Remove pulseaudio ask me to remove gnome shell too
Hi, i am looking to switch to Pipewire and try to follow the instructions available on the forum.
When I try to remove Pulseaudio I get the message to remove, a lot… of Gnome related stuff. Any one an idea to prevent removing all the gnome stuff?
Thanks!
You should not remove pulseaudio. The proper way is to replace it with pipewire by just installing manjaro-pipewire.
Those packages that come along with that package mentioned above provide the pulseaudio dependencies needed by other packages like gnome-shell, etc.
I found the answer >> Pipewire-pulse installation problem - #7 by Aragorn
