2/3/4]
████████ ████████ ████████ Icons: Papirus-Dark-Maia [GTK2/3/4]
Font: Noto Sans (10pt) [GTK2/3/4]
Cursor: xcursor-breeze
Terminal: xfce4-terminal 1.1.5
CPU: AMD A9-9410 RADEON R5, 5 COMPUTE CORES 2C+z
GPU: AMD Radeon R5 Graphics [Integrated]
Memory: 1.10 GiB / 7.22 GiB (15%)
Swap: 0 B / 8.00 GiB (0%)
Disk (/): 75.51 GiB / 97.86 GiB (77%) - ext4
Disk (/mnt/488403ff-6c51-46a3-b8f4-c1e685425dc94
Local IP (wlo1):
Battery (Primary): 100% [AC Connected]
Locale: en_US.utf8
Run both commands one after another.First one nothing happened, didn’t find anything.Second one “reopens” the .bashrc and the same very first line says:
Here is my ,bashrc file:
# ~/.bashrc
# If not running interactively, don't do anything
[[ $- != *i* ]] && return
colors() {
local fgc bgc vals seq0
printf "Color escapes are %s\n" '\e[${value};...;${value}m'
printf "Values 30..37 are \e[33mforeground colors\e[m\n"
printf "Values 40..47 are \e[43mbackground colors\e[m\n"
printf "Value 1 gives a \e[1mbold-faced look\e[m\n\n"
# foreground colors
for fgc in {30..37}; do
# background colors
for bgc in {40..47}; do
fgc=${fgc#37} # white
bgc=${bgc#40} # black
vals="${fgc:+$fgc;}${bgc}"
vals=${vals%%;}
seq0="${vals:+\e[${vals}m}"
printf " %-9s" "${seq0:-(default)}"
printf " ${seq0}TEXT\e[m"
printf " \e[${vals:+${vals+$vals;}}1mBOLD\e[m"
done
echo; echo
done
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
# Change the window title of X terminals
case ${TERM} in
xterm*|rxvt*|Eterm*|aterm|kterm|gnome*|interix|konsole*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\007"'
screen*)
PROMPT_COMMAND='echo -ne "\033_${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\033\\"'
esac
use_color=true
# Set colorful PS1 only on colorful terminals.
# dircolors --print-database uses its own built-in database
# instead of using /etc/DIR_COLORS. Try to use the external file
# first to take advantage of user additions. Use internal bash
# globbing instead of external grep binary.
safe_term=${TERM//[^[:alnum:]]/?} # sanitize TERM
match_lhs=""
[[ -f ~/.dir_colors ]] && match_lhs="${match_lhs}$(<~/.dir_colors)"
[[ -f /etc/DIR_COLORS ]] && match_lhs="${match_lhs}$(</etc/DIR_COLORS)"
[[ -z ${match_lhs} ]] \
&& type -P dircolors >/dev/null \
&& match_lhs=$(dircolors --print-database)
[[ $'\n'${match_lhs} == *$'\n'"TERM "${safe_term}* ]] && use_color=true
if ${use_color} ; then
# Enable colors for ls, etc. Prefer ~/.dir_colors #64489
if type -P dircolors >/dev/null ; then
if [[ -f ~/.dir_colors ]] ; then
eval $(dircolors -b ~/.dir_colors)
elif [[ -f /etc/DIR_COLORS ]] ; then
eval $(dircolors -b /etc/DIR_COLORS)
fi
fi
if [[ ${EUID} == 0 ]] ; then
PS1='\[\033[01;31m\][\h\[\033[01;36m\] \W\[\033[01;31m\]]\$\[\033[00m\] '
else
PS1='\[\033[01;32m\][\u@\h\[\033[01;37m\] \W\[\033[01;32m\]]\$\[\033[00m\] '
fi
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
else
# show root@ when we don't have colors
PS1='\u@\h \W \$ '
else
PS1='\u@\h \w \$ '
fi
fi
unset use_color safe_term match_lhs sh
#alias cp="cp -i" # confirm before overwriting something
#alias df='df -h' # human-readable sizes
#alias free='free -m' # show sizes in MB
#alias np='nano -w PKGBUILD'
#alias more=less
xhost +local:root > /dev/null 2>&1
# Bash won't get SIGWINCH if another process is in the foreground.
# Enable checkwinsize so that bash will check the terminal size when
# it regains control. #65623
# http://cnswww.cns.cwru.edu/~chet/bash/FAQ (E11)
shopt -s checkwinsize
shopt -s expand_aliases
# export QT_SELECT=4
# Enable history appending instead of overwriting. #139609
shopt -s histappend
fastfetch
Bash reads multiple files, from ~/bash_profile~/bash_login, ~/profile for interactive login shells… so you have to locate any reference to neofetch there too.
Additionally, in Konsole, you can set a ‘command to run’ when opening a terminal.
I deleted from the last line and save the file and now it no longer appears!Thank you!I didn’t get this:
Also consider an abbreviation to clear before running fastfetch to make it render cleanly:
ff 'clear; fastfetch'
Or simply do something better entirely:
matrix 'tmatrix -s 30 -f 0.3,0.6'
