Remove LUKS Encryption
How to remove LUKS encryption completely?
I installed Manjaro-gnome-20.04 on 256 GB NVMe with LUKS encryption on boot. I want to remove LUKS encryption (I know the passphrase).
Thanks.
I never used LUKS, but it should be:
  1. Backup your data
  2. Delete the Partitions
  3. Reinstall without LUKS
  4. Restore Backup
To remove LUKS, I have tried the following but so far I have been failed:
  1. Re-installing Manjaro (the setup terminates in the partition stage)
  2. Re-installing LINUX MINT (the setup terminates in the partition stage)
  3. Using arch live iso to create new partition table (But after finalizing new partition table, i see the old partitions when I hit “lsblk”)
  4. Tried “sudo dd bs=4M if=/dev/zero of=/dev/nvme0n1p2 status=progress”
  5. Using arch wiki help cryptsetup-reencypt --decrypt /dev/nvme0n1p2 with Arch live USB
You can actually decrypt without reinstalling. But i guess with the dd command, things are messed up now, so:
Before installing, open gparted in the live session and wipe out the partitions.
Although no longer useful to @masaud, it would be helpful to users of the search function if the answer to the question was actually posted in the thread.
Hello,
I have luks encryption on NVME.
I am failed to remove encryption after trying five different approaches.
I have posted it also in forum. Here is the link Remove LUKS Encryption
Please guide me to remove it. I have been trying but getting nowhere.
Data is not important. I just want my NVME back.
Thanks
Since you hare tried just about everything - I suspect the encryption is implemented by the hardware.
One thing caught my eye - you have not zapped your device only content of the partition - which leaves the partition table behind.
Possible methods to clear a disk
:warning: To avoid someone copy pasting thus wiping their primary disk - replace $DEViCE with the actual device - in this context /dev/nvme0n1 - don’t append any partitions - just the device path.
Any one of the following commands should should be enough - but you can use all three if you like.
Execute as root (adding a failsafe layer to the listed commands)
:exclamation: Removes all traces of partition information including super blocks etc.
# sgdisk --zapall $DEVICE
:exclamation: Write zeroes to the first 10M - effectively removing partition information
# dd if=/dev/zero of=$DEVICE bs=1M count=10
:exclamation: Creates a new GPT partition table with a single unformatted partition of Linux filesystem type
# printf 'o\ny\nn\n\n\n\n\nw\ny\n' | gdisk $DEVICE
SSD memory cell cleaing
(From my notes at nix.dk)
