Remote Peer Disconnected
I have this same problem now myself. The most strange part is, if I launch from the GUI menu, it fails with this error. If I launch from a command terminal, it works fine using the same command from the KDE GUI menu. Doesn’t make any sense at all.
Note this happened after the latest patch.
I have converted your post to a dedicated thread where it can attract maximum attention.
Please provide the neccessary information for others to help you discover if indeed it is the same problem.
Note:- The forum might be a little slow this time of year. Any information in addition to the system information requested may also be helpful.
Please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
Output of the following command (formatted according to forum requirements) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
Thanks for the info. Note, this is not OS breaking, just annoying. I assume a new user however might get detered by it. I can leave it as is, or remove Pamac and reinstall Pamac to see if that fixes it… I will wait for someone to advise me on testing for a fix before I try to fix it myself. This will maybe let us find the root cause.
If I had to guess, the root cause may be with GTK4. I had another issue with this app and super large mouse cursor sizes and GTK4. I hear there is a fix for this in March 2025, but the workaround for now is to not use Breeze icons. This of course is a totally unrelated issue.
This current problem for the original issue is I get the following message when launching Pamac from the KDE GUI menu:
Checking what is in the KDE menu:
But if I run the same command in a terminal window, it works fine with no errors, only a warning:
/bin/pamac-manager %U                                               ✔
(pamac-manager:55897): Adwaita-WARNING **: 18:33:33.462: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
System info:
inxi --admin --verbosity=8 --filter --no-host --width               ✔
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=cfd0c22e-f935-4d70-96df-08f59fc0f939 rw splash
    resume=UUID=58e51981-e62b-4738-8436-1b39c03a0353 udev.log_priority=3 quiet
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
  Type: Desktop Mobo: ASRock model: X570 Steel Legend
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: P5.63 date: 08/22/2024
  System RAM: total: 32 GiB available: 31.27 GiB used: 11.07 GiB (35.4%)
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX4M4D3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 1753 min/max: 550/4550 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1753 2: 1753 3: 1753
    4: 1753 5: 1753 6: 1753 7: 1753 8: 1753 9: 1753 10: 1753 11: 1753 12: 1753
    13: 1753 14: 1753 15: 1753 16: 1753 bogomips: 108634
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
    XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3,Writeback-1 bus-ID: 0f:00.0
    chip-ID: 1002:747e class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon,vesa alternate: fbdev dri: radeonsi
    gpu: amdgpu d-rect: 7179x1391 display-ID: 0
  Monitor-1: DP-1 pos: center res: 3339x1391 size: N/A modes: N/A
  Monitor-2: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
  Monitor-3: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
    surfaces: xcb,xlib,wayland
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0f:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 11:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
  Device-1: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.82 TiB used: 854.52 GiB (45.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP600
    lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM11.1 temp: 40.9 C
    scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH08LS20 rev: 2.00
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 1.34 TiB size: 1.32 TiB (98.35%) used: 854.49 GiB (63.4%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: cfd0c22e-f935-4d70-96df-08f59fc0f939
    used: 25.5 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A0C8-6C9A
  ID-3: /mnt/nas raw-size: N/A size: 3.63 TiB used: 3.34 TiB (91.9%) fs: nfs4
    remote: 192.168.11.165:/Multimedia
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: 58e51981-e62b-4738-8436-1b39c03a0353
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: ext4 label: N/A
    uuid: dcf7b311-797b-47b6-bfbe-2b3062f4459d
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 488.27 GiB fs: ntfs label: N/A
    uuid: 3CA44955A44912B6
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-5:3 info: ThrustMaster HOTAS Warthog Throttle type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 044f:0404 class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:3 info: SMK Manufacturing eHome Infrared Receiver
    type: <vendor specific> driver: mceusb interfaces: 1 rev: 1.1
    chip-ID: 0609:031d class-ID: 0000 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-3:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Device-1: 4-3.4:3 info: Genesys Logic All-in-One Cardreader
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 05e3:0732 class-ID: 0806 serial: <filter>
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: DEXIN MADCATZ R.A.T. 8+ gaming mouse
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 50mA
    chip-ID: 12cf:0c05 class-ID: 0300
  Device-2: 5-2:3 info: ThrustMaster HOTAS Warthog Joystick type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 044f:0402 class-ID: 0300
  Device-3: 5-3:4 info: Natural Point type: N/A driver: N/A interfaces: 1
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 366mA
    chip-ID: 131d:0157 class-ID: 0000
  Device-4: 5-4:5 info: Razer USA Tartarus V2 type: keyboard,mouse
    driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:022b class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 33.5 C mobo: 33.0 C gpu: amdgpu temp: 59.0 C
    mem: 68.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 830 fan-3: 0 fan-4: 0 fan-5: 0 fan-6: 0
    fan-7: 0 gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1729 libs: 459 tools: octopi,pamac pm: flatpak
    pkgs: 0
  Active pacman repo servers in: /etc/pacman.conf
    1: file:///mnt/nas/rsync/stable/$repo/$arch
    2: file:///mnt/nas/rsync/stable/$repo/$arch
    3: file:///mnt/nas/rsync/stable/$repo/$arch
Processes:
  CPU top: 5 of 380
  1: cpu: 7.5% command: konsole pid: 54655 mem: 237.9 MiB (0.7%)
  2: cpu: 3.8% command: firefox pid: 2185 mem: 913.8 MiB (2.8%)
  3: cpu: 3.4% command: zsh pid: 54693 mem: 9.60 MiB (0.0%)
  4: cpu: 3.0% command: kwin_wayland pid: 1170 mem: 1041.2 MiB (3.2%)
  5: cpu: 2.8% command: firefox pid: 2667 mem: 132.0 MiB (0.4%)
  Memory top: 5 of 380
  1: mem: 1787.0 MiB (5.5%)
    command: 1838_Lost_Lagoon_Dr___Residential_Inspection.pdf started-by: okular
    pid: 5209 cpu: 0.1%
  2: mem: 1041.2 MiB (3.2%) command: kwin_wayland pid: 1170 cpu: 3.0%
  3: mem: 913.8 MiB (2.8%) command: firefox pid: 2185 cpu: 3.8%
  4: mem: 871.6 MiB (2.7%)
    pid: 41132 cpu: 0.1%
  5: mem: 744.0 MiB (2.3%) command: plasmashell pid: 1442 cpu: 1.3%
  Processes: 380 Power: uptime: 12h 12m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
As you are using Plasma, you might find that replacing pamac-gtk with pamac-gtk3 (which does not rely on Adwaita) works better on your system. Just run the command:
pamac install pamac-gtk3
Yeah, this works. I like the GTK3 version better anyway. Forgot why I went to GTK4 for this thing.
Thx for the tip.
To be clear, installing pamac-gtk3 solved your issue?
If so, please mark the post that solved it (or helped you solve it) as the solution. As a member since 2021 you know how it works. :wink:
Yep, it is solved. Still playing with it, but this is a good workaround.
