Hi. I currently have 3 kernels installed: 5.4 LTS, 5.10, 5.13.
My understanding (hope I’m not wrong!) is that both 5.4 and 5.10 are LTS. I thought I could remove 5.4 since I don’t want 2 LTS versions…I get an error message though when I try to remove 5.4:
I was just trying to free up some space on my boot partition since it’s full; I only have 3 kernels installed (I should have assigned more space to my boot partition when I installed!).
Can anyone advise what I need to do to remove 5.4 or can I not do that?
Strange…so I rebooted and then used settings manager to remove the kernel and this time it was successful. I’m not sure why I still had to remove the kernel from settings manager after already removing it from the cli…
linux-lts and linux-stable are no longer in the repos. You have to select which particular kernel you want (i.e, linux510, linux512, linux513, etc.)
If you use the Manjaro Settings Manager, the LTS and Recommended tags signify which ones to use for those of us who wish to stay on LTS kernels. So rather than relying on a metapackage, you have to manually jump from LTS to LTS when the time comes.
