Remove systemd ctlr+alt+del shortcut that reboots
I’ve noticed ctrl+alt+del forces a reboot of the entire system. Oddly it used to to take me to a the confirmation screen with a set of options (sleep, hibernate, restart, shut down etc…) but now pressing the keys automatically forces the reboot. I’d like to return to the old command, I’ve found it under system settings but even if it’s set to ctlr+alt+delete the system reboots.
From a bit of researching it seems this is a standard systemd command that’s overriding the one I want to use.
Does anyone have any idea how to disable this systemd default shortcut?
Mask service:
sudo systemctl mask ctrl-alt-del.target
sudo systemctl daemon-reload
or set in /etc/systemd/system.conf this line:
CtrlAltDelBurstAction=none
Thanks for the quick response.
I tried the second option but no sucess. I’ve run the first but
sudo systemctl reload
returned
Too few arguments
perhaps did you mean
daemon-reload
It seems it was daemon-reload! that’s resolved the issue
Yes, you are right. Fixed :wink:
