Remove automatic start of programs
Good evening Manjaro community,
I have Manjaro Linux, minimal LXDE version installed on my machine (really with very few resources).
Today, when I turned on the machine, the system started normally, however, the Task Manager also started together, showing the window.
I don’t have graphical interface to check which programs are being started along with the system (at least I don’t think so).
Where can I check which programs are starting and how can I disable them (as in the case of the task manager)?
  Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=4c99a061-31b7-445a-ad39-2ef99ad4a052 rw quiet udev.log_priority=3
  Desktop: LXDE 0.10.1 info: lxpanel wm: Openbox 3.6.1 vt: 7
  Type: Desktop Mobo: INTEL model: H81 serial: <filter>
  UEFI: American Megatrends v: 4.6.5 date: 10/21/2020
  RAM: total: 7.72 GiB used: 1.57 GiB (20.3%)
  Info: Dual Core model: Intel Pentium G3250 bits: 64 type: MCP arch: Haswell
  family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 3 MiB
  bogomips: 12777
  Speed: 3193 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 3193 2: 3193
  Flags: abm acpi aperfmperf apic arat arch_perfmon bts clflush cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
  ept_ad erms est flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
  invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
  pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep ss ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
  tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
  class-ID: 0300
  Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati
  unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4")
  s-diag: 762mm (30")
  Monitor-1: HDMI-A-0 res: 1920x1080 hz: 75 dpi: 82
  size: 598x336mm (23.5x13.2") diag: 686mm (27")
  Monitor-2: DVI-D-0 res: 1920x1080 hz: 60 dpi: 69
  size: 708x398mm (27.9x15.7") diag: 812mm (32")
  Device-1: Intel 8 Series/C220 Series High Definition Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
  vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 1002:aae0 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
  class-ID: 0200
  Local Storage: total: 223.57 GiB used: 4.86 GiB (2.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
  size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 61K1 scheme: GPT
  ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%) used: 4.86 GiB (2.2%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 4c99a061-31b7-445a-ad39-2ef99ad4a052
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 84A3-A666
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
  Device-1: 3-9:2 info: Dell KB216 Wired Keyboard type: Keyboard,HID
  power: 100mA chip-ID: 413c:2113 class-ID: 0300
  Device-2: 3-10:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 37.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1202
  Processes: 168 Uptime: 11m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 652 lib: 152 Shell: Zsh v: 5.8
  running-in: lxterminal inxi: 3.3.06
PAMAC LIST
accountsservice                   0.6.55-3                    extra      1,1 MB
acl                               2.3.1-1                     core       333,2 kB
acpi                              1.7-3                       community  28,2 kB
acpid                             2.0.32-2                    community  156,4 kB
adobe-source-code-pro-fonts       2.038ro+1.058it+1.018var-1  extra      1,9 MB
adwaita-icon-theme                40.1.1-1                    extra      23,6 MB
alsa-firmware                     1.2.4-2                     extra      14,8 MB
alsa-lib                          1.2.5.1-3                   extra      1,7 MB
alsa-plugins                      1:1.2.5-2                   extra      356,1 kB
alsa-topology-conf                1.2.5.1-1                   extra      343,8 kB
alsa-ucm-conf                     1.2.5.1-1                   extra      183,3 kB
alsa-utils                        1.2.5.1-1                   extra      2,3 MB
aom                               3.1.2-1                     extra      9,2 MB
appstream-glib                    0.7.18-3                    extra      3,8 MB
archlinux-appstream-data          20210723-1                  extra      20,6 MB
archlinux-keyring                 20210802-1                  core       1,4 MB
argon2                            20190702-3                  core       116,2 kB
at-spi2-atk                       2.38.0-1                    extra      230,4 kB
at-spi2-core                      2.40.3-1                    extra      2,3 MB
atk                               2.36.0-1                    extra      3,7 MB
atkmm                             2.28.2-2                    extra      558,8 kB
attr                              2.5.1-1                     core       212,6 kB
audit                             3.0.3-1                     core       1,1 MB
avahi                             0.8+20+gd1e71b3-1           extra      1,9 MB
b43-fwcutter                      019-3                       core       66,0 kB
bash                              5.1.008-3                   core       8,6 MB
bashrc-manjaro                    5.1.008-3                   core       4,4 kB
binutils                          2.36.1-3                    core       46,8 MB
bluez-libs                        5.60-1                      extra      333,2 kB
botan                             2.18.1-1                    extra      9,6 MB
brotli                            1.0.9-4                     extra      2,7 MB
btrfs-progs                       5.13.1-1                    core       5,4 MB
bubblewrap                        0.4.1-2                     extra      59,8 kB
bzip2                             1.0.8-4                     core       147,7 kB
ca-certificates                   20210603-1                  core
ca-certificates-mozilla           3.69-1                      core       924,9 kB
ca-certificates-utils             20210603-1                  core       6,2 kB
cairo                             1.17.4-5                    extra      1,8 MB
cairomm                           1.14.3-2                    extra      413,6 kB
cantarell-fonts                   1:0.301-1                   extra      705,1 kB
celt                              0.11.3-4                    extra      180,1 kB
chromium                          92.0.4515.159-1             extra      241,9 MB
cifs-utils                        6.13-2                      extra      262,8 kB
ckbcomp                           1.204-1                     extra      149,8 kB
coreutils                         8.32-1                      core       16,8 MB
cpupower                          5.13-1                      community  464,7 kB
crda                              4.14-4                      core       234,4 kB
cronie                            1.5.7-2                     core       248,0 kB
cryptsetup                        2.3.6-1                     core       2,7 MB
curl                              7.78.0-1                    core       1,8 MB
dav1d                             0.9.1-1                     extra      1,4 MB
db                                5.3.28-5                    core       6,7 MB
dbus                              1.12.20-1                   core       988,1 kB
dbus-glib                         0.112-2                     extra      815,2 kB
dbus-python                       1.2.18-1                    extra      5,7 MB
dconf                             0.40.0-1                    extra      459,0 kB
desktop-file-utils                0.26-1                      extra      208,5 kB
device-mapper                     2.03.13-1                   core       865,7 kB
dhclient                          4.4.2.P1-1                  extra      3,0 MB
dhcpcd                            9.4.0-1                     core       496,2 kB
diffutils                         3.8-1                       core       1,5 MB
ding-libs                         0.6.1-3                     core       665,9 kB
dmidecode                         3.3-1                       extra      204,9 kB
dmraid                            1.0.0.rc16.3-13             core       332,7 kB
dnsmasq                           2.85-1                      extra      827,0 kB
dnssec-anchors                    20190629-3                  core       809 bytes
dosfstools                        4.2-1                       core       447,4 kB
double-conversion                 3.1.5-2                     extra      172,6 kB
e2fsprogs                         1.46.3-3                    core       5,1 MB
ecryptfs-utils                    111-4                       community  590,1 kB
efibootmgr                        17-2                        core       79,9 kB
efivar                            37-4                        core       373,6 kB
elfutils                          0.185-1                     core       3,6 MB
enchant                           2.3.0-1                     extra      222,8 kB
engrampa                          1.26.0-1                    community  13,7 MB
epdfview                          0.1.8-11                    community  401,2 kB
exfat-utils                       1.3.0-2                     community  264,6 kB
expac                             10-3                        community  36,0 kB
expat                             2.4.1-1                     core       400,7 kB
f2fs-tools                        1.14.0-2                    extra      559,1 kB
ffmpeg                            2:4.4-4                     extra      35,6 MB
file                              5.40-5                      core       7,2 MB
filesystem                        2021.01.19-1                core       8,0 kB
findutils                         4.8.0-1                     core       1,7 MB
flac                              1.3.3-3                     extra      1,1 MB
fontconfig                        2:2.13.94-1                 extra      780,7 kB
freetype2                         2.10.4-1                    extra      1,7 MB
fribidi                           1.0.10-1                    extra      223,6 kB
fuse-common                       3.10.4-1                    extra      694 bytes
fuse2                             2.9.9-4                     extra      469,2 kB
fuse3                             3.10.4-1                    extra      462,2 kB
fzf                               0.27.2-1                    community  3,3 MB
galculator                        2.1.4-5                     community  1,4 MB
gawk                              5.1.0-1                     core       2,8 MB
gc                                8.0.4-4                     extra      767,5 kB
gcab                              1.4-1                       extra      394,4 kB
gcc                               11.1.0-1                    core       158,6 MB
gcc-libs                          11.1.0-1                    core       128,3 MB
gcr                               3.40.0-1                    extra      6,1 MB
gdbm                              1.20-1                      core       695,1 kB
gdk-pixbuf2                       2.42.6-2                    extra      3,1 MB
gettext                           0.21-1                      core       7,9 MB
giflib                            5.2.1-2                     extra      314,1 kB
git                               2.32.0-1                    extra      33,9 MB
glib-networking                   1:2.68.1-1                  extra      561,6 kB
glib2                             2.68.3-1                    core       15,8 MB
glibc                             2.33-5                      core       48,2 MB
glibmm                            2.66.1-2                    extra      6,1 MB
gmp                               6.2.1-1                     core       1,0 MB
gnome-icon-theme                  3.12.0-6                    community  10,3 MB
gnome-icon-theme-symbolic         3.12.0-6                    extra      2,0 MB
gnome-keyring                     1:40.0-1                    extra      4,5 MB
gnome-themes-extra                3.28-2                      extra      4,7 MB
gnupg                             2.2.29-1                    core       10,4 MB
gnutls                            3.7.2-2                     core       7,1 MB
gobject-introspection-runtime     1.68.0-1                    extra      862,8 kB
gparted                           1.3.1-1                     extra      7,6 MB
gpgme                             1.16.0-1                    core       1,3 MB
gpicview                          0.2.5-6                     community  444,0 kB
gpm                               1.20.7.r38.ge82d1a6-3       core       433,0 kB
gptfdisk                          1.0.8-1                     extra      828,7 kB
graphite                          1:1.3.14-1                  extra      699,4 kB
grep                              3.6-1                       core       756,6 kB
groff                             1.22.4-6                    core       10,2 MB
grub                              2.06-1                      core       50,2 MB
gsettings-desktop-schemas         40.0-3                      extra      4,7 MB
gsm                               1.0.19-1                    extra      104,5 kB
gssproxy                          0.8.4-1                     core       259,6 kB
gst-plugins-base-libs             1.18.4-1                    extra      11,2 MB
gstreamer                         1.18.4-1                    extra      10,4 MB
gtk-engine-murrine                0.98.2-4                    community  319,6 kB
gtk-engines                       2.21.0-5                    extra      1,2 MB
gtk-update-icon-cache             1:4.2.1-2                   extra      36,9 kB
gtk2                              2.24.33-2                   extra      38,1 MB
gtk3                              1:3.24.30-2                 extra      50,9 MB
gtkmm3                            3.24.5-2                    extra      9,7 MB
gufw                              21.04.0-1                   community  3,4 MB
guile                             2.2.7-1                     extra      46,2 MB
gvfs                              1.48.1-1                    extra      5,4 MB
gvfs-nfs                          1.48.1-1                    extra      55,3 kB
gvfs-smb                          1.48.1-1                    extra      94,6 kB
gzip                              1.10-3                      core       160,7 kB
harfbuzz                          2.8.2-1                     extra      5,5 MB
harfbuzz-icu                      2.8.2-1                     extra      17,8 kB
hdparm                            9.62-1                      core       192,5 kB
hicolor-icon-theme                0.17-2                      extra      55,5 kB
hidapi                            0.10.1-1                    community  93,7 kB
htop                              3.0.5-1                     extra      282,4 kB
hunspell                          1.7.0-3                     extra      803,2 kB
hwids                             20210613-1                  core       2,0 MB
hwinfo                            21.76-1                     community  3,8 MB
hyphen                            2.8.8-3                     extra      33,7 kB
iana-etc                          20210728-1                  core       4,1 MB
icu                               69.1-1                      core       39,8 MB
imlib2                            1.7.3-1                     extra      1,3 MB
inetutils                         2.1-1                       core       1,2 MB
intel-ucode                       20210608-1                  extra      4,8 MB
inxi                              3.3.06.1-1                  community  962,9 kB
iproute2                          5.13.0-1                    core       3,3 MB
iptables                          1:1.8.7-1                   core       2,5 MB
iputils                           20210722-1                  core       430,3 kB
iso-codes                         4.6.0-1                     extra      19,4 MB
iw                                5.9-1                       core       286,0 kB
jack2                             1.9.19-2                    extra      2,7 MB
jansson                           2.13.1-1                    community  187,1 kB
jfsutils                          1.1.15-7                    core       1,1 MB
js78                              78.13.0-1                   extra      67,4 MB
json-c                            0.15-1                      core       177,5 kB
json-glib                         1.6.2-1                     extra      1,8 MB
kauth                             5.85.0-1                    extra      986,2 kB
kbd                               2.4.0-2                     core       3,0 MB
kcoreaddons                       5.85.0-1                    extra      4,2 MB
keyutils                          1.6.3-1                     core       202,1 kB
kitemmodels                       5.85.0-1                    extra      1,7 MB
kmod                              29-1                        core       301,3 kB
krb5                              1.19.1-1                    core       4,7 MB
kvantum-qt5                       0.20.1-1                    community  7,9 MB
kvantum-theme-matcha              20190810-1                  community  2,4 MB
kwindowsystem                     5.85.0-1                    extra      1,9 MB
l-smash                           2.14.5-2                    extra      1,1 MB
lame                              3.100-3                     extra      959,1 kB
lcms2                             2.12-1                      extra      683,0 kB
ldb                               2:2.3.0-1                   extra      889,6 kB
ldns                              1.7.1-2                     core       1,9 MB
leafpad                           0.8.18.1-9                  extra      308,3 kB
less                              1:590-1                     core       267,9 kB
libaio                            0.3.112-2                   core       22,5 kB
libappindicator-gtk3              12.10.0.r296-1              community  359,5 kB
libarchive                        3.5.1-1                     core       1,1 MB
libass                            0.15.1-1                    extra      253,3 kB
libassuan                         2.5.5-1                     core       218,1 kB
libasyncns                        0.8+3+g68cd5af-3            extra      48,8 kB
libatasmart                       0.19-5                      extra      105,2 kB
libavc1394                        0.5.4-4                     extra      121,1 kB
libblockdev                       2.25-2                      extra      1,6 MB
libbluray                         1.3.0-1                     extra      1,3 MB
libbsd                            0.11.3-1                    extra      351,4 kB
libbytesize                       2.6-1                       extra      91,0 kB
libcanberra                       0.30+2+gc0620e4-5           extra      448,2 kB
libcap                            2.51-1                      core       209,6 kB
libcap-ng                         0.8.2-3                     core       125,3 kB
libcddb                           1.3.2-6                     extra      164,0 kB
libcdio                           2.1.0-2                     extra      972,0 kB
libcdio-paranoia                  10.2+2.0.1-2                extra      167,4 kB
libcloudproviders                 0.3.1-2                     extra      490,4 kB
libcolord                         1.4.5-4                     extra      1,3 MB
libcroco                          0.6.13-2                    extra      1,2 MB
libcups                           1:2.3.3op2-3                extra      884,1 kB
libdaemon                         0.14-5                      extra      59,7 kB
libdatrie                         0.2.13-1                    extra      70,8 kB
libdbusmenu-glib                  16.04.0-4                   community  376,3 kB
libdbusmenu-gtk3                  16.04.0-4                   community  139,5 kB
libdrm                            2.4.107-1                   extra      993,8 kB
libedit                           20210522_3.1-1              core       279,5 kB
libelf                            0.185-1                     core       3,0 MB
libepoxy                          1.5.9-1                     extra      3,4 MB
libevdev                          1.11.0-1                    extra      260,5 kB
libevent                          2.1.12-1                    core       1,2 MB
libexif                           0.6.22-1                    extra      2,6 MB
libffi                            3.3-4                       core       94,6 kB
libfm                             1.3.2-1                     community  4,3 MB
libfm-extra                       1.3.2-1                     community  38,0 kB
libfm-gtk3                        1.3.2-1                     community  552,8 kB
libfontenc                        1.1.4-3                     extra      40,4 kB
libgcrypt                         1.9.3-1                     core       1,5 MB
libglvnd                          1.3.3-1                     extra      3,9 MB
libgpg-error                      1.42-1                      core       1,0 MB
libgudev                          237-1                       extra      404,6 kB
libhandy                          1.2.3-1                     extra      4,2 MB
libibus                           1.5.24-1                    extra      97,8 MB
libice                            1.0.10-3                    extra      369,7 kB
libid3tag                         0.15.1b-11                  extra      126,1 kB
libidn2                           2.3.2-1                     core       462,9 kB
libiec61883                       1.2.0-6                     extra      120,9 kB
libindicator-gtk3                 12.10.1-9                   community  99,5 kB
libinih                           53-1                        core       46,6 kB
libinput                          1.18.1-1                    extra      1,4 MB
libjpeg-turbo                     2.1.1-1                     extra      2,1 MB
libkeybinder3                     0.3.2-3                     extra      77,4 kB
libksba                           1.6.0-1                     core       333,8 kB
libldap                           2.4.59-2                    core       957,4 kB
libmanette                        0.2.6-2                     community  398,3 kB
libmd                             1.0.3-1                     community  91,0 kB
libmfx                            21.2.3-1                    community  288,6 kB
libmm-glib                        1.16.10-1                   extra      5,7 MB
libmnl                            1.0.4-3                     core       34,7 kB
libmodplug                        0.8.9.0-3                   extra      374,7 kB
libmpc                            1.2.1-1                     core       152,8 kB
libndp                            1.8-1                       extra      58,1 kB
libnetfilter_conntrack            1.0.8-1                     core       153,5 kB
libnewt                           0.52.21-5                   community  365,1 kB
libnfnetlink                      1.0.1-4                     core       43,2 kB
libnfs                            4.0.0-4                     community  687,8 kB
libnftnl                          1.2.0-1                     core       253,3 kB
libnghttp2                        1.44.0-1                    core       373,7 kB
libnl                             3.5.0-3                     core       2,1 MB
libnm                             1.32.8-1                    extra      9,8 MB
libnma                            1.8.30-1                    extra      1,8 MB
libnotify                         0.7.9-1                     extra      289,2 kB
libnsl                            1.3.0-2                     core       204,3 kB
libogg                            1.3.5-1                     extra      460,7 kB
libomxil-bellagio                 0.9.3-3                     extra      606,4 kB
libp11-kit                        0.24.0-1                    core       2,8 MB
libpamac                          11.0.1-3                    extra      3,4 MB
libpcap                           1.10.1-1                    core       633,6 kB
libpciaccess                      0.16-2                      extra      63,2 kB
libpgm                            5.3.128-1                   community  421,7 kB
libpipeline                       1.5.3-1                     core       89,7 kB
libpng                            1.6.37-3                    extra      580,2 kB
libproxy                          0.4.17-2                    extra      303,1 kB
libpsl                            0.21.1-1                    core       193,0 kB
libpulse                          15.0-1                      extra      1,6 MB
libraw1394                        2.1.2-3                     extra      164,8 kB
librsvg                           2:2.50.7-1                  extra      9,4 MB
libsamplerate                     0.2.1-1                     extra      1,6 MB
libsasl                           2.1.27-3                    core       520,2 kB
libseccomp                        2.5.1-2                     core       265,2 kB
libsecret                         0.20.4-1                    core       2,3 MB
libsigc++                         2.10.7-2                    extra      1,2 MB
libsm                             1.2.3-2                     extra      267,5 kB
libsndfile                        1.0.31-1                    extra      1,0 MB
libsodium                         1.0.18-2                    extra      518,4 kB
libsoup                           2.72.0+10+gfe1e295d-1       extra      5,1 MB
libsoxr                           0.1.3-2                     extra      342,6 kB
libssh                            0.9.5-1                     extra      589,9 kB
libssh2                           1.9.0-3                     core       424,4 kB
libstemmer                        2.1.0-1                     extra      813,7 kB
libtasn1                          4.17.0-1                    core       459,0 kB
libteam                           1.31-3                      extra      1,1 MB
libthai                           0.1.28-2                    extra      672,2 kB
libtheora                         1.1.1-5                     extra      1,8 MB
libtiff                           4.3.0-1                     extra      3,0 MB
libtirpc                          1.3.2-1                     core       445,3 kB
libtool                           2.4.6+42+gb88cebd5-16       core       2,3 MB
libunistring                      0.9.10-3                    core       2,4 MB
libunwind                         1.5.0-1                     extra      272,2 kB
libusb                            1.0.24-2                    core       209,1 kB
libva                             2.12.0-1                    extra      864,6 kB
libva-mesa-driver                 21.1.6-1                    extra      11,6 MB
libva-vdpau-driver                0.7.4-5                     extra      104,2 kB
libvdpau                          1.4-1                       extra      272,0 kB
libvorbis                         1.3.7-2                     extra      1,5 MB
libvpx                            1.10.0-1                    extra      4,6 MB
libwacom                          1.11-1                      extra      649,0 kB
libwebp                           1.2.1-1                     extra      1,1 MB
libwpe                            1.10.1-1                    extra      272,1 kB
libx11                            1.7.2-1                     extra      10,6 MB
libx86emu                         3.1-1                       community  177,0 kB
libxau                            1.0.9-3                     extra      21,7 kB
libxcb                            1.14-1                      extra      3,9 MB
libxcomposite                     0.4.5-3                     extra      24,2 kB
libxcrypt                         4.4.25-1                    core       210,9 kB
libxcursor                        1.2.0-2                     extra      62,5 kB
libxdamage                        1.1.5-3                     extra      17,6 kB
libxdmcp                          1.1.3-3                     extra      133,1 kB
libxext                           1.3.4-3                     extra      318,3 kB
libxfixes                         6.0.0-1                     extra      42,0 kB
libxfont2                         2.0.5-1                     extra      249,5 kB
libxft                            2.3.4-1                     extra      116,8 kB
libxi                             1.7.10-3                    extra      495,7 kB
libxinerama                       1.1.4-3                     extra      24,8 kB
libxkbcommon                      1.3.0-1                     extra      793,1 kB
libxkbcommon-x11                  1.3.0-1                     extra      73,0 kB
libxkbfile                        1.1.0-2                     extra      203,6 kB
libxklavier                       5.4-3                       extra      379,7 kB
libxml2                           2.9.10-9                    extra      9,7 MB
libxmu                            1.1.3-2                     extra      350,4 kB
libxrandr                         1.5.2-3                     extra      72,8 kB
libxrender                        0.9.10-4                    extra      79,4 kB
libxshmfence                      1.3-2                       extra      17,0 kB
libxslt                           1.1.34-5                    extra      2,3 MB
libxss                            1.2.3-3                     extra      26,8 kB
libxt                             1.2.1-1                     extra      2,1 MB
libxtst                           1.2.3-4                     extra      114,8 kB
libxv                             1.0.11-4                    extra      61,4 kB
libxvmc                           1.0.12-3                    extra      95,2 kB
libxxf86vm                        1.1.4-4                     extra      35,9 kB
libyaml                           0.2.5-1                     extra      188,5 kB
licenses                          20200427-1                  core       425,9 kB
lightdm                           1:1.30.0-4                  extra      1,1 MB
lightdm-gtk-greeter               1:2.0.8-1                   extra      331,9 kB
lightdm-gtk-greeter-settings      1.2.2-6                     community  960,4 kB
linux-api-headers                 5.12.3-1                    core       5,1 MB
linux-firmware                    20210719.r1990.168452e-1    core       733,6 MB
linux510                          5.10.59-1                   core       82,0 MB
llvm-libs                         12.0.1-3                    extra      103,2 MB
lm_sensors                        1:3.6.0.r41.g31d1f125-1     extra      487,5 kB
lmdb                              0.9.29-1                    extra      542,2 kB
logrotate                         3.18.1-1                    core       110,6 kB
lsb-release                       1.4-13                      core       41,0 kB
lvm2                              2.03.13-1                   core       6,5 MB
lxappearance-gtk3                 0.6.3-4                     community  404,8 kB
lxde-common                       0.99.2-3                    community  925,1 kB
lxde-wallpapers                   20170907-1                  community  10,1 MB
lxhotkey                          0.1.1-1                     community  237,3 kB
lxinput-gtk3                      0.3.5-3                     community  212,0 kB
lxlauncher-gtk3                   0.2.5-4                     community  158,1 kB
lxmenu-data                       0.1.5-3                     community  163,3 kB
lxpanel-gtk3                      0.10.1-1                    community  3,4 MB
lxrandr-gtk3                      0.3.2-2                     community  237,4 kB
lxsession-gtk3                    1:0.5.5-1                   community  1,5 MB
lxtask-gtk3                       0.1.10-1                    community  264,0 kB
lxterminal                        0.4.0-1                     community  404,6 kB
lz4                               1:1.9.3-2                   core       431,3 kB
lzo                               2.10-3                      core       411,7 kB
mailcap                           2.1.53-1                    extra      111,3 kB
man-db                            2.9.4-2                     core       2,4 MB
man-pages                         5.12-2                      core       6,0 MB
manjaro-application-utility       1.3.3-5                     community  180,3 kB
manjaro-documentation-en          20181009-1                  extra      10,0 MB
manjaro-firmware                  20160419-1                  extra      2,6 MB
manjaro-hello                     0.6.6-8                     extra      367,9 kB
manjaro-icons                     20191015-1                  extra      127,0 kB
manjaro-keyring                   20210807-2                  core       181,0 kB
manjaro-lxde-config               0.2-2                       community  54,8 kB
manjaro-lxde-desktop-settings     0.2-2                       community  3,0 kB
manjaro-lxde-logout-banner        0.1-1                       community  205,8 kB
manjaro-openbox-flatred-theme     0.3-1                       community  478,1 kB
manjaro-openbox-matcha            1.0-3                       community  41,0 kB
manjaro-release                   21.1.0-1                    core       106 bytes
manjaro-settings-manager          0.5.6-15                    extra      4,9 MB
manjaro-settings-manager-notifier 0.5.6-15                    extra      736,2 kB
manjaro-system                    20210612-1                  core       369 bytes
manjaro-zsh-config                0.20-3                      community  374,8 kB
masalla-icon-theme                1.2-1                       community  79,6 MB
matcha-gtk-theme                  20210802-1                  community  31,4 MB
md4c                              0.4.8-1                     extra      260,3 kB
mdadm                             4.1-2                       core       995,2 kB
memtest86+                        5.31b-1                     extra      155,1 kB
menu-cache                        1.1.0-2                     community  263,5 kB
mesa                              21.1.6-1                    extra      103,1 MB
mesa-vdpau                        21.1.6-1                    extra      12,0 MB
mhwd                              0.6.5-2                     core       253,4 kB
mhwd-amdgpu                       19.1.0-1                    core       1,0 kB
mhwd-ati                          19.1.0-1                    core       4,0 kB
mhwd-db                           0.6.5-15                    core       27,5 kB
mhwd-nvidia                       470.63.01-1                 core       1,7 kB
mhwd-nvidia-390xx                 390.144-1                   core       1,9 kB
minizip                           1:1.2.11-4                  core       87,6 kB
mkinitcpio                        30-2                        core       105,8 kB
mkinitcpio-busybox                1.33.1-1                    core       524,5 kB
mkinitcpio-openswap               0.1.0-3                     extra      2,3 kB
mlocate                           0.26.git.20170220-7         core       356,1 kB
mobile-broadband-provider-info    20201225-1                  extra      505,0 kB
mpfr                              4.1.0.p13-1                 core       980,9 kB
mtdev                             1.1.6-1                     extra      52,2 kB
nano                              5.8-1                       core       2,5 MB
ncurses                           6.2-2                       core       3,7 MB
ndctl                             71.1-1                      extra      647,6 kB
nerd-fonts-noto-sans-mono         2.0.0-1                     community  7,5 MB
nettle                            3.7.3-1                     core       985,1 kB
network-manager-applet            1.22.0-1                    extra      615,5 kB
networkmanager                    1.32.8-1                    extra      17,3 MB
networkmanager-openvpn            1.8.14-1                    extra      1,3 MB
nfs-utils                         2.5.4-1                     core       1,6 MB
nfsidmap                          2.5.4-1                     core       262,8 kB
nftables                          1:0.9.9-6                   extra      930,2 kB
nm-connection-editor              1.22.0-1                    extra      4,7 MB
npth                              1.6-3                       core       70,7 kB
nspr                              4.32-1                      core       755,8 kB
nss                               3.69-1                      core       5,6 MB
ntfs-3g                           2017.3.23-5                 extra      1,8 MB
numlockx                          1.2-5                       community  15,2 kB
obconf                            2.0.4-7                     community  784,2 kB
openbox                           3.6.1-7                     community  1,3 MB
opencore-amr                      0.1.5-5                     extra      306,1 kB
openjpeg2                         2.4.0-1                     extra      14,7 MB
openresolv                        3.12.0-1                    core       62,2 kB
openssh                           8.6p1-1                     core       6,1 MB
openssl                           1.1.1.k-1                   core       7,7 MB
openvpn                           2.5.3-1                     extra      1,6 MB
opus                              1.3.1-2                     extra      1,8 MB
orc                               0.4.32-1                    extra      1,1 MB
os-prober                         1.78-0.1                    community  80,0 kB
p11-kit                           0.24.0-1                    core       732,1 kB
pacman                            6.0.0-2                     core       4,9 MB
pacman-mirrors                    4.21.5-1                    core       698,2 kB
pacui                             1.14-1                      community  216,4 kB
pam                               1.5.1-1                     core       2,8 MB
pamac-cli                         10.1.3-3                    extra      184,3 kB
pamac-gtk                         10.1.3-3                    extra      716,5 kB
pambase                           20210605-2                  core       2,7 kB
pango                             1:1.48.8-1                  extra      2,1 MB
pangomm                           2.46.1-2                    extra      510,4 kB
papirus-icon-theme                20210802-1                  community  102,8 MB
papirus-maia-icon-theme           20200702-1                  community  10,0 MB
parted                            3.4-2                       extra      2,4 MB
pastebinit                        1.5.1-1                     community  168,5 kB
pciutils                          3.7.0-1                     core       279,7 kB
pcmanfm-gtk3                      1.3.2-1                     community  1,4 MB
pcre                              8.45-1                      core       3,6 MB
pcre2                             10.37-1                     core       4,1 MB
perl                              5.34.0-2                    core       61,7 MB
perl-clone                        0.45-3                      extra      21,1 kB
perl-encode-locale                1.05-8                      extra      16,6 kB
perl-error                        0.17029-3                   extra      44,1 kB
perl-file-basedir                 0.09-1                      extra      22,3 kB
perl-file-desktopentry            0.22-8                      extra      29,3 kB
perl-file-listing                 6.14-2                      extra      16,9 kB
perl-file-mimeinfo                0.30-2                      extra      84,0 kB
perl-html-parser                  3.76-2                      extra      174,7 kB
perl-html-tagset                  3.20-11                     extra      16,7 kB
perl-http-cookies                 6.10-2                      extra      44,8 kB
perl-http-daemon                  6.06-3                      extra      36,4 kB
perl-http-date                    6.05-4                      extra      15,0 kB
perl-http-message                 6.33-1                      extra      170,9 kB
perl-http-negotiate               6.01-9                      extra      20,3 kB
perl-io-html                      1.004-2                     extra      25,4 kB
perl-ipc-system-simple            1.30-3                      extra      41,4 kB
perl-libwww                       6.55-1                      extra      352,3 kB
perl-lwp-mediatypes               6.02-9                      extra      58,7 kB
perl-mailtools                    2.21-5                      extra      110,1 kB
perl-net-http                     6.21-2                      extra      43,8 kB
perl-timedate                     2.33-3                      extra      87,0 kB
perl-try-tiny                     0.30-6                      extra      29,6 kB
perl-uri                          5.09-2                      extra      167,3 kB
perl-www-robotrules               6.02-9                      extra      19,6 kB
perl-xml-parser                   2.46-3                      extra      450,9 kB
perl-xml-writer                   0.625-7                     community  49,6 kB
pinentry                          1.1.1-1                     core       522,8 kB
pixman                            0.40.0-1                    extra      733,6 kB
pkcs11-helper                     1.27.0-1                    extra      285,6 kB
pkgfile                           21-2                        extra      54,9 kB
polkit                            0.119-1                     extra      1,9 MB
polkit-qt5                        0.114.0-1                   extra      307,4 kB
poppler                           21.08.0-1                   extra      5,8 MB
poppler-glib                      21.08.0-1                   extra      2,7 MB
popt                              1.18-1                      core       220,6 kB
powertop                          2.14-1                      community  645,2 kB
procps-ng                         3.3.17-1                    core       1,6 MB
psmisc                            23.4-1                      core       646,4 kB
python                            3.9.6-1                     core       55,1 MB
python-appdirs                    1.4.4-3                     extra      78,1 kB
python-certifi                    2020.12.5-1                 community  274,6 kB
python-chardet                    4.0.0-2                     extra      1,8 MB
python-dnspython                  1:1.16.0-3                  community  1,3 MB
python-docopt                     0.6.2-9                     community  84,8 kB
python-gobject                    3.40.1-1                    extra      1,2 MB
python-idna                       3.2-1                       extra      640,0 kB
python-keyutils                   0.6-6                       community  77,6 kB
python-markdown                   3.3.4-1                     community  528,8 kB
python-more-itertools             8.8.0-1                     community  304,4 kB
python-npyscreen                  4.10.5-5                    community  1,0 MB
python-ordered-set                4.0.2-3                     extra      58,9 kB
python-packaging                  20.9-1                      extra      196,2 kB
python-pyparsing                  2.4.7-3                     extra      762,8 kB
python-pyxdg                      0.27-1                      extra      402,1 kB
python-requests                   2.26.0-1                    extra      471,6 kB
python-setuptools                 1:57.4.0-1                  extra      3,1 MB
python-six                        1.16.0-1                    extra      92,8 kB
python-urllib3                    1.26.6-1                    extra      728,3 kB
python-yaml                       5.4.1.1-2                   community  782,2 kB
qt5-base                          5.15.2+kde+r215-1           extra      68,3 MB
qt5-svg                           5.15.2+kde+r7-1             extra      502,4 kB
qt5-x11extras                     5.15.2-1                    extra      41,6 kB
qt5ct                             1.3-1                       community  885,9 kB
rav1e                             0.4.1-1                     extra      6,1 MB
re2                               1:20210801-1                extra      482,5 kB
readline                          8.1.001-1                   core       748,7 kB
reiserfsprogs                     3.6.27-3                    core       609,7 kB
rest                              0.8.1-3                     extra      875,8 kB
rpcbind                           1.2.6-1                     core       96,7 kB
rsync                             3.2.3-4                     extra      593,7 kB
run-parts                         4.11.2-1                    core       46,1 kB
s-nail                            14.9.22-1                   core       1,0 MB
scrot                             1.6-2                       community  112,0 kB
sdl                               1.2.15-14                   community  1,1 MB
sdl2                              2.0.16-2                    extra      3,6 MB
sed                               4.8-1                       core       753,5 kB
shadow                            4.8.1-4                     core       3,9 MB
shared-mime-info                  2.0+57+gc1d1c70-1           extra      4,6 MB
slang                             2.3.2-2                     extra      3,3 MB
smbclient                         4.14.6-1                    extra      29,5 MB
snappy                            1.1.8-2                     extra      75,3 kB
sound-theme-freedesktop           0.8-4                       extra      472,3 kB
spectre-meltdown-checker          0.44-1                      community  220,1 kB
speex                             1.2.0-3                     extra      651,1 kB
speexdsp                          1.2.0-2                     extra      561,9 kB
sqlite                            3.36.0-1                    core       10,0 MB
squashfs-tools                    4.5-1                       extra      403,7 kB
srt                               1.4.3-1                     extra      9,0 MB
startup-notification              0.12-7                      extra      62,4 kB
sudo                              1.9.7.p2-1                  core       6,8 MB
svt-av1                           0.8.7-1                     extra      6,3 MB
sysfsutils                        2.1.1-1                     core       90,5 kB
systemd                           248.7-1                     core       27,1 MB
systemd-fsck-silent               239-1                       extra      34,8 kB
systemd-libs                      248.7-1                     core       1,9 MB
systemd-sysvcompat                248.7-1                     core       2,4 kB
talloc                            2.3.3-1                     extra      175,6 kB
tar                               1.34-1                      core       3,0 MB
tdb                               1.4.5-1                     extra      241,9 kB
tevent                            1:0.11.0-1                  extra      196,9 kB
texinfo                           6.8-2                       core       9,2 MB
thin-provisioning-tools           0.9.0-1                     core       1,7 MB
thunderbird                       78.13.0-1                   extra      181,9 MB
tlp                               1.3.1-2                     community  268,1 kB
tlpui                             1.3.1.8-1                   community  882,2 kB
tslib                             1.22-1                      extra      494,5 kB
ttf-dejavu                        2.37+18+g9b5d1b2f-3         extra      10,5 MB
ttf-liberation                    2.1.4-1                     community  4,4 MB
ttf-roboto                        2.138-4                     community  5,4 MB
tzdata                            2021a-1                     core       2,3 MB
udiskie                           2.3.3-1                     community  649,4 kB
udisks2                           2.9.3-1                     extra      14,5 MB
ufw                               0.36-5                      community  811,1 kB
unzip                             6.0-14                      extra      322,7 kB
usbutils                          013-1                       core       321,4 kB
util-linux                        2.37.1-3                    core       14,3 MB
util-linux-libs                   2.37.1-3                    core       1,5 MB
v4l-utils                         1.20.0-1                    extra      4,7 MB
v86d                              0.1.10-5.1                  extra      162,8 kB
vi                                1:070224-5                  core       323,1 kB
vid.stab                          1.1-3                       extra      141,3 kB
vmaf                              1.5.3-1                     community  4,8 MB
volume_key                        0.3.12-5                    extra      829,4 kB
vte-common                        0.64.2-2                    extra      16,6 kB
vte3                              0.64.2-2                    extra      1,9 MB
vulkan-icd-loader                 1.2.186-1                   extra      403,0 kB
vulkan-intel                      21.1.6-1                    extra      10,2 MB
vulkan-radeon                     21.1.6-1                    extra      7,7 MB
wayland                           1.19.0-1                    extra      786,5 kB
wayland-protocols                 1.21-1                      extra      429,8 kB
web-installer-url-handler         1.0.2-1                     community  1,7 kB
webkit2gtk                        2.32.3-1                    extra      107,2 MB
wget                              1.21.1-1                    extra      3,1 MB
which                             2.21-5                      core       35,2 kB
wireless-regdb                    2021.04.21-1                core       16,7 kB
woff2                             1.0.2-3                     extra      202,4 kB
wpa_supplicant                    2:2.9-8                     core       5,9 MB
wpebackend-fdo                    1.10.0-1                    extra      114,5 kB
x264                              3:0.161.r3039.544c61f-1     extra      3,9 MB
x265                              3.5-1                       extra      19,8 MB
xcb-proto                         1.14.1-3                    extra      866,5 kB
xcb-util                          0.4.0-3                     extra      39,1 kB
xcb-util-image                    0.4.0-3                     extra      54,1 kB
xcb-util-keysyms                  0.4.0-3                     extra      30,0 kB
xcb-util-renderutil               0.3.9-3                     extra      36,8 kB
xcb-util-wm                       0.4.1-3                     extra      229,8 kB
xclip                             0.13-3                      extra      35,2 kB
xcursor-breeze                    5.11.5-1                    community  5,5 MB
xdg-dbus-proxy                    0.1.2-3                     extra      53,9 kB
xdg-user-dirs                     0.17-3                      extra      152,1 kB
xdg-utils                         1.1.3+19+g9816ebb-1         extra      289,9 kB
xf86-input-libinput               1.1.0-1                     extra      97,8 kB
xf86-video-amdgpu                 21.0.0-1                    extra      169,8 kB
xf86-video-ati                    1:19.1.0-2                  extra      528,5 kB
xf86-video-intel                  1:2.99.917+916+g31486f40-1  extra      2,3 MB
xf86-video-nouveau                1.0.17-1                    extra      228,2 kB
xfsprogs                          5.12.0-1                    core       5,7 MB
xkeyboard-config                  2.33-1                      extra      6,0 MB
xorg-fonts-100dpi                 1.0.3-7                     extra      12,8 MB
xorg-fonts-75dpi                  1.0.3-7                     extra      11,2 MB
xorg-fonts-alias-100dpi           1.0.4-1                     extra      3,6 kB
xorg-fonts-alias-75dpi            1.0.4-1                     extra      3,5 kB
xorg-fonts-encodings              1.0.5-2                     extra      640,4 kB
xorg-fonts-type1                  7.7-6                       extra      2,8 MB
xorg-server                       1.20.13-1                   extra      3,8 MB
xorg-server-common                1.20.13-1                   extra      130,3 kB
xorg-server-xephyr                1.20.13-1                   extra      2,3 MB
xorg-setxkbmap                    1.3.2-2                     extra      29,8 kB
xorg-xauth                        1.1-2                       extra      57,2 kB
xorg-xbacklight                   1.2.3-2                     extra      16,4 kB
xorg-xdpyinfo                     1.3.2-4                     extra      33,8 kB
xorg-xinit                        1.4.1-3                     extra      36,3 kB
xorg-xkbcomp                      1.4.5-1                     extra      227,2 kB
xorg-xkill                        1.0.5-2                     extra      17,0 kB
xorg-xmodmap                      1.0.10-2                    extra      50,3 kB
xorg-xprop                        1.2.5-1                     extra      57,3 kB
xorg-xrandr                       1.5.1-2                     extra      71,1 kB
xorg-xrdb                         1.2.0-2                     extra      41,5 kB
xorg-xset                         1.2.4-2                     extra      40,7 kB
xorg-xwininfo                     1.1.5-2                     extra      53,4 kB
xorgproto                         2021.4-1                    extra      1,5 MB
xsel                              1.2.0.20190821-1            community  41,1 kB
xvidcore                          1.3.7-2                     extra      709,0 kB
xxhash                            0.8.0-1                     community  297,7 kB
xz                                5.2.5-1                     core       968,6 kB
zensu                             0.3-1                       community  2,6 kB
zeromq                            4.3.4-1                     community  3,4 MB
zimg                              3.0.2-1                     extra      985,7 kB
zip                               3.0-9                       extra      571,5 kB
zita-alsa-pcmi                    0.3.2-3                     extra      83,0 kB
zita-resampler                    1.8.0-1                     extra      202,6 kB
zlib                              1:1.2.11-4                  core       341,6 kB
zsh                               5.8-1                       extra      6,5 MB
zsh-autosuggestions               0.7.0-1                     community  43,6 kB
zsh-completions                   0.33.0-1                    community  1,2 MB
zsh-history-substring-search      1.0.2-1                     community  36,9 kB
zsh-syntax-highlighting           0.7.1-1                     community  143,2 kB
zsh-theme-powerlevel10k           1.15.0-2                    community  3,7 MB
zstd                              1.5.0-1                     core       3,8 MB
Hello @rmcaetanoalves :wink:
I guess you are looking for this folder: ~/.config/autostart → Autostart - LXDE.org.
Under settings there have to be also some kind of gui there.
Thanks for your help my friend.
I checked the folder and related files, however, I couldn’t find the command or shortcut that is starting the task manager.
Every time I turn on the machine the task manager opens with it.
And what about this file?
~/.config/lxsession/LXDE/autostart
https://wiki.archlinux.org/title/LXDE#Autostart
I accessed this file and in it I also didn’t find anything related to running the task manager
@lxpanel --profile LXDE
@pcmanfm --desktop --profile LXDE
@xset s off -dpms
~/.config/autostart`
Last idea would be that there is some kind session/profile saved one time and it loads it on every login. No idea, where and how and I have no LXDE desktop installed.
Navigate the Menu from the Manjaro icon → Preferences → Desktop Session Settings
Enable or disable autostarted applications
Screenshot
I accessed the menu you indicated and there, only the options below are marked.
Task Manager is not listed there
After searching and tinkering with some apps and functions, I found the;
lxtask
marked in the last option of this window “Screen Manager”
Removed the text “lxtask” and now it doesn’t start with the system
