wael
11 April 2023 11:45
1
I have the following outputs:
❯ sudo mhwd-kernel -li
Currently running: 6.1.23-1-MANJARO (linux61)
* linux61
* linux62
❯ pacman -Q | grep "^linux"
linux-api-headers 6.1.9-1
linux-firmware 20230310.588dd07-1
linux-firmware-whence 20230310.588dd07-1
linux61 6.1.23-1
linux61-virtualbox-host-modules 7.0.6-21
linux62 6.2.10-1
linux62-virtualbox-host-modules 7.0.6-12
so far, everything ok. but on the other hand :
❯ ls -l /boot
drwx------ - root 1 Jan 1970 efi
drwxr-xr-x - root 11 Apr 11:33 grub
drwxr-xr-x - root 12 Feb 11:23 memtest86+
.rw-r--r-- 51k root 1 Apr 05:39 amd-ucode.img
.rw------- 37M root 16 Jun 2022 initramfs-5.18-rt-x86_64-fallback.img
.rw------- 8,5M root 16 Jun 2022 initramfs-5.18-rt-x86_64.img
.rw------- 38M root 11 Apr 11:17 initramfs-6.1-x86_64-fallback.img
.rw------- 9,1M root 11 Apr 11:17 initramfs-6.1-x86_64.img
.rw------- 40M root 11 Apr 11:33 initramfs-6.2-x86_64-fallback.img
.rw------- 9,2M root 11 Apr 11:33 initramfs-6.2-x86_64.img
.rw-r--r-- 21 root 6 Apr 19:13 linux61-x86_64.kver
.rw-r--r-- 21 root 6 Apr 19:12 linux62-x86_64.kver
.rw-r--r-- 21 root 22 Dez 2020 linux510-x86_64.kver.old
.rw-r--r-- 10,0M root 16 Jun 2022 vmlinuz-5.18-rt-x86_64
.rw-r--r-- 11M root 11 Apr 10:44 vmlinuz-6.1-x86_64
.rw-r--r-- 13M root 11 Apr 11:33 vmlinuz-6.2-x86_64
These entries are also present in the GRUB!
Then I deleted as described in How to remove a “ghost-kernel”? these files!
/boot🔒
❯ sudo rm initramfs-5.18-rt-x86_64.img
[sudo] Passwort für wael:
/boot🔒 took 3s
❯ sudo rm initramfs-5.18-rt-x86_64-fallback.img
/boot🔒
❯ sudo rm vmlinuz-5.18-rt-x86_64
/etc🔒
❯ cd /etc/mkinitcpio.d
/etc/mkinitcpio.d🔒
❯ sudo rm linux54.preset.pacsave linux58.preset.pacsave linux59.preset.pacsave linux510.preset.pacsave linux511.preset.pacsave
/etc/mkinitcpio.d🔒
❯ sudo rm linux512.preset.pacsave linux514.preset.pacsave linux515.preset.pacsave
/etc/mkinitcpio.d🔒
❯ sudo rm linux515-rt.preset.pacsave linux516.preset.pacsave linux517.preset.pacsave linux518.preset.pacsave
/etc/mkinitcpio.d🔒
❯ sudo rm linux518-rt.preset linux519.preset.pacsave
/etc/mkinitcpio.d🔒
❯ sudo rm linux60.preset
/etc/mkinitcpio.d🔒
❯ sudo pacman -Qs linux518-
/etc/mkinitcpio.d🔒
❯ sudo pacman -Qs linux515-
/etc/mkinitcpio.d🔒
❯ sudo mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.1.23-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [resume]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'default'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64.img --microcode /boot/amd-ucode.img
==> Starting build: '6.2.10-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.2-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'fallback'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.2-x86_64-fallback.img'
/etc/mkinitcpio.d🔒 took 28s
❯ sudo update-grub
GRUB-Konfigurationsdatei wird erstellt …
Thema gefunden: /usr/share/grub/themes/manjaro/theme.txt
Linux-Abbild gefunden: /boot/vmlinuz-6.2-x86_64
initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-6.2-x86_64.img
Found initrd fallback image: /boot/initramfs-6.2-x86_64-fallback.img
Linux-Abbild gefunden: /boot/vmlinuz-6.1-x86_64
initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
/etc/grub.d/bin/grubcfg_proxy: /usr/lib/libcrypto.so.1.1: version `OPENSSL_1_1_0' not found (required by /etc/grub.d/bin/grubcfg_proxy)
/etc/grub.d/proxifiedScripts/linux: Zeile 208: version_find_latest: Kommando nicht gefunden.
/etc/mkinitcpio.d🔒
after a cold start, the GRUB MENU has not changed at all!
Questions:
how can I remove these entries? and what about the error message in ‘update-grub’: (DE → EN)
/etc/grub.d/proxifiedScripts/linux: line 208: version_find_latest: command not found.
a long time ago I installed ‘grub-customizer’ and then uninstalled it again! maybe it’s related?
why is the new kernel 6.2 not used?
Thanks for your help
PS: I use Manjaro KDE since 2.5 years (my first Ditsro), but this is my first post here.
You don’t say how you installed/uninstalled 5.10 and 5.18.
But somehow there are leftovers from 5.10 and 5.18. (maybe not only in /boot). They are useless now and should be removed. But be careful not to break the current kernel.
Then please also look in /usr/lib/modules
Did you stop GRUB at boot to select the other kernel ?
You can also use maxi -eg
to collect information about the boot process. This works,
when you are in your running system (with CTRL +ALT +F2 ).
And also in a live environment
If your manjaro installation does not boot (any more), maxi may help to find what is missing
wael
11 April 2023 12:51
3
it’s been a while… either they were uninstalled automatically or I did it via the GUI.
❯ /usr/lib/modules
/usr/lib/modules🔒
❯ ls
drwxr-xr-x - root 11 Apr 10:44 6.1.23-1-MANJARO
drwxr-xr-x - root 11 Apr 11:33 6.2.10-1-MANJARO
drwxr-xr-x - root 20 Jan 2021 extramodules-5.10-MANJARO
drwxr-xr-x - root 11 Apr 10:44 extramodules-6.1-MANJARO
drwxr-xr-x - root 11 Apr 11:33 extramodules-6.2-MANJARO
/usr/lib/modules🔒
❯ cd extramodules-5.10-MANJARO/
lib/modules/extramodules-5.10-MANJARO🔒
❯ ls
.rw-r--r-- 17 root 22 Dez 2020 version.old
yes, i can’t see the new Kernel
What files are inside the /etc/mkinitcpio.d/
.pacsave are just backup save files which are safe to delete.
.preset are the kernels that are installed and ready to run from grub.
So delete any .preset files of the kernels you are removing/don’t need then do a ‘mkinitcpio -P’ and ‘update-grub’
Please DO NOT DELETE the .preset file/files for the kernels you need/installed.
wael
11 April 2023 13:23
5
❯ ls /etc/mkinitcpio.d/
.rw-r--r-- 588 root 11 Apr 10:44 linux61.preset
.rw-r--r-- 588 root 11 Apr 11:33 linux62.preset
i first need to make sure i can use kernel 6.2! also i would keep kernel 6.1 (LTS)!
Yes keep 6.1 just in case something bad happens,
Did you do
sudo mkinitcpio -P
and then
sudo update-grub
wael
11 April 2023 13:28
7
yes, i did. Grub-menu has not changed unfortunately!
For info:
I can use the system normally, I had no problems all the time. but now I want to get rid of these problems.
wael
11 April 2023 13:37
8
and why do I have the entries twice !!??
You could try just ‘sudo grub-mkconfig’ and ‘sudo update-grub’ and see if that works.
Not sure, only option i have left is this:
but you need to follow the instructions for either BIOS (old mode) or UEFI,
** IF YOU DO THIS WRONG YOU WILL NOT BE ABLE TO BOOT YOUR SYSTEM **
In my case as i have my bios set to CSM mode (BIOS BOOT/OLD MODE) all i have to do is
sudo grub-install /dev/sda
‘sda’ is the boot drive/mbr drive, you will need to check what your drive name is.
and
sudo grub-mkconfig
I personally think this , that @TheReaperUK suggested, would be the way to go…
wael
11 April 2023 15:09
11
not sure how to do this with chroot!
I have an EFI system with:
❯ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:2 0 476,9G 0 disk
├─nvme0n1p1 259:3 0 260M 0 part
├─nvme0n1p2 259:4 0 16M 0 part
├─nvme0n1p3 259:5 0 100G 0 part
├─nvme0n1p4 259:6 0 1000M 0 part
├─nvme0n1p5 259:7 0 100G 0 part /
├─nvme0n1p6 259:8 0 50G 0 part
├─nvme0n1p10 259:10 0 67,7G 0 part
└─nvme0n1p11 259:11 0 8G 0 part [SWAP]
❯ lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/nvme0n1 gpt
/dev/nvme0n1p1 gpt c12a7328-f81f-11d2-ba4b-00a0c93ec93b vfat EFI System
/dev/nvme0n1p2 gpt e3c9e316-0b5c-4db8-817d-f92df00215ae Microsoft reserved
/dev/nvme0n1p3 gpt ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 ntfs Microsoft basic data
/dev/nvme0n1p4 gpt de94bba4-06d1-4d40-a16a-bfd50179d6ac ntfs Windows recovery environment
/dev/nvme0n1p5 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p6 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p8 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p10 gpt 0fc63daf-8483-4772-8e79-3d69d8477de4 ext4 Linux filesystem
/dev/nvme0n1p11 gpt 0657fd6d-a4ab-43c4-84e5-0933c84b4f4f swap Linux swap
shoud i reinstall GRUB:
pacman -Syu grub
How to bee in chroot for next procedure?
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Update the grub configuration
grub-mkconfig -o /boot/grub/grub.cfg
Please be carefull. Its not good to mess up a booting system in trying to repair a problem you do not understand jet.
This could indeed be the origin of your issue… Uninstalling does not repair the damage the use of this tool could have caused.
Can’t really help you as your using EFI, but did you try at least doing:
sudo grub-mkconfig
and
sudo update-grub
From terminal?
omano
11 April 2023 17:08
15
GRUB update fails so this is why the menu doesn’t change. This is what you need to fix now.
I don’t know what grubcfg_proxy is, probably something you installed. Maybe you’re a user of GRUB Customizer?
wael
11 April 2023 19:17
16
yes, several times.
❯ sudo grub-mkconfig
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="Manjaro Linux"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_gpt
insmod ext2
search --no-floppy --fs-uuid --set=root bd1d44ca-91e0-4a22-b906-6d798639c31c
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=de_DE
insmod gettext
fi
terminal_input console
terminal_output gfxterm
insmod part_gpt
insmod ext2
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=0
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/06_grub-customizer_menu_color_helper ###
### END /etc/grub.d/06_grub-customizer_menu_color_helper ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-6.2-x86_64 root=UUID=bd1d44ca-91e0-4a22-b906-6d798639c31c rw quiet resume=LABEL=swap apparmor=1 security=apparmor udev.log_priority=3
initrd /boot/amd-ucode.img /boot/initramfs-6.2-x86_64.img
submenu 'Erweiterte Optionen für Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
menuentry 'Manjaro Linux (Kernel: 6.2.10-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.2.10-1-MANJARO x64-advanced-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
menuentry 'Manjaro Linux (Kernel: 6.2.10-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.2.10-1-MANJARO x64-fallback-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /boot/initramfs-6.2-x86_64-fallback.img
menuentry 'Manjaro Linux (Kernel: 6.2.10-1-MANJARO x64 - recovery mode)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.2.10-1-MANJARO x64-recovery-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-6.2-x86_64 root=UUID=bd1d44ca-91e0-4a22-b906-6d798639c31c rw single
menuentry 'Manjaro Linux (Kernel: 6.1.23-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.1.23-1-MANJARO x64-advanced-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-6.1-x86_64 root=UUID=bd1d44ca-91e0-4a22-b906-6d798639c31c rw quiet resume=LABEL=swap apparmor=1 security=apparmor udev.log_priority=3
initrd /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
menuentry 'Manjaro Linux (Kernel: 6.1.23-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.1.23-1-MANJARO x64-fallback-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
initrd /boot/initramfs-6.1-x86_64-fallback.img
menuentry 'Manjaro Linux (Kernel: 6.1.23-1-MANJARO x64 - recovery mode)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-6.1.23-1-MANJARO x64-recovery-bd1d44ca-91e0-4a22-b906-6d798639c31c' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-6.1-x86_64 root=UUID=bd1d44ca-91e0-4a22-b906-6d798639c31c rw single
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/10_linux_proxy ###
❯ sudo update-grub
wael
11 April 2023 19:34
17
As written above I installed ‘grub-customizer’ a long time ago and then uninstalled it because it no longer works, I think!
at that time I had changed the default boot option and the timeout because of dual boot. nothing more.
here are the contents of /etc/grub.d/
/etc/grub.d🔒
❯ ls
drwxr-xr-x - root 16 Dez 2020 backup
drwxr-xr-x - root 16 Dez 2020 bin
drwxr-xr-x - root 1 Jan 2021 proxifiedScripts
.rwxr-xr-x 8,9k root 5 Apr 16:07 00_header
.rwxr-xr-x 270 root 16 Dez 2020 06_grub-customizer_menu_color_helper
.rwxr-xr-x 14k root 5 Apr 16:07 10_linux
.rwxr-xr-x 1,1k root 1 Jan 2021 10_linux_proxy
.rwxr-xr-x 14k root 5 Apr 16:07 20_linux_xen
.rwxr-xr-x 13k root 5 Apr 16:07 30_os-prober
.rwxr-xr-x 1,1k root 5 Apr 16:07 30_uefi-firmware
.rwxr-xr-x 722 root 31 Mär 13:15 35_fwupd
.rwxr-xr-x 214 root 5 Apr 16:07 40_custom
.rwxr-xr-x 215 root 5 Apr 16:07 41_custom
.rwxr-xr-x 1,2k root 9 Feb 22:50 60_memtest86+
.rw-r--r-- 483 root 5 Apr 16:07 README
and here is the content of /etc/grub.d/10_linux_proxy
/etc/grub.d🔒
❯ cat 10_linux_proxy
#!/bin/sh
#THIS IS A GRUB PROXY SCRIPT
'/etc/grub.d/proxifiedScripts/linux' | /etc/grub.d/bin/grubcfg_proxy "+*
+#text
+'Manjaro Linux'~45e4e0c2642df9ef3359acf9967ec5c4~
+'SUBMENU' as 'Advanced options for Manjaro Linux'{+'Advanced options for Manjaro Linux'/*, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.9.11-3-MANJARO x64 - recovery mode)'~16b24cbd5c90da0c5512ac626748fd2b~, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.8.18-1-MANJARO x64 - recovery mode)'~5e6561432a1faaf58d573de367c9b5cb~, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.9.11-3-MANJARO x64)'~c6aa1bf901b9800096e0626423c516f0~, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.9.11-3-MANJARO x64 - fallback initramfs)'~aaacd5aefa257f93fe8f326964286927~, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.8.18-1-MANJARO x64)'~eee413f187f9a4d402691abaaa3935be~, +'Advanced options for Manjaro Linux'/'Manjaro Linux (Kernel: 5.8.18-1-MANJARO x64 - fallback initramfs)'~220f80c8f088889445559f2f690fc74f~}
cscs
11 April 2023 20:27
19
Just gonna drop this here.
gcspt.sh
#!/usr/bin/env bash
gcspt=$(find /boot/ -type f -name grub.cfg);
initz=$(find /boot/ -type f -name 'initramfs*' | sort);
imgz=$(find /boot/ -type f -name 'vmlinuz*' | sort);
modz=$(find /lib/modules/ -maxdepth 1 -type d | sort);
mkinitz=$(find /etc/ -type f -name 'mkinitcpio*' 2>/dev/null | sort);
mkinitzd=$(find /etc/mkinitcpio.d -type f | sort);
printf '\n...Bite-Sized Boot-Info...\n';
printf "\nCurrently Running Kernel:\n$(hostnamectl | tail -n6 | head -n1 | awk '{ print $NF }')\n";
printf '\nGrub Configuration File:\n';
echo $gcspt | while read in; do ls -l --time-style=+'%F %R' "$in" | cut --complement -d ' ' -f1,2,3,4,5; done | column -t;
printf '\nInstalled Kernels:\n';
echo "$imgz" | while read in; do ls -l --time-style=+'%F %R' "$in" | cut --complement -d ' ' -f1,2,3,4,5; done | column -t;
printf '\nInitramfs Images:\n';
echo "$initz" | while read in; do ls -l --time-style=+'%F %R' "$in" | cut --complement -d ' ' -f1,2,3,4,5; done | column -t;
printf '\nmkinitcpio:\n';
echo "$mkinitz" | while read in; do ls -l --time-style=+'%F %R' "$in" | cut --complement -d ' ' -f1,2,3,4,5; done | column -t;
echo "$mkinitzd" | while read in; do ls -l --time-style=+'%F %R' "$in" | cut --complement -d ' ' -f1,2,3,4,5; done | column -t;
printf '\nModule Directories:\n';
for i in $modz; do du --time --time-style=+'%F %R' -sh $i; done | awk '{print $2,$3,$4,$1}' | column -t;
printf '\nHibernation:\n'; grep -o 'resume=' /etc/default/grub || printf 'No "resume=" option found in /etc/default/grub\n\n'
Remember to make sure to check if a package own a directory before manually removing it.
pacman -Qo /lib/modules/5.10.17-1-MANJARO
PS.
wael:
‘grub-customizer’
Friendly reminder to anyone reading this. Please dont use this software.
wael
11 April 2023 21:19
20
unfortunately i can’t understand what your script does. nevertheless i solved the problem differently. but you are right, ‘grub-customizer’ is to blame!
This is no surprise.
Would you be so kind to let us know how exactly?
